235/85r16
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nw_nomad, Feb 4, 2020.
  1. Apr 3, 2020 at 4:43 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Stock or lifted?
  2. Apr 3, 2020 at 4:44 AM
    Taco/Jäger
    Taco/Jäger Well-Known Member
    2016 Tacoma SR 2wd
    2.25” leveling in front with 1” block in rear
  3. Apr 3, 2020 at 8:09 AM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Here's my Sumitomo Encounter AT in 235/85/16 LT (load range E). It's a good Japanese brand that seems to fly under the radar. I run Sumitomo tires on all the cars in my family.
    Stock height and wheels on a 2018 OR.
    IMP595 and BravoSix like this.
  4. Apr 3, 2020 at 8:10 AM
    JNG
  5. Apr 3, 2020 at 9:37 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Stock tires were 38lb, these are 51lb. Ride did not really change, except a bit more road noise. I run the fronts at 36psi and the rears at 32psi(chalk test). MPG lost of 3mpg.
    These tires are pretty much unstoppable off road. I've never been more pleased with a tire.
  6. Apr 3, 2020 at 9:40 AM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    I might copy you.
  7. Apr 21, 2020 at 6:21 PM
    BravoSix
    BravoSix Well-Known Member
    2017 MGM SR5 DCSB 4x4
    Seat jackers, Tonneau, Toyo AT3 235 85 16.
    235 85 16 Toyo Open country at3.
  8. Apr 21, 2020 at 6:33 PM
    Justwandering
    Justwandering Well-Known Member
    1996 Land Cruiser, 2008 GX470
    235/85/16 Cooper ST Maxx
  9. Oct 9, 2020 at 5:16 AM
    muffyinva
    muffyinva Well-Known Member
    Reid
    Lynchburg, VA
    2019 Cement Tacoma DCSB OR
    Do you happen to have a pic from a little farther away? I like the look of this size tire!
  10. Aug 17, 2021 at 5:21 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    What rear bumper is this?
  11. Aug 17, 2021 at 6:22 PM
    Justwandering
    It’s a CBI T3 high clearance.
  12. Sep 22, 2021 at 2:50 PM
    Meclizine
    Meclizine Well-Known Member
    CA
    '18 DCLB OR
    I'm going to go with a set of tires in this size when my current ones are spent. It looks like ordering from tirerack.com and having a local shop do the install is the best way to get the tires I want. Has anyone gone that route and regretted it? My worry is not being able to get a decent selection just talking to a shop, and I certainly don't have the ability to mount my own tires.
  13. Sep 22, 2021 at 3:03 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I see little advantage of that size over 255/85r16.
    CherylJane likes this.
  14. Sep 22, 2021 at 3:19 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Weight. Fuel economy. Power. Just a few I can think of.
  15. Sep 22, 2021 at 3:58 PM
    #35
    SLeeper512
    SLeeper512 Well-Known Member
    Sam
    2021 SR5 DCLB Tacoma white with red topper with tow pkg
    I had them, Cooper Discover ATIII load E, on my 2015/2nd gen SR5. They did well on highways and some really nasty forest roads with lots of protruding rocks. I did lose about 2 mpg with them. I regeared to offset the sluggishness... better alternative would have probably been to keep in 4th until highway speed... no change on mileage with regear.
  16. Sep 22, 2021 at 4:34 PM
    #36
    gudujarlson
    Minnesota
    I think you are already paying that price by going to a LT tire. Also the OP said he was trying to avoid rubbing, but 255/85r16 or 265/75r16 will likely not rub either.
  17. Sep 23, 2021 at 4:03 PM
    #37
    eugenewithanaxe
    eugenewithanaxe Well-Known Member
    2017 TRD OR M/T DCSB 4x4
    Toyo Open Country AT3.
    Coming from 265/75r16 Toyo Open Country RT. AT3's weigh in at 44lbs, RT's 53lbs. I expect to see significant boost in fuel economy and apparent power. The AT3's were considerably less expensive and easier to find.
  18. Sep 23, 2021 at 4:40 PM
    #38
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Same tire in a 235/85R16 weighs in at 44lbs as well.
  19. Sep 23, 2021 at 5:15 PM
    #39
    eugenewithanaxe
    My AT3's are 235/85r16. Thought that was implied since this is a 235/85r16 thread, should have specified.
    For those curious, the SL 265/70r16 comes in at 40lbs, SL 265/75r16 comes in at 41lbs and the LT 265/75r16 comes in at 48lbs.
  20. Jul 4, 2024 at 9:20 AM
    #40
    cogsci
    cogsci Member
    2022 Tacoma SR5 Doublecab
    In the Falken Wildpeak at4s the weight difference is 3 lbs but I figured the smaller foot print would negate mpg differences, although there is a slight increase in diameter
