22re low oil pressure
Discussion in 'Garage / Workshop' started by fireturk41, Mar 20, 2015.
  1. Mar 20, 2015 at 4:55 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    2 days ago I changed out my oil pan gasket with rtv ultragrey, put in new oil(10w-30) and drove about 100 some miles, this morning on the way to work low oil pressure light comes on, oil level was good. When I idle up the light went off. Later cranked it up and the light wouldn't come on at all. Cranked it up again and the light stayed on no matter what the throttle and tried it again later and if only came on at low idle but not at high idle, oil is good coolant is good. Tomorrow I'm going to plug in a manual gauge to check pressure and then go from there. Any ideas what else it could be?
    Also the motor only has 800 miles on it
  2. Mar 21, 2015 at 4:17 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
  3. Mar 21, 2015 at 7:14 AM
    Tacoma Mike
    Southern Maine
    What was the result of your oil pressure test ???
  4. Mar 21, 2015 at 7:31 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Oil pressure is normal, noticed an oil puddle last night by the sensor cleaned it, rant it this morning and noticed it's leaking. Assuming the sensor is leaking and shorting out I am currently replacing the sensor
  5. Mar 21, 2015 at 7:45 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Bad oil switch fairly common on the 22RE.
  6. Mar 21, 2015 at 7:53 AM
    Tacoma Mike
    Southern Maine
  7. Mar 21, 2015 at 8:15 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    I was worried because the timing lined up just right with me replacing the oil pan gasket, flushing coolant, and installing a bigger oil filter.
    Plus it's a freshly rebuilt engine, less than 1k miles, I was worried the builder may have forgot an internal component
  8. Mar 21, 2015 at 8:40 AM
    Tacoma Mike
    Southern Maine
    I deal with coincidences all the time. Makes your hair stand on end.
    I was just worried you left a rag in the pan but didn't want to say anything untill you did your pressure check.
    Hope this settles the issue..
  9. Mar 21, 2015 at 9:24 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    That's what I was worried about too or that I didn't let the rtv cute enough and clogged the oil pick up screen
  10. May 18, 2015 at 12:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Rebuilt engine still using a idiot light interesting .
    I have mechanical gauges on all my engines I like the peace of mind.
