255/85/16s or 285/75/16?
Discussion in 'Wheels & Tires' started by YellowDog01, Jan 28, 2010.
  1. Feb 3, 2010 at 7:31 PM
    #81
    YellowDog01
    YellowDog01 [OP] Well-Known Member
    04 4x4
    There is no such thing as snow in SC! :)
  2. Feb 3, 2010 at 7:32 PM
    #82
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    disagree!
  3. Feb 3, 2010 at 7:37 PM
    #83
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    I meant SNOW
  4. Feb 3, 2010 at 8:29 PM
    #84
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    What a...
    BEAST!
  5. Feb 4, 2010 at 2:30 PM
    #85
    YellowDog01
    04 4x4
    Another question just came to mind...I know I know...
    Are 255s going to fit on my stock 16in. Wheels?
  6. Feb 4, 2010 at 3:40 PM
    #86
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Same width, if not a little narrower than stock. Yes:thumbsup:
  7. Feb 4, 2010 at 3:52 PM
    #87
    XGR50.2
    XGR50.2 Active Member
    David
    Austin, TX
    05 TRD
    So whats the issue with rubbing on a 2nd gen?
    Very minimal or will you have to do some modifications to stop it from rubbing like crazy, when it comes to daily driving
  8. Feb 4, 2010 at 6:00 PM
    #88
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    What would be the next size for a skinny tire? Anything along the lines of 265/85 or 34/11.5?
  9. Feb 4, 2010 at 8:11 PM
    #89
    adavis22
    adavis22 Member
    Allen
    Texas
    TRD Sport 4X4
    Just threw a pair set of toyo ats on my ride. Curious what sort of lift you've got to be running 285s on stock wheels. Do you rub at all?
  10. Feb 5, 2010 at 11:20 AM
    #90
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Prolly the usual corner of the wheel well. I wouldn't worry about UCAs or body mount on a skinny tire like that.
    I think more of a 35/11.5 or 12.5
  11. Feb 5, 2010 at 11:33 AM
    #91
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Go with 285
  12. Feb 5, 2010 at 7:21 PM
    #92
    08pretaco
    az
    id probably have to go with a 3" rear lift and i dont think it would fit with a 4" lift up front. so i would have to crank up my coilovers if i wanted to get any wheel travel.
    it would probably be a good idea to go with a 1 piece drive shaft which i dont have money for.
  13. Feb 6, 2010 at 4:55 AM
    #93
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Uh what gigantic tires are you talking about? I ran 285/70/17s on almost no lift with some trimming. Adjust your bumpstops so they don't stuff and enjoy. They'll fit in a wheel well with trimming. You don't even have front cvs to pop when your tires are drooped. Also adjusting your coilovers doesn't gaain any wheel travel. It just adjusts where in the arc of travel your wheel sits at ride height. Control arm length determines wheel travel.
    Almost no one runs a 1 piece driveshaft. Its hardly necessary.
  14. Feb 6, 2010 at 7:13 AM
    #94
    08pretaco
    az
    for 35's you need lift, which is what you posted, which is what i replyed to
  15. Feb 6, 2010 at 7:26 AM
    #95
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I think I missed something. :confused:Are you talking about coilovers vs spacers or are you saying the 33's won't cause cv's to pop when drooped? By cv popping, are you talking about a noise or slipping a boot?
  16. Feb 6, 2010 at 11:38 AM
    #96
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Gotcha. There's a few people running 35s. Body mount chop lengthen bump stops can't really stuff them. It hits the firewall. Lift doesn't make your wheel wells bigger.
    Oversize tires drooped suspension and wheel turned to lock in 4wd and the axle will bust. Ask tigerfan. That's where limiting straps come in. I've gotten them to make noise but not give out.
  17. Feb 6, 2010 at 1:23 PM
    #97
    JimBeam
    JB
    2015 Tundra
    they'll pop on stuffed suspension too :anonymous:
  18. Feb 8, 2010 at 6:07 PM
    #98
    YellowDog01
    04 4x4
    So I've searched and searched...And it looks like the Bfg KM2s, Cooper STs, Toyo Mts, and Maxxis Bighorns are the only tires in 255s.
    Dang. I want either the KM2s or Toyos, but the toyos are so expensive.
    Anyone else know of another tire in that size?
  19. Feb 8, 2010 at 7:08 PM
    #99
    BAMFTACO
    Juan
    Kings bruh
    Look at super swampers traxxs mt
  20. Feb 9, 2010 at 4:16 AM
    #100
    JimBeam
    JB
    2015 Tundra
    but only if you want to replace them in 25K miles or so
