'22 SR5 Long bed -- U Join Zerks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco11179, May 25, 2024.
  1. May 25, 2024 at 8:05 AM
    Taco11179
    Taco11179 [OP] Well-Known Member
    Jake
    2022 Tacoma SR5 Double Cab 6 foot bed
    I'm not finding any--- from a search online it's a mixed opinion. I don't see them. Am I just not looking close enough?
  2. May 25, 2024 at 8:08 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    mine is 2020 and doesnt have them, some were made Zerkless
  3. May 25, 2024 at 8:30 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    2019 no grease fittings here. Replaced u joint recently also
  4. May 25, 2024 at 8:33 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    the transition from zerked to zerkless was apparently not a clean one, model year wise. my guess is you don't have any on your driveshafts since 2022 is likely late enough to believe you don't. but checking is fairly easy. on both the front wheel and rear wheel driveshaft universals, look at the exterior of the knuckles. sometimes they are easy to see there. and sometime (like mine 2018) the zerks are attached to the interior of the spider (i think that is the term) of the universal. the front wheel shaft is easily rotated by hand to get a good view of things and front wheel is where you are likely to find them, if you have any at all. iirc there is a heat shield you need to remove (easy) to get to one of the front wheel universals.
    Chew likes this.
  5. May 25, 2024 at 8:50 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Chew likes this.
