$25 Plate Bumper Dress Up Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MSrebel, Sep 14, 2014.
  1. Sep 14, 2014 at 5:50 PM
    MSrebel
    MSrebel [OP] Well-Known Member
    MS
    13 4X4 SR5
    Bil 5100, 1" Rear Block, Front light bar, Bed mounted light bar, Headwaters Seat covers front and rear, KC lights
    This is my first "How To" write up so here goes. I love the Pelfreybilt Plate bumper I just installed but wasn't crazy about how 'busy' the area directly behind the frame attachment studs was. I did a $25 mod to clean the area up. I have no welding ability and used only a circular saw with a metal blade, a Dremel, and drill.
    1. I used cardboard and scissors to make a pattern for each side. (Turned out the pattern could be used for both sides)
    2. I purchased at Lowes a 12"X24" piece of sheet metal, (2) 3 1/2"X5/16" Stainless bolts, (4) 5/16" fender washers, (2) 3/8" fender washers for inside of frame (to block large hole in frame) and (2) 5/16" nuts = $25
    3. Cut metal with circular saw to match cardboard pattern. Clean edges with Dremel.
    4. Test fit and mark large hole thru frame with sharpie. Drill 5/16" hole in center of mark.
    5. Clean with acetone, prime and paint with Rustoleum.
    6. Attach to frame with purchased hardware.
  2. Sep 14, 2014 at 5:52 PM
    MSrebel
    MS
    13 4X4 SR5
    Photos added.
  3. Sep 14, 2014 at 5:53 PM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Never mind, you added pics now!:cool:
  4. Sep 14, 2014 at 6:51 PM
    smd3
    smd3 Well-Known Member
    Nice!
  5. Sep 14, 2014 at 8:37 PM
    Cjanik
    Cjanik Senior Member
    Chase
    Vegas
    '11 4x4 Off-Road DCSB in MGM
    OME front & rear shocks, OME 886 springs, Dakar rear leaf pack, ICON UCA, Demello front bumper, BFG M/T 255/85r16
    hmmm...I just may do the same thing! great idea!
  6. Sep 14, 2014 at 8:38 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Cool idea...why not cover the lower square tube as well? Thats what I figured this was...
  7. Sep 14, 2014 at 8:39 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nice job , have some green squares on me
  8. Sep 15, 2014 at 6:21 AM
    MSrebel
    MS
    13 4X4 SR5
    I agree that winch plates would help. The brackets underneath the frame in the first photo provide some frame reinforcement and winch plates don't provide quite as much coverage as these do. As far as covering the lower square tube open ends, I couldn't have my plate flush with the frame and cover those because the tube extends beyond the frame. If I could weld, I would build a new insert that fits flush with the open end tube like the factory insert that protrudes. Then I would weld a 3/16" steel 'wing' perpendicular to cover this entire area.
  9. Sep 15, 2014 at 6:21 AM
    MSrebel
    MS
    13 4X4 SR5
    As such:
  10. Sep 20, 2014 at 1:52 PM
    MSrebel
    MS
    13 4X4 SR5
    Want to share a cheap fix for those 2 open rectangular ends left visible down low when you install a new bumper. I ordered these plugs online for $2.25 apiece. Shipping is high but maybe owners in the same area could make a big order. I just trimmed the 'fins' by about 2/3 on the long sides of the plugs, no trimming on the short sides. rubber mallet and voila.
    http://www.exercise-equipment-parts....-textured.html
