24v bulbs running on 12v system - Questions
Discussion in 'Lighting' started by cverneau, Mar 23, 2016.
  1. Mar 23, 2016 at 7:14 AM
    cverneau
    cverneau [OP] Well-Known Member
    Craig
    Cheshire, CT.
    11 Access Cab 4cyl 4x4 Auto
    AVS In-Channel Window Deflectors, AVS Rear Window Sun/Rain Deflector, EGR Front Hood Deflector, Weathertech Digital Fit Floor Liners With TRD Off Road Decals, TonnoPro Tri-Fold Cover, Coverking Black Neoprene Front Seat Covers & Front & Rear Center Console Covers, Black With Red Stitched TRD Head Rest Covers, Rear Grey Neoprene Wet Okole Seat Covers, Black Front Door Handle Pull Covers, Husky Custom Molded Mud Flaps, Devil Horns Of Fire On Satoshi, 7" Off Road Lights Mounted Behind Grill, Pop N Lock 5300, Seatbelt Chime Off, Interior & Exterior Led's, Cubby & Drink Holder Amber LED's, Infinity Reference #9633 6X9 Front Speakers, Solar-Gard HP Smoke 35% Tint, De-badged & Pinstripe Removal, Sun Visor Stickers Removed, Illuminated 4x4 Switch, ImMrYo Rear-View Mirror Lift Bracket, Ultragauge, TRD Aluminum Skid Plate, Bed Storage Cubby Locks Mod, Additional D-Rings In Bed, Rubber Bed Mat, Intermittent Wiper Stalk, Black Vinyl Arm Rest Mod, Secondary Air Filter Removal Mod, Spare Tire Rod Alignment Tube Mod, 14" Antenna Mod, Tailgate Theft Mod, DTRL Wire Jumper Mod, Parking Lights As Turn Signals Mod, Under Hood LED Strip Lighting Mod, 30 Watt Reverse Bulbs, PIAA 510's With LED's In Fog Locations, Cree LED Flood lights In Rear Bumper, Burner Bedlights In Bed Cubby's, Avid Light Bar, Horn Relocation Mod, Rear TSB Springs, Bilstein 5100's on all four corners - front set at 0.85", Cooper Discoverer ATP - 265-75R/16, Pioneer AVH-X3700BHS Head Unit With Microbypass, Added USB Charging Ports Under Dash.
    Hey all,
    I'm running PIAA 510 housings in my stock fog light locations on on a 2011.
    I've always used the 3000K H3 55W bulbs for a nice yellow color.
    The problem is the bulbs run great for about a year before burning out and I sometimes get flashed as they are very bright to look at and aren't adjustable.
    So I started thinking and looking around....
    If I used 24V H3 70W Super Bright Xenon Yellow bulbs, would it effectively cut the wattage and brightness to approximately half - say 35W in a 12V system???
    I'm thinking that the bulbs would last forever as the filament would be thicker for a higher wattage (70W) and I'd be running at half voltage(12V). I'm thinking they would also be slightly dimmer than the 55W bulbs and wouldn't blind others.
    The bulbs I'm looking at are these:
    http://www.amazon.com/Headlight-Hal...TF8&qid=1458742073&sr=8-2&keywords=s&d+h3+24v
    Is my thinking way off?? I need some electrical guru's to chime in...
  2. Mar 27, 2016 at 3:38 PM
    cverneau
    Craig
    Cheshire, CT.
    No replies???
    No words of wisdom??
    I'm very disappointed in the tribe.....
    BUMP....
