245 to 265
Discussion in 'Wheels & Tires' started by NMTrailRider, Sep 29, 2009.
  1. Sep 29, 2009 at 6:50 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    if i replace the factory 245's with 265's on my new access cab do i have to have it re-geared? is the spedometer/odometer going to be way off? will the tires rub? any thoughts would be greatly appreciated! thanks!
  2. Sep 29, 2009 at 6:52 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    theres a tire size calculator in the mod and tutorials drop down list itll give u all the info u need
  3. Sep 29, 2009 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You will be fine. Speedo will only be off about 3%
  4. Sep 29, 2009 at 7:14 PM
    NMTrailRider
    New Mexico
    which direction will the spedo be off- will it read high compared to actual or low compared to actual?
  5. Sep 29, 2009 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It will read 3% slower. It may actually be pretty close to right on, as they read fast from the factory
  6. Sep 29, 2009 at 7:37 PM
    SSrUs
    SSrUs Member
    Damascus, Oregon USA
    '09 4x4 SR5 Access Cab 2.7L M5
    3" Lift, Nasta Step Bars
    Agreed. I've clocked my odometer on the freeway and found that it's reading 4% too fast. I'm planning on getting 265/75-16's on my truck soon, and I expect that will get my odometer/speedometer reading close to right on.
  7. Sep 29, 2009 at 7:56 PM
    SSrUs
    SSrUs Member
    That depends on what wheel you use. A couple months ago, a friend of mine put Open Country 265/75-16's on his stock aluminum Toyota wheels and he has no problems rubbing.
    Yesterday I was at America's Tire. They put a 265/75-16 DuraTrac on a chrome MB wheel I liked. It looked great on the front of my truck, but it rubbed at the mudflap when the steering wheel was turned about halfway. They mounted it on a different wheel with a different offset and backspacing, and it cleared everything, but I really didn't like the wheel style. I went home with my Dunlops and steel wheels still on. :(
  8. Sep 30, 2009 at 3:10 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    No you will not have to re-gear, 265/70/16 is the stock size on the TRD OR version, so no they will not rub.
    I went from 245 to 265 and checked with 2 gps's my speedo is accurate.
    new access cab 5 lug or 6 lug??
  9. Sep 30, 2009 at 5:57 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    What wheel did it rub on?
    I was thinking about an MB wheel for mine...
