23 TACOMA POWER STEERING PUMP REPLACED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mootiger49, May 14, 2025.
  1. May 14, 2025 at 8:13 AM
    mootiger49
    mootiger49 [OP] It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    So I noticed a fluid leak while changing my oil, I believed the techs who did my last dealer oil change must have not tightened something correctly. so I did the oil change and took my time, making sure everything was perfect.
    Cleaned up the undercarriage of the fluid that was there and buttoned her up.
    The next day the fluid had come back I wasn't sure what was going on.
    I scheduled an appointment with the local dealer and after inspection they said I needed a new power steering pump.
    luckily this happened still under warranty and its supposed to be back to me today.
    Never heard of this failing before but i'm glad its covered.
    Jakerou and Tcoma16 like this.
  2. May 14, 2025 at 8:23 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Most likely a timing cover leak and not the PS pump. The TC leak drips off the bottom of the PS pump.
    jmneill likes this.
  3. May 14, 2025 at 8:38 AM
    mootiger49
    what causes a timing cover leak on a truck with 25k?
  4. May 14, 2025 at 8:40 AM
    airforceb2cc
    Don
    KCMO
    Search it on here...very common on the 3.5L. Not so much in the newer years but the 16-19 was VERY common within the first oil change time. Essentially, improper or inferior RTV sealant around the timing cover caused oil to seep.
  5. May 14, 2025 at 8:41 AM
    Tcoma16
    Tcoma16 Galatians 2:20
    California
    2016 TRD Sport
  6. May 14, 2025 at 8:48 AM
    mootiger49
    The service department just called me and said that its 100% a power steering pump leak and that it is not the timing cover.
    they supposedly checked that and that it is not the issue.
    I can only hope
    anything I can do to protect my self in this matter?
  7. May 14, 2025 at 8:49 AM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    last model year of the mighty 3rd gen and you have a major problem.. well dang :(
  8. May 14, 2025 at 8:49 AM
    mootiger49
    Invoice states that it is leaking out of the front seal of the power steering pump
  9. May 14, 2025 at 8:53 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Hope it leaks while it's still under warranty :anonymous:
    airforceb2cc likes this.
  10. May 15, 2025 at 6:37 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    More like a part defect….and exactly why it has a warranty.
    Jakerou and Phlogiston like this.
  11. May 15, 2025 at 7:09 PM
    mootiger49
    Well
    I can confirm no more leak
    Very happy was just a bad pump
    Gen3TacomaOBX and Chew like this.
  12. May 15, 2025 at 7:58 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    part defects should be just about nonexistent, especially that it's a long running 3rd gen tacoma production lol.
  13. May 15, 2025 at 8:46 PM
    avi8or_co
    Well that being the case why should Toyota bother putting a warranty on the truck in the first place?
  14. May 16, 2025 at 5:01 AM
    yotadust
    yotadust Well-Known Member
    my 2023 SR V6 steering seems to have gotten a lot stiffer of the past 2 years. But the PS fluid tank level has always been good. Did you experience the same with your issue or was the fluid level low in the tank because it leaked out?
  15. May 16, 2025 at 5:40 AM
    mootiger49
    honestly..... I never checked the levels.
    as soon as I saw fluid under the truck I brought it in.
    seemed to be driving fine.
    there was not much on the ground under the truck,
    it was on the chasis from driving under power.
    yotadust likes this.
  16. May 16, 2025 at 12:27 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    i’m never mentioned anything about factory warranty. have no idea what it has to do with my original post.
