23 Tacoma whining/ howling starts around 28mph at between 1000-1500 rpm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco-everyday, Jun 14, 2024.
  1. Jun 14, 2024 at 8:44 AM
    Taco-everyday
    Taco-everyday [OP] Member
    23 Tacoma SR
    Just got a 2023 Toyota gold certified Tacoma sr 4x4 v6 with 8000 miles on it. It starts around 28mph at 1000-1500rpm. Ac is off and running the stock Firestone destination tires. Link the video with noise. Couldn’t figure out how to post the video here. https://www.reddit.com/r/ToyotaTacoma/s/AuOh2Mvdsx
  2. Jun 14, 2024 at 8:47 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    probably the rear differential, many do it. Mine is faint, and I elected to leave it, rather than having the dealer techs monkey with it. I'd rather have an OE with a faint whine, then a hacked up rear axle.
    My GF's 4R does the same.
    jmneill likes this.
  3. Jun 14, 2024 at 9:14 AM
    Taco-everyday
    23 Tacoma SR
  4. Jun 14, 2024 at 9:17 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    mine whines as well , the engine also ticks . Some 3g tacoma characteristics unfortunately. I think you ll get used it . I forget about the noise until someone brings it up
  5. Jun 14, 2024 at 9:24 AM
    Taco-everyday
    23 Tacoma SR
    Does yours make the same noise as mine in the video? Just trying to get peace of mind or find a day to take the hour drive to the dealership
  6. Jun 14, 2024 at 9:24 AM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I changed the rear to Amsoil gear fluid and it helped mine some.
  7. Jun 14, 2024 at 9:39 AM
    Blak Shinobi
    taco
    n/a
    i would get it checked out but yes mine makes that similar sounds since day one , i had my truck for 4 years
  8. Jun 14, 2024 at 10:22 AM
    longspur
    longspur Well-Known Member
    Tim
    Western Ky.
    2015 extended cab 4x4 4cyl 5 speed
    In March I bought a used 21 with 30,000 miles. It has a very distinct whine starting at 20mph that continues till other road noise drowns it out. It’s still under warranty but I wouldn’t buy it till they certified it, so I’m covered for awhile. Took it in last month for them to look at and have a new differential ordered. This isn’t the same howl that my other 3rd gen had, sounds like a bearing is going out.
    This is my 4th 3rd gen Tacoma and the other 3 had the rear diff replaced under warranty also.
  9. Jun 14, 2024 at 2:51 PM
    Mexmeno
    Mexmeno Well-Known Member
    Ontario Canada
    23 TRD Off-road
    I’ve had 6 brand new 3rd generation Tacomas and every one has had a whine usually at about 80-90 km per hour. Totally normal, it’s not the rear differential but some kind of frame resonance noise at certain speed.
    jassco, FunknNasty and BUZZCUT like this.
  10. Jun 14, 2024 at 2:52 PM
    Blak Shinobi
    taco
    n/a
    you had 6? one for every year
    Chew likes this.
  11. Jun 14, 2024 at 2:58 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Amsoil 75-110 and a slight whine. I have ignored it as no other issues when I changed the diff fluid out at 25k when I bought it last year. Already have 33K on it and I tow with mine. Drain plug was clean when I pulled it out at the change.
  12. Jun 14, 2024 at 3:46 PM
    longspur
    Tim
    Western Ky.
    Yea this 21 does have a bearing going out. After I got it home, changed to gear oil and might of drained out 1 quart. Assuming it come that way from the factory because the fill plug had never been broke loose and was serviced everytime at the dealer.
  13. Jun 14, 2024 at 4:06 PM
    Mexmeno
    Ontario Canada
    23 TRD Off-road
    Not quite, missed the 2017 and 2019 model years.
  14. Jun 14, 2024 at 6:19 PM
    InThePlains
    InThePlains Well-Known Member
    At 30k miles, I drained the rear diff fluid because of the whining noise, which dealer "checked" and told me it's normal.
    It was 1 full quart short of from the factory.
    I refilled with some Castrol with LSD additives, the noise is 90% gone.
  15. Jun 14, 2024 at 6:24 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I would take it in…take advantage of that warranty
    t0p_d0g, FunknNasty and Stevie17 like this.
  16. Jun 14, 2024 at 6:47 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    OP, I listened to the video and I don’t hear anything abnormal.
    I would take it in and have the dealer check it out for peace of mind.
  17. Jun 15, 2024 at 12:46 PM
    Nordicbeast
    Nordicbeast I wanna be sedated...
    '23 TRD Pro 6MT
    Whew....thank God I'm not the only one who couldn't hear it. Curse my old ears dagnabbit!
    I get an intermittent....what I would call, faint howl once in a while. In any other truck I would've thought the rear end bearings were on their way out but apparently normal on a Taco.
    t0p_d0g[QUOTED] likes this.
  18. Jun 15, 2024 at 1:00 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I hear it slightly. My ‘23 rear end whine is at 50-55mph and louder exactly as the TSB calls out. Seems kind of slow to trigger the harmonic resonance in these diffs, no?
  19. Jun 15, 2024 at 1:32 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I can barely hear anything in that vid.
    Funny I was considering making a similar post, I tried to deep dive into this yesterday and got nowhere.
    I couldn’t hear anything until I installed a BAMF rear diff skid plate then I could hear a cyclical/rotation kind of noise at 22mph (like a bearing going bad).
    Not a howl as others have had and never found an example of that howl to compare.
    Parked on flat ground, blocked the front tires, used the floor jack under the diff skid to hold the rear tires in the air (jack stands too), had to long press the trac-off to disable it and “drove” in place at 20-25 mph and could hear it. (I should have filmed it).
    Took off the tires, had a neighbor “drive” it and it sounded loudest at the right rear.
    He crawled under and felt around and he thought the diff skid was the source.
    The floor jack was supporting all of the weight via the diff skid.
    I loosened all the bolts and retightened pretty damn tight….and no difference, same sound.
    Not sure what to do at this point. Maybe take off the skid and see?
    My thought is that the skid is like cupping your hand to your ear and directing the sound and making it more noticeable?
    edit-
    Also last year I mounted my GoPro on the diff and drove around and you can hear the sound, a bit different than putting the phone on the rear seat.
    The oil only has 10k on it.
  20. Nov 13, 2024 at 7:46 AM
    TRD_0ffRd2017
    TRD_0ffRd2017 Well-Known Member
    2017 White Tacoma TRD OR
    Fox Performance Elite Series 2.5s Camburg Billet UCAs 700lb. 14” springs (front) Icon AAL leafs Pinch weld body chop Steel Front and Rear bumpers Warn Evo winch
    Anyone have a thought on this sound? https://youtube.com/shorts/trrIyIOanRk?feature=shared
    2017 4x4 TRD Offroad - 110kmiles
    Installed brand new front rotors and pads, checked and replaced all of my idle pulleys and serpentine belt. There’s no play in the wheel movements vertical or horizontal when checking the wheel bearing. I’m kinda losing my mind trying to figure this out, short of taking it to a shop. Any ideas?
