220 plug
Discussion in 'Garage / Workshop' started by tomwilson74, Oct 13, 2020.
  1. Oct 13, 2020 at 2:17 PM
    tomwilson74
    tomwilson74 [OP] Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    I have a 5,000 watt garage/shop heater in my wood shop. It was to be hardwired but I had the electrician put a plug on it and a 220v receptacle in my shop and one in the garage. That way I could bring the heater in the garage if I needed to in the winter. It only weighs about 20 pounds. Anyway, I bought a 7,500 watt heater because I need more BTU’s. Can I take the plug off the 5,000 watt one and put it on the new 7,500 one safely??
  2. Oct 13, 2020 at 2:46 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Depends on what plug you have .
    What size breaker are you using ??
    tomwilson74[OP] likes this.
  3. Oct 13, 2020 at 2:49 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    The 7500 will need a 40amp breaker. It also possibly will need bigger wire. If it's on 10g (which will power the 5kw fine) you'll need to upgrade to at least 8g.
    98tacoma27 and tomwilson74[OP] like this.
  4. Oct 13, 2020 at 3:09 PM
    tomwilson74
    Tom
    West Virginia
    Sounds like I should bring in a pro.
  5. Oct 13, 2020 at 3:25 PM
    tomwilson74
    Tom
    West Virginia
    I just went out and got some info on the wire and breaker. I have 1 30 amp and 2 20 amp breakers in my shop. The wiring has a lot of wording on the covering.
    AWG 10 CU 2 CDB with
    AWG 10 ground type NM B
    600 volts.
  6. Oct 14, 2020 at 9:12 AM
    tomwilson74
    Tom
    West Virginia
    Returned the 220 model and got a 110.
  7. Oct 15, 2020 at 9:47 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    The 110 model will have 1/2 the heat output of the 220 at the same current. If you need the extra heat of the 7500 watt unit, you went the wrong direction.
  8. Oct 15, 2020 at 11:57 AM
    tomwilson74
    Tom
    West Virginia
    I already have a 5000 watt one installed. Instead of having a contractor rewire and change the breakers for another 2500 watts (8000 btu’s), I just bought a 1500 watt. No re-wiring needed. Also it’s 5000 btu’s so I would only gain 3000 btu’s for all the trouble of bringing in a professional.
  9. Oct 15, 2020 at 12:00 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It’s a wood shop. Wood stove.
  10. Oct 15, 2020 at 12:15 PM
    tomwilson74
    Tom
    West Virginia
    It’s not big enough for a stove. I would not able to put a stove far enough away from the things in the shop to safely use it. I would love to have one but not in this shop.
  11. Oct 16, 2020 at 6:38 PM
    azreb
    azreb Geezer
    TN
    OOPS, I misread something.
