24v lighting wiring questions
Discussion in 'Lighting' started by ARC, Feb 7, 2011.
  1. Feb 7, 2011 at 5:17 AM
    ARC
    ARC [OP] Well-Known Member
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    I was able to get my hands on a set of free flood lights, yay. As my dad always told me nothing is ever free, and now I have no Idea of how to wire these into my truck. Any ideas on how I can get the need 24v to run my behind the grill lights?
  2. Feb 7, 2011 at 5:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's going to be pretty expensive to do that. You'll need a transformer or power supply that will convert 12vdc to 24vdc and have enough AMP output to support the lights. Therein lies the problem. The higher the AMP output, the more the $$$ and usually bigger the PS is.
  3. Feb 7, 2011 at 5:34 AM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    So dad was right nothing is free. Thanks for the insight.
  4. Feb 7, 2011 at 5:36 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    never seen anyone do that on here.....or anywhere for that matter
  5. Feb 7, 2011 at 5:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    LOL, judging by the OP's location and the light voltage, they are MilSpec lights.
  6. Feb 7, 2011 at 5:47 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Or you can just add a battery and wire it in series to the original one, then hook your lights to the new battery and leave all the original stuff hooked to the original battery. But it still wont be very cheap because battery wire is expensive.
  7. Feb 7, 2011 at 5:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    Good option, just have fun trying to stuff another battery in there.
  8. Feb 7, 2011 at 6:21 AM
    Southern01Taco
    Sean
    Holden, La
    Yea, if I was to do it that way I would fab up a battery tray and mount the extra on the outside of the frame under the bed. But that is where the cost comes in because I have priced enough battery cable to do this and it is nowhere near cheap.
  9. Feb 7, 2011 at 10:19 AM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    Thanks for the options. It's as I expected there is no easy/cheap answer.
  10. Feb 7, 2011 at 10:45 AM
    Southern01Taco
    Sean
    Holden, La
    Yea, if I was you I would just try to sell those and buy some good 12v lights.
    There is no need in going through all that trouble just for a couple of lights imho.
  11. Feb 7, 2011 at 10:57 AM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    don't forget that if you wire up another battery in series you will probable need to beef up your alternator...For what everything would cost to get them in there, you can get a solid pair of 12+ lights.
  12. Feb 7, 2011 at 10:59 AM
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
  13. Feb 7, 2011 at 11:00 AM
    Daudio
    North Jersey
    '02 SR5
  14. Feb 7, 2011 at 11:20 AM
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    Hey, I'm an engineer. I can solve any problem. Fast, Cheap and Good. Pick two.
  15. Feb 7, 2011 at 8:48 PM
    Daudio
    North Jersey
    '02 SR5
    Gotta go cheap and good on that one:cool:
  16. Feb 8, 2011 at 4:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    Quick question: Do the lights have replacable bulbs? If the do, stick 12V bulbs in there.
  17. Feb 9, 2011 at 3:04 AM
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    They are LED
