235/75/15 help
Discussion in '5 Lug' started by adam2180, Jan 1, 2012.
  1. Jan 1, 2012 at 3:13 PM
    adam2180
    adam2180 [OP] Well-Known Member
    Dartmouth NS Canada
    2010 SR5 Double Cab
    First post! I was thinking of putting some 235/75/15's on my 2011 5lug access cab. I was wondering if it will affect the MPG or acceleration. Would I get any rubbing with this size tire?
  2. Jan 2, 2012 at 9:32 AM
    HypnoTaco
    HypnoTaco Well-Known Member
    Bay Area, CA
    2011 Tundra DC 4x4 4.6L
    Your mpg and acceleration will go down a tiny bit, but nothing drastic. Also, that size won't rub, an issue you wouldn't encounter unless you decide to go with 30x9.5 or bigger.
  3. Jan 2, 2012 at 9:42 AM
    FIANCE FARRAR22
    FIANCE FARRAR22 Member
    MISSISSIPPI
    2.7L TACO
    SOUNDSTREAM FLIP OUT SCREEN, PACER SOFT 8 WHEELS, 235/75/R15 FIRESTONE DESTINATION AT
    I just put Firestone Destination A/T 235/75/r15 on my 2006 5 lug and 15" pacer soft 8 and i had to do a black box mod do to a descent amount of rubbing
  4. Jan 2, 2012 at 9:55 AM
    HypnoTaco
    Bay Area, CA
    Yeah, going to a different wheel will definitely change things in terms of rubbing. But with the stock wheels, a 235/75r15 wouldn't rub.
  5. Jan 2, 2012 at 2:22 PM
    FIANCE FARRAR22
    MISSISSIPPI
    2.7L TACO
    Not 100 percent sure but it should if not the black box mod took all of 5 minutes to do
  6. Jan 2, 2012 at 2:43 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    Thanks guys, its my daily driver so low MPG is a big deal for me. I think I'm going smaller. Maybe 215/75/15 or 225/70/15.
  7. Jan 2, 2012 at 3:52 PM
    HypnoTaco
    Bay Area, CA
    The mpg drop on mine was maybe 1-2mpg max, but I hear ya, in this economy you got save the $ where you can.
  8. Jan 2, 2012 at 5:44 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    Maybe 225/75/15...
  9. Jan 2, 2012 at 5:50 PM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    Good choice!
    I run the same size, click the link in my sig.
    City traffic effects the MPGs more than the slightly larger tire does. It looks a ton better than the stock 215/70's and fits a bit better in the wheel wells.
  10. Jan 5, 2012 at 1:48 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    I run 235/70/15s with no rubbing. It also made my speedometer agree with the GPS. They look much better than stock and the truck is much more secure in all handling situations.
  11. Jan 5, 2012 at 2:14 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    I'd love to see the 235/70/15's
  12. Jan 5, 2012 at 6:11 PM
    hammerman
    hammerman Well-Known Member
    ohio
    2012 access auto pyrite
    if you check dimensions the 225-75 are little taller than 235 -70s so i went 225 -75 -15 on my12.was afraid of going 235 -75 for torque reasons and i know it wouldn't be much.
  13. Jan 6, 2012 at 9:02 AM
    HypnoTaco
    Bay Area, CA
    Here is my 5-lug with 235/70R15 Yoko Geolandar AT-S
    And Here is it with the updated 235/75R15 General Grabber AT2 I switched the yoko's for.
    Hope it helps
  14. Jan 6, 2012 at 11:22 AM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    Love the truck, Tires look appropriate for wheelwells, especially with the 235/75/15's
    Did you not like the Geolanders AT-S's?
    Motoretro
  15. Jan 6, 2012 at 12:24 PM
    HypnoTaco
    Bay Area, CA
    Thanks Motoretro:D
    Well, I liked how the geolandars performed on the street, but after getting that size of tire I regretted not just getting the 235/75R15's from the start. Luckily the yoko's have a 30 day test drive warranty, so I was able to exchange them for no penalty. But they didn't have any geolandars in 235/75 so I opted for a different more aggressive tire. The Generals are great tires, and I am very happy with them so far. For what its worth though, the yoko's are great tires as well with really good on pavement manners.
  16. Jan 6, 2012 at 5:08 PM
    motoretro
    Michigan
    Hypno,Thanks for the info.
    Motoretro
  17. Jan 26, 2012 at 12:46 PM
    adam2180
    Dartmouth NS Canada
    2010 SR5 Double Cab
    So I went with 225/75/15. Im happy with my choice.
  18. Jan 28, 2012 at 8:36 AM
    Blackcat10
    Blackcat10 Well-Known Member
    Just a FYI for all fellow 5 luggers. Streetside auto is selling Bushwacker Pocket Flares For $341.95 when you use Smartshopper cupon code. And no tax with free shipping.
    Just received mine yesterday. And if you are told they will not fit a truck without OEM flares. I researched it with Bushwacker and they say they will fit but it has to have a 6 foot bed. They will not fit a short bed.
  19. Jan 29, 2012 at 7:03 AM
    Thorpedo26
    Thorpedo26 Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    Random ^ but thanks might check it
  20. Jan 26, 2018 at 11:18 PM
    O2tahcoma
    O2tahcoma New Member
    Golden taco
    First timer here, I have an 02 5 lug Tacoma which soon be in the shop placing 1.5" daystar spring spacers and a set of Falken 235/75 15 wildpeak A/T3 tires, hope it turns out better looking than the 205 it sits on now. Am I making a good decision?
