250k mile tacoma - negligence
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stupidkid, Jul 7, 2020.
  1. Jul 7, 2020 at 10:42 PM
    Stupidkid
    Stupidkid [OP] Member
    Hi all,
    I havea 2007 tacoma prerunner i bought new, and just rolled over 250k miles.
    I have done all my maintence since it ran out of warranty, but have neglected a few things... Wondering if i should bother or "if it aint broke..."
    Power steering fluid - never been changed, should i even bother?
    Water pump - still original
    Serpentine belt - original. Im just afraid the water pump or pullys will give up if they experience a slight change in belt tension should i replace it.
    Going to drive cross country in a few weeks and debating doing these things now or later.
    Other than that, mostly just performed preventative maintenance.
  2. Jul 7, 2020 at 10:47 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    If it’s gone this long with no problems, let it ride with the fluids..... for the serpentine belt, that’s a very easy swap, just buy the belt, release the tension, and replace. Can do it in 15 minutes with the diagram.
    ToyoTaco25, Blockhead and TnShooter like this.
  3. Jul 8, 2020 at 1:48 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    1. I am amazed that the idler pulleys have made it that long. At 150k mine were grinding so when you put that new belt on spin them and see. If the belt self destructs it may mess a few things up under the hood.
    2. As for 30 minute PS fluid flush it takes longer to jack up the front end than the flush turning the steering engine off (posts on how to do). This is a nice to do but not required as my fluid was dark crap at 150k vs the red.
    3.If you did coolant a few times flushing at 2 block drains and maybe a new pressure cap, your water pump and thermostat are probably fine unless some noise or temp problem. Grab your rad hoses and make sure not soft near connections as a hot summer.
    Always other things to do/change but these were your questioned ones.
    Have a great trip.
  4. Jul 8, 2020 at 2:23 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Damn. I syphon the ps fluid every oil change.
    Lester Lugnut likes this.
  5. Jul 8, 2020 at 2:28 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    CC trip? Stay on major interstates. Keep: phone charged, case of bottled water (for you and the truck). Is there air in the spare tire?
  6. Jul 8, 2020 at 4:17 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Items I recommend investing in are a portable air compressor, tire repair kit, and a better jack if your truck is lifted. I even carry a cordless impact for tire changes. If you have never dropped the spare, I highly recommend doing it along with checking the pressure and condition of it. I would also oil the mechanism once you have the spare lowered.
    spikekw and Oldewing1800 like this.
  7. Jul 8, 2020 at 4:41 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I have 205,000 on my 07. I think you're way overdue on the belt. That is a simple job and I think you're overthinking it.
    I've done very little to mine. I have replaced the plugs twice, rear brake pads once and the fronts 3 times. Still have the original rotors and drums. I replace the belt every 100K. I had the transfer case and diff oil changed at 170,000. Still working with factory transmission fluid and won't change it until I have to rebuild in another 10 years. I sometimes worry about hoses, but they are still soft and pliable, and the coolant is still good when tested.
    The only real parts I've had to replace were a U-Joint and the alternator.
  8. Jul 8, 2020 at 5:05 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The water pump I'm my v6 looked phenomenal with 238k on it. The impeller looked as good as the replacement. No worries there imo.
    Power steering fluid is an easy change. The hardest part is the set up. Emptying the reservoir, rerouting the return line. Putting the truck on stands. Start with the wheel turned all the way in one direction before you drain the reservoir. When you do this move the wheel to the other stop then refill the reservoir. Repeat... Don't try and do 2 wheel movements before refilling; you'll empty the reservoir.
    The serpintine belt should definitely be replaced. There are threads where the belt has torn and wrapped behind the crank pulley taking out the seal. Easy fix to prevent a potential headache down the road.
    What's the condition of the antifreeze? If it's original, that and the tstat should be replaced as well.
    Check the tranny fluid level. Maybe do a drain and fill or go so far and drop the pan and replace the screen filter.
    And check out the front end. Upper and lower BJs, tie rods, sway bar links...
    Imo, it comes down to doing what you can to minimize the possibility of breaking down somewhere.
    Maintenance is cheaper than breakdowns.
  9. Jul 8, 2020 at 5:18 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I would change belt, hoses, brake fluid if that's never been done, and anti freeze.
  10. Jul 8, 2020 at 5:33 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Might want to review your policy to make sure your insurance covers towing.
  11. Jul 8, 2020 at 5:38 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Do the maintenance before the trip. Your luck is about up at that mileage.
  12. Jul 8, 2020 at 5:47 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  13. Jul 8, 2020 at 5:57 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    ^ This.
    Your on borrowed time with that kind of mileage.
  14. Jul 8, 2020 at 6:10 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    PzTank[QUOTED] likes this.
  15. Jul 8, 2020 at 6:14 AM
    Stupidkid
    So have done coolant, transmission, brake fluid multiple times.
    Replaced the brake master cylinder last year after a leaking brake booster.
    Replaced the rear drums and shoes last year, shoes still had life at 235k...
    Replaced LBJs 5 years back with moog, they are already getting a little slop. Im just going to order new lower arms from toyota.
    Replaced ujoints three times now. The rear most ujoint was the only bad joint two of those times
    Replaced driveshaft carrier bearing at prob 150k
  16. Jul 8, 2020 at 7:00 AM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    OP: Asks truck guys if he should do things to truck
    Truck guys: Do things to truck
    You'll probably be fine if you can't do any of that stuff but you should if you have the time/funds.
  17. Jul 8, 2020 at 7:12 AM
    Stupidkid
    Yea really just wondering about creating a PS leak by replacing the fluid.
  18. Jul 8, 2020 at 7:58 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    I have over 220k on my '09. Power steering fluid has never been changed, not much of a reason to. Water pump is still the OG and (knock on wood), no signs of leaking yet. I've replaced my serpentine belt once. You'll be fine OP.
  19. Jul 8, 2020 at 10:28 AM
    Larzzzz
    Larry
    MA
    I did mine probably 50-60 k ago for the first time. No leaks before or after.
    As for the water pump, there's a weep hole. You gotta crawl under and look into the back side of the pulley on the water pump. If you don't see any pink crusty stuff, the water pump is good.
    Good luck.
  20. Jul 8, 2020 at 10:38 AM
    Taco Wake
    Taco Wake Well-Known Member
    South Carolina
    At a minimum I'd buy a spare belt and keep it in the truck, but if it was me I'd replace the belt for sure. Changing PS and transmission fluids are good ideas, but not critical before your trip.
