23 battery disconnect
Discussion in '3rd Gen. Tacomas (2016-2023)' started by junkyardyote, Apr 26, 2025.
  1. Apr 26, 2025 at 7:40 AM
    junkyardyote
    junkyardyote [OP] Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    I need to pull my battery in my 23 TRDOR to service it.With my 10 I remember it acting funny,running rough. Any special way I should do this? Thanks
  2. Apr 26, 2025 at 7:44 AM
    DesertIceCap
    DesertIceCap Well-Known Member
    Gasoline Forever
    Loosen the battery cables
    Take off the negative cable
    Take off the positive cable
    Take battery out
    Chew likes this.
  3. Apr 26, 2025 at 8:02 AM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    Curious why you are servicing your 2023 battery?
    Chew likes this.
  4. Apr 26, 2025 at 8:04 AM
    Bishop84
    Bishop84 Well-Known Member
    When cars age, the throttle body gets dirty from reciculated gas/carbon deposits. So when the battery is disconnected and reconnected the idle takes time to learn.
    Cleaning the throttle on older cars negates this. Your 23 should be ok.
    The one thing that helps prevent this and radio issues is, dont turn on the truck right away.
    Reconnect the battery, don't touch the brake pedal, push the start button twice and let the radio boot. Then start it. This gives the throttle a second to see where its zero is, and lets the radio boot without being interupted.
  5. Apr 26, 2025 at 8:54 AM
    junkyardyote
    Starting to get a bit of corrosion on the terminals and hold down. Going to get that stopped now.
  6. Apr 26, 2025 at 8:55 AM
    junkyardyote
    I will do it,thank you
