24 Trail Hunter Front Brakes
Discussion in '4th Gen. Tacomas (2024+)' started by Hadelson, Jun 27, 2025 at 5:49 AM.
  1. Jun 27, 2025 at 5:49 AM
    Hadelson
    Hadelson [OP] Active Member
    Hugo
    24 Taco Trail Hunter
    8500 miles and last week both front brake pads started shifting in the calipers. Move forward and back and they clank!. They also pop and click in 4low.
    Spent an hour at the dealership. Still know resolution although as expected "heard this is normal".
    Anyone else having this issue?
  2. Jun 27, 2025 at 6:16 AM
    Surfncamp
    Surfncamp Member
    2024 Tacoma Trailhunter 6' bed
    My TH has 9400 miles. I have had no brake issues at all. Let us know what the dealership says.
    TACODOC1 likes this.
  3. Jun 27, 2025 at 6:18 AM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    TH brakes are the same as all hybrid brakes. Not many THs on the road, but a lot of hybrids and we haven't heard of any issues. Unless you think the brake problem is related to the TH's unique suspension.
  4. Jun 27, 2025 at 8:26 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    my 3rd gen did that since new. does it do it most in parking lot maneuvers ? mine was more of a click. when going from forward to reverse or back again / just slight play in the brake pads. if i remember right this style of caliper does not have stainless shims between pad and caliper so they can move a couple thousands . maybe your pads are a little to small and tolerance stacking caused them to make more noise than normal.
  5. Jun 27, 2025 at 9:35 AM
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    For what's it worth:
    These are floating calibers, there is slight movement but no sound. Most likely the pads are sticking to the caliber, or they installed the wrong size pad/caliber combo.
    [/QUOTE] They also pop and click in 4low. [/QUOTE]
    Interesting, your brakes should perform the same in 2wd, 4h or 4L...
    [/QUOTE] Spent an hour at the dealership. Still know resolution although as expected "heard this is normal". [/QUOTE]
    The technician is smoking mary-jane... Not normal. No sound should be coming for your brake system unless there is something wrong. Good luck.
