22x9.5 on a 255?
Discussion in 'Wheels & Tires' started by HSG100, Jun 16, 2009.
  1. Jun 16, 2009 at 5:38 PM
    HSG100
    HSG100 [OP] Well-Known Member
    Vancouver, B.C.
    05 Access Cab SR5
    The 255 tires are made for 9" wheels, but i've been told you can put 9.5" wide wheels on a 255 no problem. Do you think i could. Also would it be possible for 8.5" width on a 255?
  2. Jun 16, 2009 at 5:43 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    not sure I follow, but i think your best bet is to go on the manufacturers website and see what size rim you specific tire is designed for. Each tire is somewhat unique in size
  3. Jun 16, 2009 at 5:45 PM
    HSG100
    Vancouver, B.C.
    05 Access Cab SR5
    A 9.5" wheel is made to fit 265. I'm getting 255/35/22. But i just wanna make sure it fits fine. 255 is 10.4 inches wide and a 265 is 10.4 inches wide.
  4. Jun 16, 2009 at 6:02 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I think Tacoma stock wheels are 7.5" wide and a 265 Tire on them... So 255 tires with a 9.5" wheel might be kinda awkward.
  5. Jun 16, 2009 at 6:12 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    x2 it would be oober awkward....but then so is a 255/35/22 to begin with
  6. Jun 16, 2009 at 8:27 PM
    HSG100
    Vancouver, B.C.
    05 Access Cab SR5
    Mines a 5 lug its a 215/70/15. so 215 to 255 mm.
  7. Jun 17, 2009 at 7:16 AM
    LiftedForLife
    LiftedForLife Active Member
    Massachusetts
    09 TRD DoubleC SB
    You will hate that combo. I did that on an S-10 I had, I really wanted to put 22's all the way around. It looked cool but the ride was horrible and you have to watch out for every bump in the road(I didn't run it for that long). I ran a Nitto 555 with the rim guard just to get the tire to meet the face of the wheel and even then it looked like the tire was stretching to meet the rim width. The minimum you should go with on that size wheel is a 265.
  8. Jun 17, 2009 at 7:34 AM
    bennyzil1022
    bennyzil1022 Member
    Benny
    Sacramento CA
    99 Tacoma
    why 255? isn't that way too narrow for 22"s? i thougth about the same size wheel but in a 285. although this will be a very rough and sensitive ride, not to mention all the punishment to your brakes.
