235 85 16s
Discussion in '5 Lug' started by Thorpedo26, Nov 1, 2011.
  1. Nov 1, 2011 at 1:58 PM
    Thorpedo26
    Thorpedo26 [OP] Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    Any experience with these on your 5 lug? Will they fit with the fat bobs with minimal triming? I think they are similar to a 265 75 16 just more narrow if im not mistaken. Im ordering my fat bobs kit in one week, trying to figure out my wheel set up. Also need a course on wheel spacers will it be a bad choice over all to use some with the rim of my choice
  2. Dec 22, 2011 at 9:30 PM
    southern4banger
    southern4banger Member
    Below The Mason Dixon
    04 single cab base 4 banger 5 lug
    1.5" front spacers, P235 75 R15 General Grabers AT 2, JB stereo, speakers, Power Bass 10" sub
    I installed P235 75 R15's on mine 1.5" spacers in the front... not even close to a rubbing issue. The 85's will be wider than mine, but you should be fine with the Fat Bobs kit, if I'm not mistaken the 2nd Generations have slightly larger wheel weels than the 1st generations
  3. Dec 22, 2011 at 9:43 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    they should be slightly taller than the 265's but about an inch or so narrower. should bit wit the fat bobs depending on your wheel too of course. id look at wheels with an offset to avoid the wheel spacers
  4. Dec 23, 2011 at 9:30 AM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    Im kinda debating on these now, i looked at them in person. Very tall for being so narrow. kinda worry about control on the road
  5. Dec 23, 2011 at 7:49 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    id get 265s personally. my dad has them on his tundra and he hauls ass through turns and they bite pretty good
  6. Dec 23, 2011 at 9:35 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Though different, I have 235/85r16 duratrac's on my '06 4x4. It still handles great on the road, totally rocks in snow. They are only available in 10ply (rated) though, which I don't mind. YMMV.
    And, yes, they are just a hair taller than a 265/75r16, but just over one inch narrower.
