250 miles on a "new" truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billstickly1, Mar 20, 2013.
  1. Mar 20, 2013 at 9:10 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    that's practically used dude. should have told them to cut a few thousand off.
  2. Mar 20, 2013 at 9:12 PM
    farbio615
    farbio615 Well-Known Member
    Adam
    Ft. Polk
    Big and Blue
    A few
    i take back what i said before. I would buy it then wreck it so I had something more to worry about
  3. Mar 20, 2013 at 9:14 PM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    +1
    The person that drove it the 250 miles probably does dealer swaps all the time. Also tearing up a new truck would be an employees ass. Most people are not going to risk their job to trash a vehicle. I was a service writer for Ford and drove so many new vehicles it was just another day. Look at the truck if it looks good it probably is. Check the tires make sure the nipples are still on them just do some inspecting. Common sense kind of stuff, like my old man used to say "use your head".
  4. Mar 20, 2013 at 9:14 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    There's your answer my friend. Not only should you not buy this truck - I would NEVER deal with them again.
  5. Mar 20, 2013 at 9:15 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep... that's a used vehical. Tell them to drop the price $3,000 or you'll shop elsewhere.
  6. Mar 20, 2013 at 9:17 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    This, 170k miles later, I still remember the 13 mine had on it, but it doesn't bother me anymore. I know I'm the only driver of this truck.
  7. Mar 20, 2013 at 9:36 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    My truck had about 175 miles on it when I purchased it...it was the only 2012 in the area when they first came out that had the options I wanted. They drove it in from another dealer. As long as those miles aren't test drive miles I don't think you have anything to worry about. It's not like the Tacoma's are sports cars. Just check for mud ;) Less then 500 miles is nothing...you will probably do far worse to your truck over the time you own it.
    Even then, most dealers go with you these days...only a few times have I test drove a new car by myself....one time because It was only a two seater and my father came with. :burnrubber: with < 20 miles.:D
  8. Mar 20, 2013 at 9:58 PM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    your warranty starts at whatever mileage is on the odometer when you purchase it. I wouldn't worry about it, if you don't buy it someone else will. look it over good for rock pecks after clean up, that and door nicks are about I would worry about. almost forgot, no smoking in vehicle.
  9. Mar 20, 2013 at 10:40 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Act like you really don't like it, but buy the truck anyway, and they should try to sweeten the deal to make you happy :D You might get something free out of it or a small price break.
  10. Mar 21, 2013 at 12:32 AM
    JKD
    JKD Well-Known Member
    On the one hand, no big deal.
    On the other hand, a lot of people (myself included) prefer to go by a fairly specific set of rules about break-in, and the most important break-in occurs before 50-100 miles. Maybe the dealership drivers go by "break in" rules too, but maybe not.
    That's probably more an emotional response than a reasoned one. I'm sure there's virtually zero chance that anything bad actually happened during the drive up. Probably a bored retired guy listening to AM radio for a few hours.
  11. Mar 21, 2013 at 4:20 AM
    MadMan
    MadMan Well-Known Member
    Indy
    13 TRD sport
    De-badged and blacked out
    Get them to throw in life-time oil changes and call it done. :)
  12. Mar 21, 2013 at 4:25 AM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    Seeing how you are new to this forum. After you spend more time on here you're probably gonna mod, lift, put bigger tires, offroad it anyways. That first 250 miles will probably be the easiest miles it will ever see.
  13. Mar 21, 2013 at 5:08 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Guess they did not have what you wanted so they sent an employee 500 miles to get it for you and now your mad? Would you have asked a friend to drive 10 hours so you could put the 250 miles on your self? It common practice that's how dealers make deals for some thing as simple as a color. None of the dealers in southern Maine had what I wanted they went to Mass. to get it for me no charge.
  14. Mar 21, 2013 at 5:15 AM
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    didnt read through the whole thing but my first thought since you walked away id bet theyd be willing to make a pretty good deal now. if so id still get the truck if its exactly what you want.
  15. Mar 21, 2013 at 5:17 AM
    #35
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    I work hard for my $. And these trucks aren't cheap. If it didn't feel right then I would have pulled the plug too. It's sucks cause you had your heart set on this one. But it will be worth the wait for the next one. Trust me. I waited a month or so for my exact options package to be built and I'm so glad I did. 2 miles on the clock when I headed down the road. Couldn't be happier. Could've settled for something close, but I held out and have no regrets. Take that time to save up a little more down payment cash.
  16. Mar 21, 2013 at 5:29 AM
    #36
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I worked for a GMC truck dealership a few years back. We used to do truck trades all the time. We had 3 retired old men on call to run the trades for us. They were great. Not only did they drive the trucks from other dealerships, they would note any squeeks, rattles or any other problems when they checked them in. Buy the truck. I am sure they don't have teenagers doing their swaps.
  17. Mar 21, 2013 at 5:31 AM
    #37
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Mine had 300 miles on it when I bought it new, it's original dealership was in Pennsylvania and I bought it in West Virginia. It didn't bother me at all that it had those miles, I now have 46K on the truck with no problems. I was told Toyota dealerships trade new vehicles back and forth with other Toyota dealerships.
  18. Mar 21, 2013 at 5:56 AM
    #38
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    What mine said when I got into to test drive....well needless to say that's what sold me on mine. I was driving by when they were unloading it and I thought we'll let's take a look.
  19. Mar 21, 2013 at 6:53 AM
    #39
    billstickly1
    billstickly1 [OP] Well-Known Member
    ^ would love to see that. I am sure it wont happen. Would be much easier if I was looking for something more common I am sure. The salesperson emailed me this morning and asked if I would still be interested in the truck if they could get it without the miles. I said under 10 miles and I will buy it no problem.
  20. Mar 21, 2013 at 7:21 AM
    #40
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    2021 Tacoma TRD Pro
    none
    From what I've seen, some miles on a "new" vehicle is quite common. When I do a test drive, I will put about 30 miles on a vehicle, and I don't always buy that one. Dealers don't seem to be bothered by that.
    About 15 years ago, Colorado changed its laws regarding miles on new vehicles. Prior to the law change, if a vehicle had over 200 miles, it couldn't be sold as new. Now its 2000 miles, as long as its never been sold/registered before.
    OTOH, years ago (1960s) my father drove cars between dealers (for "dealer swaps") for the local Chevy dealership. His drives were usually 200-300 miles each way, but the speedometers were always disconnected (can't do that now). We lived in Yuma, AZ and he usually drove to Phoenix, LA or San Diego. Anyway, he drove the snot out of those cars (he got paid for the trip, not an hourly rate). They once had him drive a Corvette and he knocked almost an hour off his usual drive time to LA.
