210 plug in bed of 2019 Toyota Tacoma
Discussion in '3rd Gen. Tacomas (2016+)' started by JanEagle, Sep 26, 2018.
  1. Sep 26, 2018 at 9:54 AM
    JanEagle
    JanEagle [OP] Member
    Central California Coast
    2019 toyota tacoma trd off road 4x4 v6 short bed
    fully loaded
    What can you run off this? Is it just for portable pump to pump up your tires after offloading?
    Will it run a blender for margaritas? Can you hook up a small microwave to cook hotdogs? I guess it all comes down to the voltage etc....just wondering what anyone has used theirs for...
  2. Sep 26, 2018 at 9:58 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    It's actually only ~120v, like a normal outlet in your house. You'd need a blender that was under 400 watts.
  3. Sep 26, 2018 at 9:58 AM
    Techsan
    Techsan Well-Known Member
    South Texas
    2017 BBPDC
    210...220...whatever it takes
  4. Sep 26, 2018 at 10:04 AM
    whatstcp
    whatstcp currently drunk so don't listen to me
    Ed
    Fontana, CA
    2006 Tacoma Regular Cab 2.7l 4x4
    King + Archive Relocation Wheeler's bumps +hydros
    400 watts will net you ~3.5amps which isn't enough for a decent sized anything. A box fan, hairdryer with heat off. I've heard of people using small sawzalls or drills with light loads works ok but may as well use cordless and use the outlet to charge batteries while driving
    JanEagle [OP] likes this.
  5. Sep 26, 2018 at 10:08 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    The only thing I used the plug for is to blow up a air mattress while car camping and a drop light. Pretty slick, but as mentioned not very powerful.
  6. Sep 26, 2018 at 10:15 AM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I haven't looked yet, but wondering if a small air compressor would work on the plug. I know there are off-road specific compressors, but seems most run off the battery. I'm curious if one running of 120v would be better. Some of the 12v ones pull pretty high amps and not sure a stock alternator would be up to the task. Maybe a 120v option would present less of an issue.
  7. Sep 26, 2018 at 10:41 AM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill
    I wonder if we could start a thread with things that DO work... like with Amazon links. That way if you needed something you could quick reference that thread and see "ok so this air pump from Amazon will work" this blender... this refrigerator.. etc... take the mystery out of the equation.
    Would be nice I'd toyota provided a list of sorts
    oconnor, Simpleton and JanEagle [OP] like this.
  8. Sep 26, 2018 at 10:45 AM
    DrSouthpaw
    DrSouthpaw 2 dogs 1 truck
    Spur
    AZ
    2017 MGM TRD OR 4x4 DCSB
    This air freshener will work
    Glade PlugIns Scented Oil Air Freshener, Clean Linen, 6 Refills and 2 Warmers, 4.02 Fluid Ounce https://www.amazon.com/dp/B01KQ9CNS6/ref=cm_sw_r_cp_api_jw8QBbMQJ24Q2
  9. Sep 26, 2018 at 10:48 AM
    dnlskier
    17' TRD SPORT MT
    It would be pretty bad ass if I could have a mini-fridge plugged in while driving!! Plug it at home while packing it with extension cord to the garage. Then, when you road trip it, plug it tnto the truck. Of course I ened a bee....er sorry soda dispenser for the trip?? Hmm, who can fab this press a button and out rolls a bee.....er I mean soda directly to my cup holder :humble:
    JanEagle [OP], tonered and BSFord like this.
  10. Sep 26, 2018 at 10:48 AM
    BSFord
    2018 TRD Sport 4x4
    tonered likes this.
  11. Sep 26, 2018 at 10:50 AM
    tonered
    tonered tacorider
    tony
    Lynnwood, WA
    As a shortcut, how about this:
    https://www.rapidtables.com/calc/electric/watt-volt-amp-calculator.html
    Just enter any two of the values (400W and 120V, for example), and it will spit out an answer (3.3A). That ain't much to work with.
    I tried a HF corded impact wrench hoping it might loosen the lugs. It runs but won't loosen a lug nut after letting it run for a long time (> 15sec).
    JanEagle [OP] and HelloMyNameIs like this.
  12. Sep 26, 2018 at 10:50 AM
    HelloMyNameIs
  13. Sep 26, 2018 at 11:03 AM
    Gator352
    Gator352 I like Publix cake ...
    Leesburg, Florida
    2018 Super White Tacoma SR5 4x2
    For when your woman gets lonely when your hunting.
    HelloMyNameIs likes this.
  14. Sep 26, 2018 at 1:00 PM
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, Bak X2 Tonneau, custom breaker box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs.
    You mean, this thread? https://www.tacomaworld.com/threads...-bed-inverter-for-today-now-with-poll.495878/
