255 80 r17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdawg, Apr 18, 2011.
  1. Apr 18, 2011 at 1:05 PM
    cdawg
    cdawg [OP] Member
    Any one running these size tires? as BFG makes them and they are basically 33''s
  2. Apr 18, 2011 at 1:08 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I have the 255/85/16. They are the same OD. They haven't effected my hiway gas milage. I still get 19-20mpg. Mostly because of less resistance compared to 285s. And I'm using stock rims.
  3. Apr 18, 2011 at 1:15 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    How they run in Colorado's snow?
  4. Apr 18, 2011 at 1:20 PM
    S.B.
    Sean
    Don't know. Its ben very dry here in he springs. I drove up to Winter park once on the 70. There was almost no snow on the road (from 70 to winter park). For the little bit of snow they did fine. Back end wanted to slide out some, but still very controlled. I had 3 60lb bags in the back, but they slide to the front of the bed. This was the first time driving in snow and Have no other anything to compare to.
  5. Apr 18, 2011 at 3:40 PM
    cdawg
    cdawg [OP] Member
    do you have a 3 inch lift and if so any rubbing, trimming or issues?
  6. Apr 18, 2011 at 3:44 PM
    S.B.
    Sean
    I'm at a little less than 2" for lift. When I fist got them they kissed the frame at full lock to the right, then I got new UCAs and an alignment and it hasn't touched ever since. I haven't had to trim any thing due to rubbing.
  7. Apr 18, 2011 at 4:12 PM
    cdawg
    cdawg [OP] Member
    SB
    I\m thinking a 3 inch OME 885(i have a DCLB) with the 255/80/R17 do you think I would need UCA's as well?
  8. Apr 18, 2011 at 4:21 PM
    S.B.
    Sean
    UCAs help with alignment after lifting. Some say their alignment is in spec (minus caster) but most (like me) need UCAs to get the camber and caster back to spec (caster doesn't effect, shops sacrifice caster for camber). After I installed my Bult Right UCAs and did an alignment I notice a much smother ride. The little bumps were gone and its much nicer to drive on and off road. I definitely recommend them. The big brands are Camberg, Light Racing, Icon, Total Chaos. Some others are Downsouth Motorsport's (he is a vender on here) brand of UCAs and Built Right. I have the built rights and love them.
    Here is the link for the built rights: http://www.tacomaworld.com/forum/suspension/97398-new-built-right-ucas.html
  9. Apr 18, 2011 at 4:27 PM
    cdawg
    cdawg [OP] Member
    Thanks, S.B. appreciated.
  10. Apr 18, 2011 at 4:46 PM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    Hell yeah it's been dry. I'm up in Woodland Park. :(
    I'm running 265s (BFG ATs). I've run 285s, but in Colorado's super dry snow, nothing, no matter how wide, floats for very long. So I've been looking for a good compromise between flotation and bite. I found the 285 to be too squirmy and loose for my tastes. The 265s have been better. I ran 245s on my old 4Runner and they were great for the vehicle, but that truck was a good 1000 pounds lighter. So now I'm looking for 1st hand reports on the 255s. I have a feeling they'd do great in Colorado snows. I love the look too.
  11. Apr 18, 2011 at 6:45 PM
    S.B.
    Sean
    Maybe this next winter it will snow more, then I can actualy test them. The on trail I was they did weel except for the steep icy down hill.:rolleyes:
