22' USB-C port not charging new phone
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toothpick, Sep 24, 2024.
  1. Sep 24, 2024 at 8:20 AM
    toothpick
    toothpick [OP] Member
    Got a new phone, requires 45watt charge. The center console usb-c port won't charge it. Not trickle charge, but won't even register it. I saw it's a 3amp port. I think I need a 5amp USB-C port. I know there are work arounds and stuff, but has anyone found a 5amp/45watt usb-c port out there to swap them?
  2. Sep 24, 2024 at 9:45 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Buy a $20 charging block from BestBuy ... use it to top off the cell phone and recharge the block at night. The block is small/light to travel with you as needed.
    Also a NOCO GB40 battery boost block allows charging (need a USB-C to USB-A adapter which is cheap). GB40 supposedly jumps a battery 6 times per charge so should charge your phone in the day.
    OR ...
    Buy a 12V plug that has a 5 A port ... easy install into the stronger power source.
    OR ...
    Become an electrician and wire a new/stronger port into your truck.
    Jaragon likes this.
  3. Sep 24, 2024 at 9:58 AM
    ks9158
    ks9158 Well-Known Member
    Keith
    South Carolina
    2018 Tacoma SR5
    I have a battery pack from Amazon that works well USB-C to iThe phone can get 8-10 full charges quickly and still charge 3 drone batteries before recharging it.
  4. Sep 24, 2024 at 12:47 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Wow, that’s crazy. I have the opposite problem. When I plug in my phone, it overheats and stops charging.
  5. Sep 24, 2024 at 1:43 PM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
  6. Sep 24, 2024 at 1:49 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    try a different cord
    MannyS likes this.
