250lb motorcycle on a tow hitch?
Discussion in 'Towing' started by Wyliecoyote, Nov 11, 2018.
  1. Nov 11, 2018 at 10:03 AM
    Wyliecoyote
    Wyliecoyote [OP] Well-Known Member
    Robby
    los angeles california
    2018 off road tacoma access cab cement gray
    factory side step, didn't get a chance to do anything to it yet, haven't even got to put it in 4 wheel mode yet. Lame, but I work a lot.
    I'm picking up a rad little Honda monkey bike. I need a transport solution. I live in an apartment so storage is key. No room for a trailer. A tow hitch hauler seems to be the easiest solution right now. I have seen ratings all over the place from one star to 5. The bike weighs 250lbs. I have a 2018 off road Tacoma. Anyone use one?
  2. Nov 11, 2018 at 10:04 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    That is sweet, is it a little 50 or?
  3. Nov 11, 2018 at 10:08 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I’d suggest making it a hood ornament, perhaps?
  4. Nov 11, 2018 at 10:09 AM
    Wyliecoyote
    Robby
    Its a street legal 125
  5. Nov 11, 2018 at 10:13 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Looks cool, but the pice is a huge WTF $4k nope
    FFBlack likes this.
  6. Nov 11, 2018 at 10:20 AM
    Wyliecoyote
    Robby
    Really asking more for opinions on folks who have used this style of motorcycle hauler.
  7. Nov 11, 2018 at 10:29 AM
    FFBlack
    2019 TRD OFF ROAD
    I've seen them in use and it seems like the cheap ones Rock back and forth really bad on the highway. I've seen guys with 250 dirt bikes on the good ones and they look solid. This reminds me of the arctic cat whisker I had as a kid, lots of fun times.
  8. Nov 11, 2018 at 10:30 AM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Maybe check out some RV forums. I see a lot of these type of hitches with scooters, but have no personal experience with them.
  9. Nov 14, 2018 at 5:25 PM
    flyby
    flyby Well-Known Member
    Ohio
    14 DCSB 4x4
    I used a Moto-Tote once to carry a sportbike. That weight made me nervous but the monkeybike should be just fine.
    Discountramps.com sells carriers and is great to work with - 15% coupons come along frequently. 20% occasionally.
    Look for something steel, with a anti-rock device, chock for the front wheel, and nice wide/long arm for the straps. The one you pictured seems chintzy at first glance.
    I'd rather spend the money on a couple of nice loading ramps for the truck or a rent trailer over using the carrier though.
    Where are you located? You can borrow mine if you're close.
  10. Nov 14, 2018 at 5:45 PM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    Nice, op!! I just got rid of my Grom and I miss it every day! Might have to pick up one of these monkeys come spring time!
    As far as the hitch carrier, if you spend the money and get a good one, I’m sure you lol be fine. Why not throw it in the bed though?
  11. Nov 15, 2018 at 5:38 PM
    gnorv
    gnorv Member
    I use a hitch carry fir a 300 lbs dual sport with no issues
  12. Nov 15, 2018 at 5:48 PM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    I have a wr250 that I put in the same style hitch carrier with no problems
  13. Nov 17, 2018 at 5:32 PM
    Graton
    Graton Well-Known Member
    Berkshires - Massachusetts
    Depends on how often and how far you plan on going with the bike on the hitch. For short occasional hauls the cheaper ones are ok. I have an xt250, use it often, and travel far - I only use Vershaul. They are solid, a bit heavier than I would like, but they are the only carrier I would trust.
  14. Nov 25, 2018 at 3:22 AM
    JiminMaine
    JiminMaine Well-Known Member
    Jim
    Maine
    2017 TRD OR Access
    I know, I know!
    Easy! Your truck will have no problem carring 250lb bike on the back. I traveled from SF to Maine with a Triumph T100 raked and bobbed. I have carried many other bikes too. CB 500, Klr 650, R9T (added Firestone bags) etc.
    So a 250lbs is a breeze. Just make sure your steel carrier is rated for the load. Great retro bike!
  15. Dec 6, 2018 at 5:10 PM
    garyt68
    garyt68 Well-Known Member
    Gary
    Trabuco Canyon
    2012 TRD Sport DCSB
    I have a similar hitch mount bike hauler for my CRF 250X. I got it at Harbor Freight and it has worked fine for me. Doesn't rock too much and you don't even feel it on the truck.
  16. Dec 6, 2018 at 5:13 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I have one from www.joehauler.com that kicks butt. My bike is around 460 pounds and I have no worries.
  17. Dec 6, 2018 at 5:19 PM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
  18. Dec 9, 2018 at 9:16 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    get a good one, and you wont have any issues.
    I modded one to fit better on my truck and its been rock solid for my husky 501
  19. Dec 9, 2018 at 9:29 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    You will be fine with a hitch carrier... I use a harbor freight one that cost around 130$ and is partially aluminum which helps save on weight, it has been solid the last 4 years or so... I have used it for a ~400lb dual sport on harsh Nevada roads without issue... probably have over 6k miles with this setup, ruckus weighs couple hundred pounds.
    '14RC likes this.
  20. Dec 9, 2018 at 9:30 PM
    grichg
    grichg Well-Known Member
    rich
    Laguna Beach
    11 Tacoma 4x4
    Camburg 3.0 Coilovers Camburg A-arms All Pro rear bumper CBI Front Bumper LED Light Bar and PODs and some other misc
    I have a Joe Hauler and love it
    Doc.SS likes this.
