24 ft trailer towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tbg80, Jun 4, 2018.
  1. Jun 6, 2018 at 6:50 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I monitor temps at the torque converter and have seen them reach 245 in the mountains. Since then I've installed an aux plate cooler for the transmission but haven't towed with it hooked up yet.
    lynyrd3 likes this.
  2. Jun 6, 2018 at 7:11 AM
    MakeItWork
    MakeItWork Well-Known Member
    2017 White Tacoma TRD Offroad
    Dude, that sway master looks slick. Don’t think I’ll be pulling the trigger on it this trip (renting a 24 footer in a couple weeks) because I’ll be learning and driving like a grandma, but if I ever get serious I’ll give it another look.
    OP, I’m roughly in your shoes here, first timer, about the same length/weight. I’ve added a P3 brake controller, k source towing mirrors, an ez lift wd hitch (keep in mind ordering these that bigger is not better, price is right rules: closest to rating without going over), thr BAFX Wifi OBD scanner and the OBD fusion app (keep in mind on OBD fusion you have to do another $10 in-app to get access to the trans temp monitors. Super cool app once its dialed in though).
    I bought a Timbren SES kit, but I regret that, haven’t hooked up the rig yet but I’ll be doing my best to get sag-free without the rubbers.
    Also, with the bafx, it used Wifi for the iPhone version. If you’re android get the Bluetooth. If you’re using Wifi, and you still want your phone to browse online, you have to turn off the dynamic IP address. Getting off topic, Hit me up if you need help with that.
    Good luck!
    Tatts521 likes this.
  3. Jun 6, 2018 at 7:24 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    when you haul a light long wind sail, it can be scary when a big wind hits and tosses your truck around like being on ice
    I have seen it happen in front of me a few times over the years and no one wants to lose their load this way
    lynyrd3 likes this.
  4. Jun 6, 2018 at 7:32 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Mine definitely feels underpowered when towing our 14' Starcraft, and it only weighs ~2400 lbs dry. I have a lift and 33s so I didn't expect much else, but definitely consider your current mods if you're gonna tow as well.
    lynyrd3 likes this.
  5. Jun 6, 2018 at 9:51 AM
    41magmag41
    41magmag41 Well-Known Member
    jim
    New Hamshiire
    tacoma double cab TRD 4 x 4
    Dropped my son's 3100 lb pop up on my 14 dc trd 4x4 off road with tow package and pulled it 210 miles in the mtns of New Hampshire, ie next to mt washington, and really didnt even know it was there. Towed in 4th gear the whole way and let the tranny do its thing. Couldnt ask for a better tow vehicle, and got 27.5 mpg while towing. Seems like 3000 rpm and load on her was her sweet spot.
    FJ to Taco likes this.
  6. Jun 6, 2018 at 10:34 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    27.5 mpg, you cant be serious
    tacoRenner, lynyrd3 and jpereira2 like this.
  7. Jun 6, 2018 at 10:51 AM
    TakoLoko12
    TakoLoko12 Well-Known Member
    :popcorn:
    lynyrd3 likes this.
  8. Jun 6, 2018 at 10:54 AM
    knottyrope
    Knotty
    Bahstun
    unloaded, I got about 20.1 MPG with mostly 40 mph backroads
  9. Jun 6, 2018 at 11:39 AM
    41magmag41
    jim
    New Hamshiire
    Dead serious, checked the math twice.
  10. Jun 6, 2018 at 11:46 AM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    27.5MPG? Not possible, what do average with no load?
    lynyrd3 likes this.
  11. Jun 6, 2018 at 11:50 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    You drove 210 miles with that load in the mountains and only had to put in 7.6 gallons?
  12. Jun 6, 2018 at 11:51 AM
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    Turd Gen here, but I pull a 3400# UltraLite trailer with an Eaz-lift WD hitch that has friction sway control built in. All stock except Load E BFGs and Method Wheels. I pulled it a few weeks ago fully loaded with 30 gallons of water and full gear with a cooler loaded up with beverages and 40lbs of ice.
    Pulled it from 2300ft to 7000ft and it did fine. You might struggle if you start adding more weight. I met another local with a 2015 2nd Gen and he pulls an Imagine that weighs in at 6000#. He is also Magnuson Supercharged, air bagged, and uses WD and sway control also.
    Welcome to the travel trailer life.
    lynyrd3 likes this.
  13. Jun 6, 2018 at 11:54 AM
    ejl923
    Eric
    Western Mass
    i cant get that commuting to work, nevermind towing in mountains. Heck, i towed my mothers 1600 lb popup across two mildy hilly towns and got 15. That had to be all downhill. Thats the last ill argue about it, but i just think thats not possible
  14. Jun 6, 2018 at 12:06 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    (pssssst… real tow vehicles have that system built in. Just sayin')
  15. Jun 6, 2018 at 12:29 PM
    #35
    41magmag41
    jim
    New Hamshiire
    Gentlemen the point is it happened and the math double checked. Yes on the fuel used to cover that milage. I get around 21 to 22 empty and not towing. The fact is the engines sweet spot for towing is around 2800 to 3000 rpm in 4th gear.
    This is the 3rd time I've towed with that much weight and on all 3 occasions I averaged 25.5 to 27.5 mph. That rpm range appears to be the sweet spot for my Tacomas torque and economy. Believe it or not it happened for all you arm chair mechanics.
  16. Jun 6, 2018 at 12:38 PM
    #36
    ejl923
    Eric
    Western Mass
    new mpg mod, attach 3000 lbs to your truck to increase your mileage
    tacoRenner, Pugga, lynyrd3 and 3 others like this.
  17. Jun 6, 2018 at 12:44 PM
    #37
    bimrologist
    bimrologist Well-Known Member
    Alex
    Edmond, OK
    2015 Super White DCSB TRD Sport
    Bilstein 5100's w/ OME 885's FN BFD's w/ Nitto TerraGrapplers CaliRaised 40" Flood light bar The Retrofitsource HID conversion
    im happy to get 17 with a tail wind hauling just myself in the driver's seat and a tall red bull in the cupholder!?
    lynyrd3 likes this.
  18. Jun 6, 2018 at 12:55 PM
    #38
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    by this calculation i should get like 35 mpg when towing.......instead of averaging around 10-12 for roughly 5k pounds
    jethro likes this.
  19. Jun 6, 2018 at 1:00 PM
    #39
    BlazingTaco
    Exile
    I get around 11-12 mpg. (LoL @ 27)
  20. Jun 6, 2018 at 1:07 PM
    #40
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    Just my opinion but i felt uncomfortable towing my 24 ft 4200 lb( dry weight) trailer. i had a good load leveling equalizer hitch ,a P3 brake controller, When you add your family ,your gear, your water if your going off the grid that weight can be pushing well past 5000lbs.The truck will do it but at what cost down the road. IMO that 6500 tow rating for my TRD sport truck is too much.
