255/75/17 fitment?
Discussion in 'Wheels & Tires' started by 09silvertaco, Mar 8, 2010.
  1. Mar 8, 2010 at 5:20 PM
    09silvertaco
    09silvertaco [OP] Well-Known Member
    Massachusetts
    2010 AC TRD Sport V6 6SPD
    Will 255/75/17 fit wo/ a lift on a trd sport? seems like they would being that they are a shade taller than a 265/70 and a bit narrower. im thinking it may warrant taking off the front mud flaps to elminate any possible rubbing. thoughts?
  2. Mar 8, 2010 at 6:56 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    they work w/ flaps on....and all stock
  3. Mar 10, 2010 at 3:52 PM
    09silvertaco
    Massachusetts
    thanks jhodge...i remember you had the 255/75 on your truck at one point, but with the lift...good to know stock will work too. does anyone know if 275/70/17 will fit all stock? i know that one is a stretch b/c the tire, though the same height as 255/75 is almost a full inch wider. im taking of the mud flaps anyway, so keep that in mind.
  4. Mar 10, 2010 at 3:54 PM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    I had them before i lifted my truck. They fit perfect with no rubbing. At full flex i was able to see that i was a hair away from rubbing. They will fill your wheel wells good.
    EDIT: I was referring to the 255/75/17
  5. Mar 10, 2010 at 3:56 PM
    09silvertaco
    Massachusetts
    Good info. it sucks b/c there aren't many choices in that size, but i want to fill the wells as much as possible wo/lifting just yet. i don't do much if any offroading so i wouldn't think rubbing would be an issue. what tires did you/or do you have on yours in that size?
  6. Mar 10, 2010 at 4:02 PM
    MikeyD
    Sayreville NJ
    I still have them on. They are bfg mud terrains km's 255/75/17. They stopped making them but you might be able to still find them for a good deal. After they stopped making them i got mine for 450 shipped to my house brand new. check ebay. or google them
  7. Mar 10, 2010 at 4:06 PM
    09silvertaco
    Massachusetts
    nice! i do a lot of driving so the narrower tire, 255/75/17, though taller than stock, will be better on mpg than the 265/70 or 275/70 i would think.
    any other opinions on 275/70/17 on all stock suspension?
