255/80/r17s pizza cutter thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ares32, Dec 20, 2017.
  1. Mar 20, 2025 at 6:29 AM
    #801
    VicsTaco23
    VicsTaco23 Member
    Vic
    Los Angeles
    23 Tacoma TRD Off Road Black
    Eibach Pro Truck S2, JBA UCAs, Icon AAL
    Ok sounds good. I appreciate the help. I had a feeling I was going to do trimming and cmc. It seems like everyone has had different experiences lol. Some trim and cmc with no issues and others do lol. Either way I’m stoked about it. Now I just have to figure out what brand tires I want lol
  2. Mar 20, 2025 at 7:03 AM
    #802
    enluzenment
    enluzenment Well-Known Member
    Jeff
    RI
    2020 Cement TRD Sport DCLB
    17” KMC KM722 w/ Wildpeak AT3 Eibach Pro Truck Stage 2R
    Just make sure you take enough off the cab mount when you do the chop. Obviously, where the actual body mount is, you can only go that far back but outboard of the actual rubber mount try and go a little deeper and curve rhe plate. Hard to explain, but if you search some images of cmc jobs you’ll know what I’m talking about. Last thing you want is to end up like I did and have to go back and cut more after because it wasn’t enough the first time. Side note, I went with WP at4w, they’ve been good so far, for an E rated tire anyway.
    VicsTaco23[QUOTED] likes this.
  3. Mar 20, 2025 at 9:28 AM
    #803
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    What do you mean by "be ok?" are you talking functionally or aesthetically?
  4. Mar 20, 2025 at 3:31 PM
    #804
    VicsTaco23
    VicsTaco23 Member
    Vic
    Los Angeles
    Functionally
    Tronfunkblow[QUOTED] likes this.
  5. Mar 20, 2025 at 3:34 PM
    #805
    VicsTaco23
    VicsTaco23 Member
    Vic
    Los Angeles
    Thanks man. I know what you mean by cutting as much as possible. I’m going to throw the wheels and tires and go from there. As far as tires, I’m considering AT4W or Terra Grapplers for the tires.
  6. Mar 27, 2025 at 8:46 PM
    #806
    bc.trd
    bc.trd Active Member
    Just had these at4w thrown on. LT. The ride is smooth and was rubbing on mudflaps with 1.25 inch spacers and Bilstein 5100 at 1.55 with 1/4inch strut mount spacers on top of each side. (Around 2 inch front lift maybe more) 1 inch block in the back. Stock UCA. Still need to have my OME UCA installed and will throw the stock mudflaps back on or throw some rokblok mudflaps if anything. Not close to the cab mount or the fender liner up front at all.
    Switched from 265/70/17 (Motomaster eliminator AT: which in my opinion ran smaller than advertised)
  7. May 7, 2025 at 1:35 PM
    #807
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Anybody running 8.5" wide wheels on a 255/80/17? Wondering if there's any issues airing down to ~15 PSI or not
  8. Jun 8, 2025 at 4:17 PM
    #808
    Quadfxther
    Quadfxther Well-Known Member
    2021 Tacoma DCSB
    265/70R17 Cooper Rugged Trek OEM TRD Pro SEMA Wheels Yotaverse V2 Pro Grille Softopper w/ Custom Rack Toyota OEM Bed Mat Rokblokz Mud Flaps
    For people with stock gearing and no tune what has been your experience driving on the highway (70+mph) with 255/80r17? I live in southern KY/Northern TN area and frequently drive go over mountains on the interstate.
  9. Jun 8, 2025 at 4:52 PM
    #809
    enluzenment
    Jeff
    RI
    It hasn’t been an issue for me. I drive about 65 highway miles 6 days a week. Gas mileage isn’t great (not that it was good before) but I also average about 80/85mph. Obviously it takes a little more time or throttle to get up to highway speed compared to stock tires but once you’re at cruising speed, I don’t notice much of difference vs the 265/70/17s I was running before.
  10. Jun 8, 2025 at 5:19 PM
    #810
    Quadfxther
    2021 Tacoma DCSB
    Well that’s good to hear, not really concerned with mpg but more how it drives. Just worried about it gear hunting bad
  11. Jun 12, 2025 at 5:03 PM
    #811
    TacoTuesday25
    TacoTuesday25 Member
    Greenville, SC
    Are these OEM 17x7” with +4mm offset?
  12. Jun 13, 2025 at 6:30 AM
    #812
    hilighter
    hilighter Master of Disaster
    Portland, OR
    21 Tacoma MGM TRD OR DCSB ABCDEFG
    3” Ironman IM2.5 lift Body Armor stubby front bumper 10k Superwinch Ironman Raid rear bumper Custom sliders Nomad 501 17x8.5 Satin black wheels Smartcap Dashmat
    I’m in need of new tires - looking at the Mickey Thompson 255/85/17 - slightly taller (34.1 I believe)
    I have 285/70/17 now - hoping that less rolling resistance improves fuel mileage.
    Kane50 and Roody like this.
  13. Jun 13, 2025 at 6:47 AM
    #813
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It'll drive like a 2nd gen (5-speed automatic) ;)
  14. Jun 13, 2025 at 7:20 AM
    #814
    Quadfxther
    2021 Tacoma DCSB
    Who needs a 6th gear anyway right
  15. Jun 13, 2025 at 7:22 AM
    #815
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^With a tune, 6th becomes available above 85 mph
  16. Jun 13, 2025 at 7:37 AM
    #816
    Quadfxther
    2021 Tacoma DCSB
    I usually don’t ever drive above 75mph. wonder if 6th gear will work around 70mph.
    Guess i’ll find out when I get new tires in a couple of years, I like to plan my build to know what generally expect
  17. Jun 13, 2025 at 9:04 AM
    #817
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    A narrower tire does not necessarily have less rolling resistance. You need to consider other factors like rubber compound, tread pattern, amount of rubber, etc.
    For example, my LT255/85r16 e-load mud terrains have measurably more rolling resistance than my P265/70r16 SL all terrains (1-2 mpg) . The mud terrains are super beefy compared to the supple all terrains. More rubber means more friction thus less efficiency.
    hilighter[QUOTED] likes this.
  18. Jun 14, 2025 at 5:58 AM
    #818
    Kane50
    Kane50 Well-Known Member
    2016 TRD Sport
    Do it, I love my Baja Boss no loss I gas mileage compared to the 285’s I had on :thumbsup:
  19. Jun 14, 2025 at 1:27 PM
    #819
    Diver_De_Taco
    Diver_De_Taco Well-Known Member
    ‘23 TRD OR
    Any trimming required?
  20. Jun 14, 2025 at 3:24 PM
    #820
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    That's the nice thing about 33" pizza cutters. Less wear and tear on components, hence less gear hunting.And noooo cutting!!!!! And great ground clearance to boot! Any upsized tire is going to change your mpg, that's a given. So will a lift.
