255/85/16 on a reg cab
Discussion in 'Wheels & Tires' started by GARYRED, Mar 3, 2011.
  1. Mar 3, 2011 at 1:12 PM
    GARYRED
    GARYRED [OP] Well-Known Member
    David
    Huntsville Al.
    2010 REG CAB 4X4
    885's with OME shocks in front and back. 1.5AAL. BFG KM2 255/85/16
    First of all I have a 2010 reg cab 4x4, and I purchased the 3in OME kit with the 885 springs. I'm wanting to run the 255/85/16, but wondering how much cutting inside the fender I would need to do, to avoid rubbing. I See a lot guys with DC running this size but not to many with reg cabs.
    I would raise it more but that would increase the cv angle to much I think.
  2. Mar 3, 2011 at 1:35 PM
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    are you going to run your stock wheels?
  3. Mar 4, 2011 at 6:15 AM
    GARYRED
    David
    Huntsville Al.
    2010 REG CAB 4X4
    yes, i will be running the stock steelies
  4. May 25, 2011 at 9:00 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    the 255s will work ok. you will feel a loss in power and should probably regear. u will also need to do some trimming especially if you plan on going offroad a lot.
  5. May 25, 2011 at 9:09 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    From what I've heard the 255s require less trimming than the 285s and will have less of a power loss.
  6. May 26, 2011 at 7:46 AM
    GARYRED
    David
    Huntsville Al.
    2010 REG CAB 4X4
    So the 255's are manageable with a reg cab with 885 springs and no re-gear.
    I've even considered going with the km2 in the 235/85/16, but most people on TW don't like that size. Is there a reason why, I'm old school so I kinda like the skinny look, plus it is a 32in tire. What do ya'll think?
  7. May 26, 2011 at 7:48 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    tacoevndor or something like that has them....looks great
  8. May 26, 2011 at 7:51 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I think you would be fine with a 255 shit I have 33x12.5's and I haven't regeared. Sure you have some power loss but its not that much.
    I'm into the wider tires so I'm not a fan of 255's but if that's what you like I say go for it but not the 235's that's just way too small for a tacoma IMO.
