228hp vs 278hp
Discussion in '4th Gen. Tacomas (2024+)' started by DakoTaco, Aug 18, 2024.
  1. Aug 18, 2024 at 8:22 AM
    DakoTaco
    DakoTaco [OP] Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    I read that the Iforce turbo has 2 different power specs, the base model at 228hp, the higher packages, running the same motor, 278hp, more torque as well. The dealer gives hasn't any information, at least that he's willing to share. I'm assuming more boost, anybody know how much? Can I just get the base model and get a tune to get the extra power?
  2. Aug 18, 2024 at 8:24 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Be aware there are a host of other differences in the SR model (228hp) and the SR5 and up models (278hp). Chief among these differences are leaf springs in the rear rather than the coil sprung rear the higher models have.
  3. Aug 18, 2024 at 8:26 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I don't think there's an oil cooler and perhaps several other things.
  4. Aug 18, 2024 at 8:31 AM
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    The hybrid system is where the extra power comes from. Its not for better fuel economy .
  5. Aug 18, 2024 at 8:39 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    Well...
    Entry-level Toyota Tacoma models use a turbocharged 2.4L four-cylinder engine with 228 HP and 243 lb-ft of torque, while all other grades have an increased output of 278 HP with 317 lb-ft of torque. The hybrid generates 326 net combined HP and 465 lb-ft of low-end torque.
  6. Aug 18, 2024 at 8:41 AM
    ejes
    ejes Active Member
    39.16557922134366, -95.70272917750532
    Currently: 2020 Tundra, 2023 4Runner
    First I'd be finding out if the base model has the same drivetrain components to be able to handle more HP and torque, then I'd be finding out how it would affect my warranty. I don't think there would be any cost benefit to going base and then spending money to try to make it equivalent to a higher trim somehow. Seems like more of something to try on a used one that is out of warranty in several years. JM2C
    Toy_Runner, Dirty Harry and TurboDA6 like this.
  7. Aug 18, 2024 at 8:44 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    The dealer will have to change the software. And that's probably not going to happen.
  8. Aug 18, 2024 at 9:30 AM
    BabyBilly
    Billy
    2020 TRD
    It won't take long for someone to start tuning the 4th gen. VWs, BMWs, Subarus, etc do it all the time and crank up the boost
    Superdave1.0 and ejes like this.
  9. Aug 18, 2024 at 9:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    That's like buying a 60's car with a 2bbl carb and swapping over to a 4bbl and the cam that came with the 4bbl.
    Except the de-tuning in this case is done via software.
  10. Aug 18, 2024 at 9:44 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    I'm sure you're right, but I suspect that would throw the warranty in the gutter.
    Delta09 likes this.
  11. Aug 18, 2024 at 9:45 AM
    BabyBilly
    Billy
    2020 TRD
    Maybe, maybe not. I got a water pump replaced in my Golf R under warranty and it was tuned to make almost 30psi. If you're tuned and throw a rod, you may be SOL though.
  12. Aug 18, 2024 at 9:46 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Warranty in the gutter and glitter in the oil... o_O
    Sagebrush[QUOTED] likes this.
  13. Aug 18, 2024 at 11:03 AM
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    What gets me is the dealer can't tell me how the extra power is achieved, Toyota's customer service won't tell me. Driving the 3 different rated power setups I can feel the difference in the butt dyno. Looking at the base model because I can pay cash
  14. Aug 18, 2024 at 3:15 PM
    soupy1234
    soupy1234 Well-Known Member
    2024 Celestial Silver TRD OR LB
    Can't find the thread, but supposedly the SR trim has lesser cooling capacity and was tuned for reduced power for that reason.
  15. Aug 18, 2024 at 3:21 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    Software.
    vtown and SUMOTNK like this.
  16. Aug 18, 2024 at 3:55 PM
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    Wow, that would make sense if that's true and they increased the boost, that would make more heat. Thanks soupy1234, I'll see if I can find that thread
  17. Aug 18, 2024 at 4:26 PM
    ejes
    ejes Active Member
    I know the SR doesn't have the engine oil cooler as the trims above it.
    shakerhood likes this.
  18. Aug 18, 2024 at 4:28 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Are the turbo charger part numbers the same? Maybe one has a bigger turbo? That's a pretty significant power difference.
    Squirt likes this.
  19. Aug 18, 2024 at 4:38 PM
    DakoTaco
    North Coast
    2016 MGM OR Tacoma
    Another good idea, this is when the forum works right! Didn't think about that, I'll check into to see if they list anything. Thx
  20. Aug 18, 2024 at 4:45 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Nope.
    50Buck likes this.
