22RE vs 2TRFE 4 Banger reliability stats;
Discussion in '4 Cylinder' started by TacomaBuzz, Oct 19, 2011.
Will the 2TR-FE Outlast the 22RE
Poll closed Oct 13, 2012.
  1. Yes
    31.4%
  2. NO
    22.9%
  3. it's too early to tell
    45.8%
  1. Oct 19, 2011 at 9:06 AM
    TacomaBuzz
    TacomaBuzz [OP] Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Everyone knows that the 22RE 4 banger has a longstanding reputation for being the most reliable engine Toyota ever made. Will the 2TR-FE 4 banger earn The same respect ? I recently saw a 2nd gen 4 banger with 240,000 miles and still running strong, share your views/experiences on the new 4 banger vs the old!
  2. Oct 19, 2011 at 10:26 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    simple = better IMO.
  3. Oct 19, 2011 at 10:29 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    its a toyota.
  4. Oct 19, 2011 at 10:41 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Way too early to tell.
    The 22RE has been on the road for over 20 years longer than the 2TR.
    I imagine, given the way manufacturers are changing things, that the 22RE will live on to be the most dependable engine that Toyota has ever built.
    I loved it in my '85 4Runner.
    Fink
  5. Oct 19, 2011 at 10:51 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You can take it even further back to 22r carb version and 20r which are all basically the same engine with different head & bore. 20R's started showing up in 1977 or so in celicas, coronas and trucks. Too early to tell for 2trfe but not seeing it as possible for it to top the 20R or 22R/RT/RE. I flailed upon basically a bastardized junkyard 22R with no fresh internals or mercy for over 25 yrs and it was still going strong with r-12 AC when I got rid of it for the 05 back in 09.
  6. Oct 19, 2011 at 10:54 AM
    Fink
    Orlando, FL
    Very good point.
    If you are going to compare the two, you should really look at the series of engine (R vs. TR). The R-series was introduced in 1953 and the TR-series was introduced in 2004.
    Fink
  7. Oct 20, 2011 at 3:50 PM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    I loved working on the 22RE back in college. Its with the easiest 4 banger that i have ever laid hands on. the engine will last as long as the owner of ther vehicle takes good care of it. my second car was a volvo 940 and it had 280k miles on it before a bimbo totaled it... :(
  8. Oct 20, 2011 at 5:03 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I can only hope.
  9. Oct 21, 2011 at 7:20 AM
    monster38
    monster38 Member
    Michael
    I'm sure there's a lot more in common between a 22R-E and a 2TR-FE than between an R and a 22R-E.....
  10. Oct 21, 2011 at 9:08 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Too early to tell but I hope so. Got great life out of a 20R, 22R, Still have my 22RE & 2TR-FE
  11. Oct 21, 2011 at 9:23 AM
    Fink
    Orlando, FL
    I wouldn't be so sure of that, but I don't personally know.
    Regardless, one engine has been on the road for 20+ years and the other one for only ~7 years.
    Fink
  12. Oct 23, 2011 at 9:50 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Had a 22r. It has plastic guides for the timing chain that were famous for breaking. Mine did. It also blew a couple of head gaskets. Only the first one was legit. The rest were from crappy machine work on the head after the first failure. So, realistically it blew the headgasket at 150K miles and by then the chain guides were shot. After the headwork, it started loosing compression and burning oil over the next 30K miles. Might have been crappy headwork, might have been the rings, don't know.
    We have several four banger Tacomas at work. The 2rz powered one is approaching 150K, the last 2rz was 185K and counting when we sold it. The one before that burned a valve at 125K and the boss got rid of it. The oldest 2trfe has 110K on it. So far so good.
    I believe the 2rz, 3rz, and the 2trfe are all superior to the 22rs and 22res. I don't hear about crappy timing guides and blown headgaskets with them. The 22rs had both problems. The 2trfe does have more moving parts, but nobody has to add oil to any of the ones in our fleet. They go 5K miles and the stick shows full. My 22r always burned at least a quart in 2K miles. Technology has improved and Toyota has improved their 4 cylinder engines over the last twenty years or so. The four bangers have always been their most reliable engine.
    fast5speed likes this.
  13. Oct 24, 2011 at 7:45 AM
    Fink
    Orlando, FL
    How old were the trucks that the 22R's were in?
    Fink
  14. Oct 24, 2011 at 8:17 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Mine was a 1986 that I drove from 1995 till 2003. During that same time period, a company that I worked for did have a few with 300K plus on them that were used as courier trucks. I have no idea what had been done to keep them going. All our trucks at work now are 04 and later.
  15. Oct 24, 2011 at 9:22 AM
    TacomaBuzz
    CT
    I think the 2TR-FE is going to be a legend in time. I've seen some fleet 2nd gen tacoma's over 200 K miles with no issues already. The HP/gas mileage is much better too. I had an old 22RE Toyota pickup and the 2TR-FE is very impressive.
  16. Oct 24, 2011 at 9:26 AM
    Fink
    Orlando, FL
    That's something to consider when comparing the vehicles you listed then.
    A 22RE in a 1986 versus a 2TR in a 2004+. That was my only argument for it being too early to tell.
    Fink
  17. Oct 24, 2011 at 9:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    A 22RE is just an EFI'ed 22R.
    I can only hope the 2TR-FE doesn't have the Achilles heal that the 22RE did.
  18. Oct 24, 2011 at 9:35 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    im going to have to agree.
    I almost wish I had a single cab 3rz instead of my truck just due to the simplicity. I have not heard of any problems with the 3rz and its been out long enough to prove it's self.
  19. Oct 24, 2011 at 12:23 PM
    monster38
    monster38 Member
    Michael
    Yes, but when I refer to an "R", I am referring to *THE* "R" (think of it as the "1R"), not the "R series". The "R" was the first engine in the "R series", built from 1953 through 1964. The 22R was built from 1981 though 1995.
  20. Oct 24, 2011 at 6:19 PM
    joes06tacoma
    Joe
    Central Coast, CA
    So, what is the difference between the 3rz and the 2tr? Variable valve timing?
