$250 well spent dollars!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Leer, Nov 27, 2011.
  1. Nov 27, 2011 at 8:54 PM
    Leer
    Leer [OP] Well-Known Member
    Lee
    Hilo / Oahu
    08 Tacoma 4x4
    Well I just go finished installing my double din "Valor" dvd unit with backup camera today. The unit was $199 and the install kit plus the back up camera costed about $50 all with free shipping!
    Now as far as the unit is concerned, I am quit please with it as the price was very, VERY reasonable. It has built in blue tooth that works perfectly and can steam music from my I-phone 4 from both my library as well as Pandora.
    Dvd's load up real quick, the picture is very clear (except in the pics I've posted here using my cell phone camera) and its a not bad looking unit. The only gripe I have about this unit is that fact that I am used to having built in crossover adjustments which this unit does not have.
    Other than that though, it's great! I used the Scoscche install unit and it fit quite well. The color seems a little bit off, but over-all, it does it's job well with no rattles and a stock look.
    Here are some pics, please keep in mind that i was using my camera phone and it was already getting dark so the picture quality isn't great:
    Right now I have the head unit hooked up to my stock speakers. Not the best sound but better than stock. In a little time I'll round out the install with some decent subs and amps!
  2. Nov 27, 2011 at 8:56 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Those things are only $200 now? Jesus I remember when double dins were multi-thousand dollar headunits.
  3. Nov 27, 2011 at 9:03 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Cooper Discoverer ATP 285/50, Bilstein 5100's all around, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, Clazzio seat covers, BHLM with removed turn lens, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Is the backup camera a third party unit? Sounds like it is. If so, where does it mount?
  4. Nov 27, 2011 at 9:05 PM
    nighthawk87
    nighthawk87 Well-Known Member
    Tell us more!
  5. Nov 27, 2011 at 10:01 PM
    Leer
    Lee
    Hilo / Oahu
    08 Tacoma 4x4
    Thanks for the input guys!
    Yea, the backup camera was just a cheapo one I bought from Amazon. It has a very wide veiwing pattern but night viewing leaves alot to be desired!
    It is mounted in my trailer hitch for now. I cut a hole in the hitch cap and mounted to camera in there. I have it connected to the toggle switch shown in one of the pictures above because I want to be able to control when I have the camera on.
    I plan on getting a much better one down the road when I order my subs, speakers and amps. But this is just fine for now!
  6. Nov 27, 2011 at 10:19 PM
    Helidogtyler
    Helidogtyler New Member
    CA
    2018 TRD Off Road DCLB
    Diamondback Cover, TRD 17” Wheels, 265/70r17 BFG KO2
    Very nice, where did you buy the Valor?
  7. Nov 27, 2011 at 10:20 PM
    monkeytaco
    monkeytaco Well-Known Member
    Charles
    Austin, TX
    2012 Mag Grey DCSB V6 4x4 AT Sport
    +1 nice work!
  8. Nov 27, 2011 at 10:28 PM
    Leer
    Lee
    Hilo / Oahu
    08 Tacoma 4x4
    Well I was originally going to buy it from Crutchfield, they had it for $299 I think with free install gear. But then I decided to see if Amazon had it and it was only $199 there.
    Thanks!
  9. Nov 28, 2011 at 2:08 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Wow looks great and a great deal
  10. Nov 28, 2011 at 2:44 AM
    chich2000
    chich2000 Well-Known Member
    AK
    Tacoma 4WD TDR
    looks good! do u have the direct link to the valor? I can't find it by doing an Amazon search. the cheapest one that comes up is $300 and it's doesn't look the same as yours? Im currently in the market and really like the valor.
  11. Nov 28, 2011 at 3:58 AM
    upthemaiden
    upthemaiden Well-Known Member
    Josh
    Pittsburgh PA
    06 Access cab SR5
    Just bought it!
    Looks awesome! I'd love a backup camera. How was the wiring? Did you have to get into wiring diagrams and splicing things, or does it just come with all the plugs you need to swap it? What about the camera? I would definitely consider something like this if the wiring wasn't over my head.
    Does it come with the hookup for an aux input, or is bluetooth your only choice if you use your ipod/pandora?
  12. Nov 28, 2011 at 7:29 AM
    Leer
    Lee
    Hilo / Oahu
    08 Tacoma 4x4
    Thank you!
    Linky:
    http://www.amazon.com/Valor-Multime...9L42/ref=sr_1_1?ie=UTF8&qid=1322493447&sr=8-1
    AS far as the wiring is concerned, for the head unit, I also bought the install kit from Amazon, 2 total. The first install kit replaces the original stereo face and hold the new head unit in place and the second kit is for the wiring which is very clearly marked so you wont make any mistakes. it plugs directly into the stock plugs for the original deck and you will then splice the wires from the kit into the wires to the head unit.
    The camera itself didn't come with very good instructionn, but its pretty easy to install. The camera have an RCA output that goes ino the rear of the deck (again, clearly marked on the deck), and you have a negative wire and a positive. And the head unit has another wire coming out of the rear. That wire coming out of the rear of the deck is supposed to tap into the positive wire for the revers lights and the positive wire for the camera can either tap into that same reverse light wire or and accessory wire that have juice once the key is turned on. You can ground the camera anywere under the bed and you just have to connect the rca fom the camera to the rca in the rear of the deck.
    If you have a tow hitch on your truck then mounting the camera will be pretty easy using the existing cap that covers the hole on the toe hitch. Since its rubber, you can cut it or do anything you need to it and its a cheap replacement incase you dont like how it came out or want to change something later. Let me know if you have anymore questions!
  13. Nov 28, 2011 at 7:39 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    El Cajon, CA
    Blue '06 Prerunner TRD Sport
    LED Spyder Tail Lights, Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear 5125s, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 33x12.50R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack, Glassworks Front Fenders, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, MBRP Catback Exhaust, 20W PA Speaker, 2 Meter Radio, AFE Stage2 CAI, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper
    Now that looks smooth! Great find and great deal!
  14. Nov 28, 2011 at 10:32 AM
    upthemaiden
    Josh
    Pittsburgh PA
    06 Access cab SR5
    Just bought it!
    Does it let you use a 3.5mm audio jack for the auxiliary, or is it bluetooth only?
  15. Nov 28, 2011 at 10:46 AM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    It would be nice if somone could figure out how to wire the stock back up camera to the unit.
  16. Nov 28, 2011 at 11:13 AM
    Leer
    Lee
    Hilo / Oahu
    08 Tacoma 4x4
    Thank you!
    Yes it has the 3.5 plug on the front of the unit, it takes up to a 32 gb sd card. It comes with a connection so you can connect a usb device and on the rear of the unit, there is a detachable input plug that allows you to connect rca inputs like for a game or something I'm guessing.
    My future plan is to upgrade to the stock handle/camera so this would be very useful to me as well!!!
  17. Nov 28, 2011 at 11:23 AM
    sytfu510
    sytfu510 INSTAGRAM: sytfu510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit DMZ LT Kit TRD Supercharger SCS Wheels BAMF
    someone did, there was a thread here showing how to cut the stock harness on the camera and wire it back to a regular RCA. Then you can just plug it into any monitor.
  18. Nov 28, 2011 at 12:04 PM
    jasper07
    jasper07 Member
    Florida
    10 V6 4WD 6 SPEED DOUBLE CAB
    How do u stream music from iphone 4?
  19. Nov 28, 2011 at 6:57 PM
    tcma07
    tcma07 Chris
    C.C. Texas
    2007 Sport 4x4 v6 A/C Blk
    4" lift, Satoshi, BHLM...
    Nice about to purchase the same setup now :cool:
  20. Nov 28, 2011 at 7:05 PM
    kimo
    kimo Well-Known Member
    Knuckle Head
    MONTEREY BAY
    09 Super White TRD Sport DCLB 4X4!
    Great price for that, looks nice too.
