235/85/16 vs 265/75/16
Discussion in '4 Cylinder' started by mr_smoothhhh, Nov 14, 2017.
  1. Mar 30, 2018 at 8:09 PM
    #41
    LittleLady808
    LittleLady808 Well-Known Member
    Kauai,Hawaii
    2013 Prerunner SR5 2.7l
    I like the wider stance and I’m gonna try and see if it’ll be ok with my 1.25” spacers! I ordered them but they aren’t in yet. I’ll post picks as soon as they are installed. :D
  2. Apr 4, 2018 at 10:53 PM
    #42
    LittleLady808
    Kauai,Hawaii
    Finally got my KO2’s in and installed! Love it! So far so good and I love the stance. I’m very happy I could leave the spacers on and they didn’t stick out too much! Fills up the fender well very nicely! :DCB15E992-1CCD-49BD-8AAB-B322E4B7BCA1.jpg7D40E30E-53E8-4C1C-AB49-4CFD84467D7E.jpg 287539AD-42B9-48B6-8C09-418BAA7C36D5.jpg
  3. Apr 4, 2018 at 11:17 PM
    #43
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    That looks awesome!
  4. Apr 4, 2018 at 11:28 PM
    #44
    LittleLady808
    Kauai,Hawaii
    Thanks! :D
    irayfz6[QUOTED] likes this.
  5. Apr 26, 2018 at 2:05 PM
    #45
    fs007
    fs007 Well-Known Member
    06 AC 4x4 4cyl
    IMG_4330.jpg 235 falken wild peaks on KMC enduros....
  6. Apr 27, 2018 at 3:06 PM
    #46
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    They look bigger than that...maybe it's just the angle
    fs007[QUOTED] likes this.
  7. Apr 27, 2018 at 3:07 PM
    #47
    Nomad_Pilot
    Clay
    Ft Collins
    Omg omg omg that's what she said!!! Hahaha yes!
    fs007 likes this.
  8. Apr 27, 2018 at 5:22 PM
    #48
    fs007
    06 AC 4x4 4cyl
    Haha you beat me to it...
    And they do!! I actually had to do some trimming in the front...my fender rubbed when the wheel was fully cranked and I as in reverse! But nothing a heat gun and a dremel couldn’t fix....if you think they look big here...check this one out0D33EDE0-7434-40EA-B462-9D4345C186EF.jpg1015498A-5933-41A7-B3E2-4BE62B8275F3.jpg
  9. Apr 27, 2018 at 8:17 PM
    #49
    Thulsa Doom
    Thulsa Doom Well-Known Member
    Manderthal
    Rhode Island
    2012 Tacoma regular cab 4x4 automatic
    Is that stock suspension?
    fs007 likes this.
  10. Apr 27, 2018 at 8:58 PM
    #50
    fs007
    06 AC 4x4 4cyl
    yes...yes it is. OME is the plan when funds become a thing again, but it'll stay like this for a bit.
  11. Apr 28, 2018 at 9:18 AM
    #51
    Nomad_Pilot
    Clay
    Ft Collins
    I have a question. So yall hear me out. If your going with 235 and not going bigger (that's all I have) why would you put taller suspension on your truck. Other than weight carrying of course. The camel trophy rigs ran 7.50x16s, which are very close to the modern 235 85 16 I think, I and they did some downright stupid stuff if watch the videos, but there was lots of winching too. But if you lift it, is it detrimental if you don't need the lift? Or does the added traction from added flex help more than the higher cg takes away?
    fs007 likes this.
  12. Apr 28, 2018 at 9:39 AM
    #52
    fs007
    06 AC 4x4 4cyl
    I can only partially comment here, I haven’t lifted my truck and would only do it in an effort to make the truck smoother with “expedition weight”. I had a lifted Xterra for a while and while it was awesome it had a lot of drawbacks...it was a 3 in suspension and a 2 in body lift, and it was put on in order to make room for 33in tires...the problem with so much lift was the wear and tear...did ball joints several time, cv boots, power steering pump (big tires) and a bunch of other stuff...the lift let me put the big tires and have me great approach and departure angles as well as a lot more flex. With the tacoma I want something reliable so the only stuff I’d do would be as little lift as possible in an effort to improve the suspension setup..true ground Clearence is achived through bigger tires and not lift. Not sure if that’s answers your questions but it’s my two cents to lifting a truck..BF0EA448-69B4-4ECF-B6D6-E52B8325736B.jpg
    gavia likes this.
  13. Apr 28, 2018 at 12:01 PM
    #53
    Nomad_Pilot
    Clay
    Ft Collins
    I guess everything has its trade offs.
    fs007 likes this.
  14. Apr 28, 2018 at 9:22 PM
    #54
    NoFumardeEspaniol
    NoFumardeEspaniol Member
    2008 Double Cab Short Bed
    Did you have to add spacers? No issues with the calipers? I was under the impression the 16's didn't fit around the calipers.
    Looks awesome!
  15. Apr 28, 2018 at 9:57 PM
    #55
    Nomad_Pilot
    Clay
    Ft Collins
    2nd gens come with 16 inch wheels, so I am not sure what your talking about. There is a tundra brake swap the requires 17s though.
    fs007 likes this.
  16. Apr 28, 2018 at 9:57 PM
    #56
    Nomad_Pilot
    Clay
    Ft Collins
    Haha you don't smoke the spanish?
    fs007 likes this.
  17. Apr 28, 2018 at 10:24 PM
    #57
    NoFumardeEspaniol
    Sorry, I mean the KMC Enduros in 16, I've read on here that they don't clear the calipers. If they do fit, that's awesome. I'll probably look into buying a set.
    Nofumardeespaniol.... A little trick I was taught while motorcycling through Latin America. When I cop pulls you over looking for a bribe you just look at him and say "Sorry, no fumar de espaniol?" in the most gringo accent possible. He'll assume communication is a lost cause and just wave you on. Worked every single time. :)
    fs007, tacoburrito and Depoxy like this.
  18. Apr 29, 2018 at 5:55 AM
    #58
    fs007
    06 AC 4x4 4cyl
    yeah so to answer that question... they do fit. but there is NOT a lot of space...like I can barely fit my fingernail into the gap...and the hub caps i had wouldn't fit...there is a little plastic "spacer" ring that goes onto the hub to seat the wheel right and that fit...I was worried I would get rubbing on the caliper but I don't....Ill have to post a picture...my calipers are a bit rusty on top so I would have seen it by now but so far all rust is intact :) only reason i went with these wheels is cause I got em cheap of off CL...they were alloy and I wanted to offset the weight the new tires would have
  19. Apr 29, 2018 at 6:03 AM
    #59
    fs007
    06 AC 4x4 4cyl
    here is how tight the fit on these is... tip of the knife fits but thats about it..IMG_4350.jpg
    also this is what 0 offset looks like with these
  20. Apr 29, 2018 at 6:29 AM
    #60
    Nomad_Pilot
    Clay
    Ft Collins
    Holy dog crap batman your shits rusty. Glad I don't live up north
    fs007 likes this.
