22re weak or normal ?
Discussion in '4 Cylinder' started by halogene, May 14, 2013.
  1. May 14, 2013 at 6:33 PM
    halogene
    halogene [OP] Member
    Canada/Quebec
    89 tacoma xtracab
    lift kit 3po front 2.5 rear 31po offset tire & rim
    i am wondering if my 22re in a 89 toy pickup (Xtracab) 186 000 Km not miles is weak or it is made like this. under 2700 rpm on the 2 speed ..(sorry my bad english guys.) it is so weak it take like 20 secs to go up in rpm on a small hill really small hill like 5 degree angle hill. compared to my toy celica Gt 1.8 .. i looked at the specs 22re 98hp if i remember well and vvti 1.8 is 142. there is a huge difference on de pedal is that normal ? i never had a 22re re befaure this is my first toy pickup. if you need know more information ask it. i had in mind that probably O2 sensor was fucked up or something ? thanks you!
  2. May 15, 2013 at 12:34 PM
    halogene
    Canada/Quebec
    89 tacoma xtracab
    note: i have 31 inch tire offset
  3. May 20, 2013 at 3:50 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Is 31 inches larger than the stock tire diameter? If it is, then the higher gear ratio is helping to make your truck sluggish. My 2012 truck came with big heavy 245/75/16 tires. When I went back to the stock diameter 235/60/16 tires, it really perked up. :)
    I used to have a 1988 longbed and loved its simplicity and utility. :)
  4. May 21, 2013 at 5:25 PM
    halogene
    Canada/Quebec
    89 tacoma xtracab
    yeah i may not help i think there was 28 inches tire stock they are larger and bigger i should compare with a other 22re pickup
