'24 Configurator now shows 228HP on SR Manual
Discussion in '4th Gen. Tacomas (2024+)' started by ericin1984, Apr 5, 2024.
  1. Apr 14, 2024 at 9:18 PM
    linuxpickup
    linuxpickup Well-Known Member
    2024 OR MT
    I could be wrong, but was thinking the 228 vs. the 278 difference is due to lack of a transmission oil cooler on the AT SR. The MT SR rating should be the same as the OR or Sport since a transmission oil cooler is not a factor for an MT. Whatever the underlying reason, Toyota's site definitely can't make up its mind right now on the SR MT horsepower rating depending on whether you are looking at the abbreviated or full specs. Lt. Dangle and Jeff Lange's info are what I would trust & both say 270 for the manual SR.
  2. Apr 15, 2024 at 11:47 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Gonna need bigger exhaust manifold. Nope, bigger than that.
  3. Jan 17, 2025 at 7:07 AM
    holland1
    holland1 Well-Known Member
    tacoma
    Did we ever get an answer if the manual SR has the full 270HP? Anyone drive both and able to tell a difference?
  4. Jan 17, 2025 at 5:56 PM
    bananaboat
    bananaboat Well-Known Member
    I think it's always been the case that the SR has the 228 hp engine and the SR5 has the 278 hp engine, regardless of transmission type or 4x4 vs 4x2. That's the main difference between the two IMO. The e-brochure for the 2024 shows this. A screenshot I saved from fueleconomy.gov shows one difference in the engines, that the SR5 has SIDI and PFI, a different type of fuel injection system. I'm not sure about all the changes that account for the 50 hp difference.
  5. Jan 17, 2025 at 6:37 PM
    foeix
    foeix 24 TRD OR 6MT
    This is not the case with the 4th Gen - the SR 6MT is not detuned - it has the same output as the TRD OR and TRD Sport 6MT - 270HP.
  6. Jan 17, 2025 at 6:52 PM
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    Lt. Dangle and shakerhood like this.
  7. Jan 17, 2025 at 7:39 PM
    bananaboat
    When I looked more closely, it seems like you're right. The SR/MT (appears to be available only with DC/5 ft bed/4wd) has a 270 hp engine. That must be a little different than the SR5 engine that has 278 hp.
  8. Jan 17, 2025 at 8:51 PM
    RicerRabbit
    Itz JDM tyte, yo!
    The manual engines has a tiny bit of HP loss (which doesn’t really matter anyways) due to wanting to avoid “crankshaft hammering”
    shakerhood likes this.
  9. Jan 17, 2025 at 8:56 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Lower redline, too.
  10. Jan 18, 2025 at 6:24 AM
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    Different gear ratios in the transmission and final drive, too.
  11. Jan 18, 2025 at 8:15 AM
    foeix
    foeix 24 TRD OR 6MT
    And a 9.5" rear axle standard.
  12. Jan 18, 2025 at 10:51 AM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I thought I read that the SR engine does not have the oil cooler and several other parts are not upgraded for higher output. It might be from the engineer video.
