25 MPH Vibe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bishtacova, Aug 6, 2010.
  1. Aug 6, 2010 at 6:05 PM
    bishtacova
    bishtacova [OP] Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    Sirs, I have a mild shudder at exactly 25MPH that the dealership has not fixed in two visits. Turning the rotors and balance tires have not fixed the issue. I had the rear TSB done, still there. Is there anything else that should be looked at? I have stock dunlops set to 32psi front and 30 rear. Should I replace the tires to get rid of the vibe? Taco has 14k miles.
  2. Aug 15, 2010 at 4:10 PM
    bishtacova
    I've noticed this vibe greatly increases with sams club 87 octane but goes to a dribble on 93 super. Any idea why?
  3. Aug 15, 2010 at 4:13 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Try adjusting the tire pressure a couple pounds.
    Keep track of the pressures and drive a while to see if there is a difference.
    It may take a couple days
    But if it does make a difference, you know its only with tires.
  4. Oct 12, 2010 at 9:38 PM
    adavis22
    adavis22 Member
    Allen
    Texas
    TRD Sport 4X4
    I have the same issue. It shudders with both the factory tires and the Open Country A/Ts I've put on.
    It's a shudder that happens only at about 25 mph, it will stay constant if I hold that speed and is worse when I'm slowing to stop. PLEASE HELP.
  5. Oct 12, 2010 at 9:41 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I have a similar vibe at similar speeds , but can't remember if it occured when I still had the stock Dunlops on . I have 265/70/17 Hankook Dynapro M/T's now .
  6. Oct 12, 2010 at 9:45 PM
    adavis22
    adavis22 Member
    Allen
    Texas
    TRD Sport 4X4
    Not helpful.
  7. Oct 12, 2010 at 9:45 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    hahah noneck, we can always count on you for the best possible solution to a tough issue :D
  8. Oct 12, 2010 at 9:45 PM
    OZ-T
    Peter North
    British Columbia
    :rimshot:
  9. Oct 12, 2010 at 9:47 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    There is a TSB for this. T-SB-0132-08
  10. Oct 12, 2010 at 9:48 PM
    OZ-T
    Peter North
    British Columbia
    Wha ? I gotta check that out .
  11. Oct 12, 2010 at 9:54 PM
    adavis22
    adavis22 Member
    Allen
    Texas
    TRD Sport 4X4
    This TSB does not apply to my 09 Dbl Cab.
  12. Oct 12, 2010 at 9:56 PM
    S.B.
    Sean
    Which is what the TSB is for.
  13. Oct 12, 2010 at 9:59 PM
    OZ-T
    Peter North
    British Columbia
    ^^^ Same here , S.B. you know if the TSB has been updated to cover 09's as well ?
  14. Oct 12, 2010 at 10:01 PM
    S.B.
    Sean
    I just read the TSB (I got from the dealer) and ya it only covers the 05-08s. my bad for not reading it first.
    It could be worth a try to contact your dealer and see what they say.
  15. Oct 12, 2010 at 10:01 PM
    adavis22
    adavis22 Member
    Allen
    Texas
    TRD Sport 4X4
  16. Oct 12, 2010 at 10:02 PM
    OZ-T
    Peter North
    British Columbia
  17. Oct 12, 2010 at 10:03 PM
    adavis22
    adavis22 Member
    Allen
    Texas
    TRD Sport 4X4
    No worries, I have been round and round with my dealer, they "don't notice" any shudder/vibration at that speed. I'm going to try one last time and have them ride with me so there is no question. If that doesnt work, I'm trying the carrier bearing drop. Should have installed the diff drop anyway, so I'll go ahead with that as well.
