22RE vs 2TRFE 4 Banger reliability stats;
Discussion in '4 Cylinder' started by TacomaBuzz, Oct 19, 2011.
Will the 2TR-FE Outlast the 22RE
Poll closed Oct 13, 2012.
  1. Yes
    31.4%
  2. NO
    22.9%
  3. it's too early to tell
    45.8%
  1. Oct 24, 2011 at 8:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    everything, they are completely different engines.
    only similarities are the displacement and that they're both DOHC.
  2. Oct 25, 2011 at 5:42 PM
    joes06tacoma
    Joe
    Central Coast, CA
    2tr is smoother for sure. Have to rev it up quite a bit to get over hills on the highway, but it does not seem to be stressed out when I do that.
  3. Oct 27, 2011 at 9:58 PM
    98Tacoma Fan
    98Tacoma Fan Member
    Arizona
    98 2wd extra cab sr5, 4 cyl, 5 spd
    bone stock
    I am new here and just bought a 98 2.4L Tacoma SR5 xtra cab, 2wd (non-prerunner).
    What model engine does that have ? The 22re?
    In regards to the motor that is in my truck, have they been proven to be reliable ?
    Thanks,
  4. Oct 28, 2011 at 7:41 AM
    Quick_1911
    Quick_1911 Well-Known Member
    Brad
    Georgia
    08 Prerunner
    2RZ-FE is what your truck has and they are very reliable engines.
  5. Oct 30, 2011 at 8:11 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    the 2rz can last forever if you take care of it. just change the oil and probably timing chain guides eventually. the 2rz and 3rz are simple engines and have tons of space to work around. They just don't put out a lot of hp. There is a pic floating around with a 2.4 courier truck that has 700k on it.
  6. Nov 8, 2011 at 2:18 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Still to early to tell, I only have about 12k on mine right now. It seems like a really solid motor to me and is very reliable, only thing that worries me about it is the light knocking sound it sometimes makes. I think this happens with all of them though. I always check my oil everytime before I make the trip home so it is not being caused by low oil level, it has been doing this since the day I got it too.
  7. Nov 8, 2011 at 3:09 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Mine also makes the light knocking sound when temps are <40°F.
  8. Nov 8, 2011 at 3:14 PM
    jandrews
    '09 FourDubDee TRD OR
    You'll rust out the fucking frame before you kill either engine, so it's pretty much moot.
  9. Nov 9, 2011 at 9:14 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    a 22r will last forever..just long as you check valves and keep up with oil changes.
    2rzs will last forever..long as you check for misfires(common for them)..
    2tr..idk..too new of an engine to tell
  10. Dec 7, 2011 at 2:53 PM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    Almost every 22re owner i've met loves their motor, but they have also had head gasket and timing chain guide issues. Which makes me question why they love them soo much...
    I have never had one and don't plan on it as they're under powered for most apps and technology has allowed for better more efficient options.
    My 2rz feels ballsy for having 31" tires and i love it.
    I did have to replace two shrunken valves at 135k and ended up doing a complete head re-build at the same time. That was the result of a friend who towed a bass boat through the hills (on 31" tires and stock gearing) with it while having a cracked exhaust header for several years, so not the motors fault in my opinion.
  11. Dec 7, 2011 at 3:03 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    22RE timing chains 150K fairly common the older double roller chains (20R) would out last the engine. My old 97 had 248K on it when I sold it never had so much as the valve cover off of it. 2.7 has a lot more power then the 22RE and as far as I'm concerned I'll vote for the 2RZ.
  12. Dec 8, 2011 at 8:18 PM
    98Tacoma Fan
    98Tacoma Fan Member
    Arizona
    bone stock
    Sorry, It has been a while for me to get back to the computer. I am loving driving my 98 for sure. It does sound like I have a valve noise when it is at idle etc. When I am driving it is quite and sounds normal, just at idle it sounds like a bit of valve chatter etc. How do I identify if the valves need to be adjusted? And also how would I identify that it was "misfiring" etc?
    Thanks very much for your feedback.
  13. Dec 13, 2011 at 4:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    The valve train noise is a standard feature (comes with the motor :) ). Your CEL should illuminate if you indeed have a a misfire at which point you should get a P0300 - P0304 code. 300 = multiple misfires. 301 - Number 1 cylinder. 302 = Number 2 cylinder; etc, etc.
    Adjusting valve on an R series motor is different than a RZ series. The R has a set screw with locking nut type design which can be done without removing components (other than valve cover of course). The RZ series is a shim and bucket design and isn't so easy to adjust.
    Here's how.
  14. Dec 13, 2011 at 5:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    My first one had the timing chain rub through the timing chain cover and into the water pump channel. It sprayed the coolant onto the timing chain and into the oil pan. I drove it 30 miles with the temp needle pegged and another 40 to get back home. Each time I let it cool down and it fired back up with out an issue even with a lot of water/coolant mixed with the oil. I was young and dumb at the time and didn't have a lot of wrench time under my belt. I thought it was the HG at first, but all of the shade tree tests came up negative. Not once did I check the oil. It was when I hooked the garden hose up to the flush kit and turned it on (with the valve cover off) that I saw the water hitting the chain.
    So I tore the top end off, replaced the timing set, HG, had the head checked (just needed shaved) and valves done, drained the chocolate milk out of the pan, and slapped her back together.
    She ran a little rough when I first started her back up but she smoothed back out over time and a few oil changes.
    That's why we love them. They're "little engines that could".
    Oh and the root cause; the plastic timing chain guide broke.
  15. Jan 7, 2012 at 6:21 PM
    #35
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    As an owner of both engines, I can say yes the 2TR IS proving itself worth of reputation along side the 22RE. I love both my four bangers. My 22RE has been rebuilt once, and that was at the 385,xxx mile mark. My 2006 has 64,xxx miles on it, and has yet to let me down. While I haven't broke the the 100,000 mile mark on the 06 it is showing no signs of slowing down, and neither is the 88. Once more demand for parts comes for the 2TR they will be the future of sought after engines just like the 22RE :D
  16. Jan 17, 2012 at 7:08 AM
    #36
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I ran a 94 pickup with a 22R-E new to 220k miles and NEVER took off the valve cover or touched the engine aside from spark plugs, wires, cap and coil...
    I don't know how much more reliable one can get than that...
    Howard
  17. Jan 17, 2012 at 9:45 AM
    #37
    muleyhunter
    muleyhunter Git-r-Done
    Trevor
    Logan Utah
    07 2.7L 4x4
    Afe Pro dry cold air intake, lce header, dynamax super turbo muffler, scangauge II booming stereo
    Amen to that. it appears they have fixed the few notorious kinks from the older motor. So only time will give them a reputation. When these motors finally gain their reputation for lasting forever we will be taking polls on wether toyotas next generation four banger will be as reliable as the 2tr
  18. Apr 3, 2012 at 8:33 AM
    #38
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Just about anything will last a long time if well cared for. Yes Toyota 4-bangers have a long reputation for reliability and durability but also I've seen many Ford Escorts and Chevy Cavaliers with 300k miles+ on them. The highest-mileage motors seem to be driven a ton of miles in a relatively short period of time, meaning they don't sit around and get old racking up only 30 or 40 miles per day. The highest milers are typically driven a hundred or more miles a day and have hundreds of thousands before they turn 10 years old. And they always get regular maintenance :)
    That's a long time between oil changes and air filters! LOL... I kid. :p
    Great to hear about such a trouble-free and user-friendly experience.
  19. Apr 4, 2012 at 8:18 AM
    #39
    87xjmike
    Folsom
    98 5lug 2rz
    So true
    Well i went against my better judgement and bought a truck last week with a 22re that i couldn't pass up.
    Its a 91 with only 150k and i've never heard a louder running motor:(
    I just ordered a whole timing chain kit with a metal guide from engbldr.com and a RV cam. Hopefully after that and a rocker arm adjustment it will quite down and run trouble free for another 150k.
    It has decent power though for 31's, aint no 2rz but it's tolerable. Definitely need to re-gear.
  20. Apr 10, 2012 at 7:29 PM
    #40
    HedgehogOutdoors
    HedgehogOutdoors Well-Known Member
    CT
    '98 4runner SR5
    I was asking the mechanic about getting a Tacoma, with a 4banger. I would love a truck with a 22r, but my dad won't let me get anything that old (but there is one exception if they decide to sell.) He told me that the 3.4 was probably the most reliable engine Toyota ever made, which I knew has to be wrong. Wouldn't the 22r(e) be more reliable? I don't know much, and he's a Toyota employee so I didn't question him haha.
