255/75/r17
Discussion in 'Wheels & Tires' started by Dsmooth87, May 24, 2012.
  1. May 24, 2012 at 5:51 PM
    Dsmooth87
    Dsmooth87 [OP] Well-Known Member
    11' doublecab 6spd 4x4 trd offroad
    Satoshi Grille. 245/75r16 hercules terra trac a/t. Afe pro dry s. ome 884s toytec 1.5 AAL for TSB. Twm shift knob
    i currently have the stock 265 70 r16 tires and rims and wanted to convert to 255/75/r17. what size aftermarket wheel will i need to run these tires? and since i have the 6 speed will the taller tires help with freeway mpg?
  2. May 28, 2012 at 3:26 PM
    Dsmooth87
    lets not all respond at once
  3. May 28, 2012 at 3:40 PM
    Large
    Large Red
    Maybe if this was in the wheels & tires section you would get a prompt response. You would want a 17x7.5 or 17x8 (check with tire manufacturer specs so you know the least and most width you need on a wheel) and ideal backspace is 4.5 inches.
  4. Jun 13, 2012 at 1:40 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    I am thinking about going with this size too. What did you end up doing?
  5. Jun 13, 2012 at 1:55 PM
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    I have this tire. It wont improve MPG and increases RPMs at cruising speed. Granted I went from an AT to an MT. I have 7.5 backspacing I believe on my tundra wheels, and have had zero issues, Im sure stock tacoma 17s will work. Its a great tire size for a small or no lift truck. Look on craigslist for used tires in this size and I can assure you you will find someone with a jeep wrangler who stepped up to 33/35's and is selling their dunlops or BFG KM1's cheap. Thats what I did and I got a smoking deal. Additionally, if you shred a tire it should be pretty easy to replace because there are a billion wranglers who use this tire.
    I have had no problems rubbing even stuffed.
  6. Jun 13, 2012 at 2:02 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    How would it increase RPM's at cruising speed if it's a larger diameter than the OEM tires ?
    Bdonner likes this.
  7. Jun 13, 2012 at 2:06 PM
    greenrustic
    NY
  8. Jun 13, 2012 at 2:07 PM
    OZ-T
    Peter North
    British Columbia
    wut
  9. Jun 13, 2012 at 2:09 PM
    greenrustic
    NY
    I have the same question as you. Guess x2 would have been more appropriate.
  10. Jun 13, 2012 at 2:18 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I ran this size on a set of TRD Sport wheels. I ran em with and without spacers, on a 3" lift with no rubbing.
    As for MPG they came after a lift and I went with LT instead of P rated (wish I would've gone P) and it definitely hurt my MPG.
    As for OZ.. yeah my highway RPM's went down. No idea what that guy is smoking.
  11. Jun 13, 2012 at 3:48 PM
    Canuckwithatruck
    Canuckwithatruck Well-Known Member
    Ross
    Bow Lake, Alberta
    2006 TRD Sport
    OME 885 Coils Light Racing UCA's Dakar Leaf Pack
    I am planning on putting a set of 255/75/17 silent armors over the weekend. Hoping not to see a big decrease in mileage vs 265/65/17.
  12. Jun 13, 2012 at 4:24 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    greenrustic, it can't increase your RPM's at cruising speed unless you mess with gearing.
  13. Jun 13, 2012 at 4:31 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Taller tires will not help highway speed MPGs. Taller tires = higher RPMs.
  14. Jun 13, 2012 at 4:33 PM
    Pugga
    Massachusetts
    Umm... no, taller tires = lower RPMs at the same speed. And when I went from 265/65R17 to 265/70R17, my highway MPG did get better.
  15. Jun 13, 2012 at 4:34 PM
    krimson
    krimson Nothin
    TRD Off Road
    Really? Because when I came from a 265 to A 285 my MPGs went down the drain :notsure: I'm usually at 2k at 70 MPH.
  16. Jun 13, 2012 at 4:37 PM
    Pugga
    Massachusetts
    Because you went to a wider tire... Keep tread pattern and width the same, increase the height just a little, like from a 65 to a 70 series, and your highway MPG's will get a little better (obviously pending the driver). Going to a 285 will hurt MPGs, wider tires will do that.
  17. Jun 13, 2012 at 4:42 PM
    krimson
    krimson Nothin
    TRD Off Road
    I've always thought it has to do with the height of the tire and the weight of the tire. Higher A tire = higher RPMs
  18. Jun 13, 2012 at 4:45 PM
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    Unless you've done some recalibrating when you think you're doing 70 you're actually doing 75ish. difference in circumference is 7 and a bit percent.
    someone correct me if im derping here... but the spedo - tach ratio will stay the same regardless of tire size for a specific gear.
  19. Jun 13, 2012 at 4:47 PM
    OZ-T
    Peter North
    British Columbia
    A taller ( larger diameter ) tire travels more distance per axle revolution than a shorter ( smaller diameter ) tire , therefore you either ;
    1) go faster on the taller tire at the same RPM
    or
    2) go the same speed at a reduced RPM
  20. Jun 13, 2012 at 4:49 PM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    There are tonnes of factors. Tread design impacts rolling resistance, increased weight makes the tire harder to turn, wider tire makes the tire have more wind resistance (and usually weight).
    Not sure how a larger diameter tire could increase rpm at a given speed? It may required a lower gear to have adequate power to turn the tires, which would increase rpm..
