215/75/15 versus 215/70/15 on stock '09
Discussion in '5 Lug' started by RobZ71LM7, Dec 14, 2010.
  1. Dec 14, 2010 at 8:38 PM
    RobZ71LM7
    RobZ71LM7 [OP] Member
    Mount Washington, KY
    09 Tacoma Reg Cab, 2.7L 5-speed
    I just bought an '09 Tacoma last week-base model, 4cyl, 5-speed. I'm looking to replace the OEM tires and there are a lot more options in a 75 series tire. I bought the truck to haul building materials, gear, and my waverunner. Will I b able to notice any appreciable difference with 215/75's versus 215/70's?
  2. Dec 14, 2010 at 8:43 PM
    only49ersfan
    only49ersfan Well-Known Member
    Myrtle Beach, SC
    09 Tacoma 4X4
    Not much. Step bars, K&N air filter
    i believe the 215/75R15s are only 0.7" taller. if they are cheaper and easier to find, go with the 215/75s. shouldnt throw off speedometer or odometer and deffinitly wont rub. Also, sometimes larger tires are cheaper due to demand. my 2 cents
  3. Dec 14, 2010 at 9:05 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    x2 you can fit wider tires as well without any rubbing issues stock.
  4. Dec 14, 2010 at 9:42 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    You can go as far as 235/75/15 without rubbing issues. Trust me the 5lugger with bigger tires looks awesome, just check out my build and see ;)
  5. Dec 15, 2010 at 12:07 AM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    225/75/15....FTW!!!!
    Check out the build link in my sig.
    Has thrown my odo off a tiny bit.
  6. Dec 15, 2010 at 7:24 AM
    RobZ71LM7
    With the stock gearing would going up to a 225 hurt power any? I only ask because when I got the truck I expected the gearing to feel a lot lower/shorter with such small tires.
    Does anyone know the gearing in the transmission for the 4cyl Prerunner that has 245/75/16's? I'd like to do some calculations to compare how it's geared versus mine if I went with taller tires.
    Thanks.
  7. Dec 15, 2010 at 7:53 AM
    05RedTaco
    Tony
    Scottsdale
    I run 31x10.5x15 tires on my 5lugger with stock gearing. Yes it looses some power, however it is not horrible, especially with the 5speed, you just have to know how to work the gearbox.
  8. Dec 15, 2010 at 12:19 PM
    RobZ71LM7
    Did some looking around on Toyota's website and as I see it the 4x2 Automatic and 4x2 Prerunner use the same rear end gear ratios (3.58) and same tranny but have 215/70/15's and 245/75/16's respectively. I don't know how the gear ratios in the 5-speed manual versus 4-speed auto compare, but considering they run the same rear end gear with tires over 3" different in OD I would assume a jump to 225/75/15's shouldn't cause much difference.
  9. Dec 17, 2010 at 5:29 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I went with 235-70-15s and am very happy with the change. It has much more control in a crosswind and the back end does not try to step out like it did with the smaller tires. My speedometer and GPS now agree and the truck looks much better with the bigger tires.
  10. Dec 17, 2010 at 9:41 AM
    RobZ71LM7
    Are they on factory wheels? If so how do they fit on a 6" wide rim? That's also a size I'm considering.
  11. Dec 17, 2010 at 9:47 AM
    05RedTaco
    Tony
    Scottsdale
    I run 31x10.5x15's on stock 5lugger wheels...
  12. Dec 17, 2010 at 12:32 PM
    Yota Newb
    Yota Newb Well-Known Member
    Bryan
    Indiana
    2010 5-Lug Regular Cab 2.7L 5 Speed
    215/75's will fit no problem at all. IMO, 235/75's are perfect for a non-lifted 5-Lug. Like WhiteTaco said above me, even 31/10.5's will even fit, I honestly think it's a little too much tire for the stock wheels just because of the lack of backspacing, but they look a hell of a lot better than stock 215 Dunlop craps they put on at the factory.
    I plan on getting some fairly aggressive 235/75/r15's when I have the money.
  13. Dec 17, 2010 at 12:45 PM
    JDCPA
    Jim
    SW FL
    I mounted them on the stock wheels without any problem. They are the largest that is recommended on a 6 inch rim. Toyota says a 31" tire will fit on the stock rim without clearance problems on an unlifted truck. I have had no problems with my 235s.
  14. Dec 17, 2010 at 2:05 PM
    05RedTaco
    Tony
    Scottsdale
    My 31's rub at full lock. And yes 31's on 6" wide rim are NOT ideal, but they fit :eek:
  15. Dec 17, 2010 at 9:36 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Incorrect.
    The 5-lug manuals have 3.31, 5-lug automatics have 3.58.
    The 4cyl 4wd/Prerunners have 4.10 and the 6 cyl 4wd/Prerunners have 3.73
    X-runners have 3.15
  16. Dec 18, 2010 at 5:07 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    According to the 2011 Tacoma sales brochure that the dealer gave me 4 cyl automatic trans Prerunners have 3.58 along with 5 lug 4 cyl autos. 5 lug 4 cyl manual trans 3.31, all 4 cylinder 4x4s have 4.10s, all V6's except X-runner 3.73, and X-runners are 3.15. And unfortunately there is no manual transmission Prerunners in 2011. Take this info for what it is worth as there can be typos.
  17. Dec 19, 2010 at 9:44 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    i'm pretty sure your right, as before all 6 lug 2TR trucks had the manual, with a 4.10 final drive, but for the new 6 lug 2TR with autos toyota threw in the 3.58 the 4x4 2TRs still have the 4.10, according to the toyota website.
  18. Dec 21, 2010 at 3:12 PM
    RobZ71LM7
    That's exactly what the Toyota website says for '11 Prerunner 4cyl auto's.
