22re misfire?!?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by santa4x4taco, Jan 15, 2017.
  1. Jan 15, 2017 at 6:11 PM
    santa4x4taco
    santa4x4taco [OP] Well-Known Member
    I have a 94 toyota pick up with 22re engine. Was rebuilt a little bit ago before i bought it. Anyway noticed a small misfire but it drives completely fine. so i changed plugs and wires..distributor cap is less than 6 months old. Any ideas? Only codes that are thrown are 21 and 41..o2 and tp sensor.
  2. Jan 16, 2017 at 12:10 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    santa4x4taco[OP] likes this.
  3. Jan 16, 2017 at 12:12 PM
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
  4. Jan 17, 2017 at 1:54 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I had a 1998 with the 22RE. Unscrew the idle speed screw. Like post #3. You'll see an "O" ring. Go to the hardware store and replace it. I changed mine and it idled smoother. This "O" ring is only in contact with air so doesn't have to be fuel grade.
  5. Jan 21, 2017 at 5:26 PM
    santa4x4taco
    So i put the TPS on and adjusted timing and had it idleing at 750 per the info plate under hood..went to give it gas and nothing except a sputtering sounds, not enough fuel or air? Brought it to around 1250 rpm and was able to throttle it pretty good. The thing that is confusing me now is that it will backfire when in the 2k rpm range but WILL NOT backfire if the throttle is all the way open. Not sure what to check next. Anyhelp will be appreciate
