$218 to 'program' new TPMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dawhoo, Aug 11, 2016.
  1. Aug 11, 2016 at 9:15 PM
    dawhoo
    dawhoo [OP] Well-Known Member
    James Island, SC
    19 Tacoma DCLB TRD OR Cement - 18 TRD Pro 4 Runner Black Midnight
    Tacoma 17 SEMA Grey with KO2 255/75/17
    Went into the dealership to get the TPMS registered with the new truck. I had steel wheels and went to allows and bought new sensors on eBay.
    Arrive at the dealership and they tell me $218 to program the new sensors - wth!?
  2. Aug 11, 2016 at 9:18 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    They don't call it stealership for nothing....
    ManBeast and 2016Tacoman like this.
  3. Aug 11, 2016 at 9:23 PM
    Jake.A
    Jake.A Well-Known Member
    California
    2014 Tacoma TRD Sport
    WOW. I may be wrong, but I'm pretty sure you can take those sensors to any tire store and they will do it much cheaper than that. I had my sensors switched over from stock wheels to SCS wheels. $14 at america tire.
    arnette64 and shakerhood like this.
  4. Aug 11, 2016 at 9:36 PM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    that was to swap your sensors? He bought new ones that needed to be programmed to the truck
  5. Aug 11, 2016 at 9:38 PM
    Username:
    Username: I wear adult diapers at music festivals.
    CJ
    Pacific USA & Canada
    16 TRDS 6M w/ TRD Humidor
    "She's into malakas, Dino."
    i believe they program themselves after 20 miles of consistent speed driving.
    fwiw, if i could get rid of the fuckers and lose the dash light i would.
    SothernTaco, DaveInDenver and rhion82 like this.
  6. Aug 11, 2016 at 9:44 PM
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
  7. Aug 11, 2016 at 9:51 PM
    Jake.A
    California
    I had to have mine reprogrammed to transfer over to my new wheels, but they reused my sensors. I still wouldnt expect it to be that much regardless if they were new or not
  8. Aug 11, 2016 at 10:35 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    That's far too much - go to America's Tire if possible. They programmed mine for free when I had them mount/balance my new set of tires.
    Jake.A likes this.
  9. Aug 11, 2016 at 10:48 PM
    eon_blue
    Azusa, CA
    Pep Boys will read a check engine light code with their scanner for free in under a minute. Toyota requires you to leave your truck for an hour and charges a $125 "diagnostic fee" just to tell you exactly what Pep Boys will. Ask me how I know.
    That about sums it up.
  10. Aug 12, 2016 at 1:30 AM
    Para8291
    Para8291 Well-Known Member
    Rob
    San Antonio
    2016 Tacoma TRD Sport
    Bilstein 5100s all around, Toyo All Terrain AT II 285/70/17, Custom Car Grill, front windows tinted at 35%, door still protectors, bed Matt, tail gate lettering, center console organizer and detailed with Adam's Polishes products
    I just had new wheels and tires put on my truck. The light wasn't on and --- showed next to all my tires when I went to my tire pressure screen on the dash. Discount Tire couldn't reprogram it becuase they said the 2016 needs to be done at the dealership. Brought it yesterday, waited about an hour and it was done free of charge. Now it shows the reading for all 4 tires.
  11. Aug 12, 2016 at 4:37 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    There is a difference between proper diagnosis and some pimply faced kid telling you what code is set.
    P0300, random engine misfire. What's the problem?
    P0013 Exhaust camshaft position performance. What's the problem?
    high n mighty and adanfon like this.
  12. Aug 12, 2016 at 4:39 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    The steel wheels sensors do not transfer over to alloy wheels. I just bought FN wheel and the vendor verified that I had stock alloy wheels because if not I would need new sensors. I've heard autozone could re calibrate the sensor but idk if they can actually switch sensor types.
  13. Aug 12, 2016 at 4:51 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    And the dealer always gets it right? LOL
    They recently did a first oil change on a Tundra Pro for me. Half a quart of oil spilled on the skid plate blown all under the truck on the way home. Oil hand print marks all inside and on the hood. A 5 year old could have done better.
    thumper72 likes this.
  14. Aug 12, 2016 at 4:53 AM
    Aussiek2000
    2016 Offroad AC
    Not all dealers are equal, I'll be the first to admit that. And the kid right out of high school changing your oil isn't the one diagnosing more complex issues.
    adanfon likes this.
  15. Aug 12, 2016 at 4:54 AM
    2016Tacoman
    J
    So that's who is changing oil at dealers ?
  16. Aug 12, 2016 at 4:55 AM
    Aussiek2000
    2016 Offroad AC
    Every dealer I've ever been in has minimum wage 18-20 year olds changing oil
  17. Aug 12, 2016 at 4:57 AM
    2016Tacoman
    J
    I had them look at an engine vibration this year on a car of mine. Diagnosis came back as rear window screen wiper blade needs replacement. $89. Seriously. I was pissed.
    busticator likes this.
  18. Aug 12, 2016 at 4:58 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Do it yourself, and save. Toyota Techstream FTW!
    Simon's Mom likes this.
  19. Aug 12, 2016 at 4:58 AM
    Aussiek2000
    2016 Offroad AC
    like I said, not all are created equal.
  20. Aug 12, 2016 at 5:00 AM
    2016Tacoman
    J
    They all have issues in one area or another. There is no perfect dealership.
