2500 miles, 1 month to fix coolant leak.
Discussion in '4th Gen. Tacomas (2024+)' started by taco4moro, Apr 22, 2024.
  1. Apr 27, 2024 at 3:23 AM
    #41
    Archimedes
    Archimedes Demanufacturer
    Outside the stupid part of Vermont
    23 DCSB TRD OR MGM
    Full-on degenerate heavy metal banjo music
    Wait, a Toyota dealer.... and they have a Nissan as a rental? What six-sigma manager level of thinking brought them to that line of action?
    I'd also ask for a free extended powertrain warranty at this point, as they're already wrenching and who knows what they will bump and move affecting things down the line...
    2016Tacoman likes this.
  2. Apr 27, 2024 at 6:55 AM
    #42
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    The frontier is probs 10k cheaper than a comparable taco …
  3. Apr 27, 2024 at 7:25 AM
    #43
    4x4spiegel
    4x4spiegel Well-Known Member
    what's the procedure in remedying this , pull engine , drop trans or something easy peasy
  4. Apr 27, 2024 at 7:53 AM
    #44
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    The crimp clamps are also impossible to over torque which is one of the primary causes for a worm clamp to fail. They also don't drag the material being clamped towards the worm assembly like a worm clamp does. Not a huge fan of the spring clamps like what's on the op's truck (I have them also) but they've held fine for many years. They fact that at least two of the OPs clamps are leaking makes me wonder if those weren't heat treated properly and have insufficient tension.
    TurboDA6 likes this.
  5. Apr 27, 2024 at 7:58 AM
    #45
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    There is a reason all the OEMs use constant tension (spring) clamps. It is because….they maintain constant tension on the hose with temperature changes. In other words, they work and are maintenance free, and are the superior choice. Worm gear clamps can work but as temps fluctuate they will either be too tight or too loose.
    If anyone switches to worm gear clamps because they hate dealing with the spring clamps, then they clearly don’t have the proper tool that makes spring clamps easily workable. No, normal pliers aren’t the proper tool. Hose clamp pliers are.
    Functionality aside, the worm gear clamps look like cheap garbage in an otherwise clean stock engine compartment.
    I don’t know what OP’s issue is but it looks like the hoses aren’t fully over the sealing ribs on the pipe to hose connections. And the clamps aren’t either. But I’m not familiar with the new engine and how the hoses should look alternatively so maybe it’s just the appearance.
  6. Apr 27, 2024 at 12:56 PM
    #46
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Dealer owner probably owns another brand and the service bays share the rental pool. I have seen that before with a mega Dealer with 5 competing brands in the same location.
    turbosnail and Schlappesepple like this.
  7. Apr 27, 2024 at 6:06 PM
    #47
    TurboDA6
    TurboDA6 Well-Known Member
    Haha LOL says the guy that owns a truck where the manufacturer can't even figure out something as simple as cooling hoses.
    Oh the horror of sitting behind a Nissan badge.
    Hecho en Mexico, a Toda Madre por vida!
  8. Apr 27, 2024 at 6:14 PM
    #48
    young
    young Well-Known Member
    Look bad for the new truck
  9. Apr 29, 2024 at 8:27 AM
    #49
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
  10. Apr 29, 2024 at 8:35 AM
    #50
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Thanks for sharing the brochure. Seems like many people jump straight to "lemon law" claims without realizing there needs to be a history of the issue (or issues) before that can take place.
    I'd be curious as to the strict definition of the 30 days in the shop, though. Like, does time waiting for the part apply, since they are not actively trying to fix the truck? I'd assume no, but I haven't read the rule and I'm not a lawyer. (The truck is clearly still drivable, too).
  11. Apr 30, 2024 at 7:43 AM
    #51
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    30 days without the truck due to a mechanical issue will usually qualify for lemon law in most states. Doesn't matter if it's just the part holding the repair up.
  12. Apr 30, 2024 at 10:28 AM
    #52
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Usually only for serious safety issues. For not getting a new car for a coolant leak.
  13. Apr 30, 2024 at 10:29 AM
    #53
    MK212MX
    MK212MX Well-Known Member
    2022 Tacoma TRD Sport
    More responsive? Really because I have owned both. That V6 in the Nissan puts out 310HP and has the 8 speed tranny. Pretty close to the Gen 4 and no turbo lag to deal with. The Nissan did steer a little heavy but not really noticeable after you put some miles on it.
  14. Apr 30, 2024 at 12:08 PM
    #54
    STEELeR43
    Hawaii
    I get it. But what others wrote. Also, everybody tell, no buy first two years of brand new version of vehicles. Bugs come out.;)
  15. Apr 30, 2024 at 12:34 PM
    #55
    fourfourone
    Lemon Law in CA:
    • The vehicle has been in the shop for more than 30 days (not necessarily in a row) for repair of any problems covered by its warranty. This is called the Lemon Law Presumption
  16. Apr 30, 2024 at 6:53 PM
    #56
    2016Tacoman
    J
    30 days is unacceptable.
  17. May 1, 2024 at 10:26 AM
    #57
    MK212MX
  18. May 1, 2024 at 2:44 PM
    #58
    TurboDA6
    9AT, not 8
    SaulGoodman likes this.
