21 tacoma vibration/drag after leveling kit? Clam shell bushing fix?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Section8joe, Feb 25, 2024.
  1. Feb 25, 2024 at 6:54 AM
    Section8joe
    Section8joe [OP] Member
    Joe
    2021 off road
    I recently leveled my 21 Tacoma Off Road. A week or 2 after I noticed a slight vibration or drag around 27-33mph at certain times. I took it to my mechanic and everything looks good on his end. I'm fairly certain i need to replace the needle bearing with the clam shell bushing. How can I be 100% certain? Is there anything else that can cause that problem? Sorry for the newbie question, I just don't want to throw money at the wrong fix.
  2. Feb 25, 2024 at 6:57 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Drive in straight line on 4 hi. If it goes away, then it's the bushing.
    303tacoma likes this.
  3. Feb 25, 2024 at 7:01 AM
    Section8joe
    Joe
    2021 off road
    The thing is, it's not all the time and it's not too distinct. I can barely feel it but I know it's there. I'll try and find a spot when I can feel it and try it in 4hi.
  4. Feb 25, 2024 at 7:03 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Most Likely going to have to replace Needle Bearing
  5. Feb 25, 2024 at 7:22 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    What did you do to level your truck? Did you just put spacers on the front shocks?
    And did you get an alignment after?
  6. Feb 25, 2024 at 7:28 AM
    Bishop84
    Bishop84 Well-Known Member
    If you feel it in your foot and it goes away in 4x4 its the clamshell bearing.
    Especially with spacer lifts.
    71tattooguy likes this.
  7. Feb 25, 2024 at 7:38 AM
    Section8joe
    Joe
    2021 off road
    I didn't use the spacers, I used Bilstein front shocks and I did have the alignment checked after the leveling kit.
  8. Feb 25, 2024 at 11:29 AM
    Section8joe
    Joe
    2021 off road
    Ok. Like I said the feeling/vibration is very faint but it does seem to go away when in 4 wheel high.
