255/85 R16 Owners Experience
Discussion in 'Wheels & Tires' started by rsbmg, May 8, 2011.
255/85 R16's?
Poll closed Jun 7, 2011.
  1. My tire of choice has worked great in all conditions
    58.3%
  2. Ran em but didn't work for me, went wider and am happy I did.
    16.7%
  3. Ran wide before now run the skinnies and am much happier
    25.0%
  1. Jun 2, 2014 at 11:58 AM
    #1981
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Max inflation pressure is on the tire sidewall. You would be foolish to exceed it. Since this thread is about 255/85 tires and many of them are load range D or E they are rated for heavy trucks with loads thus higher pressure. Your 265-50 x 20 are are likely a load rance C tire with lowere pressure rating, read the tire...
  2. Jun 2, 2014 at 12:06 PM
    #1982
    Yota64
    Yota64 Professional Threadjacker
    Thanks for the infos, I wonder how much this sweet sport varies between tires, trucks, and altitudes? I don't have room to perform the chalk test and my tires are safe to say very different than the majority here
    Thanks for the tip, but I know how to read the tire, I don't recall saying I didn't know how to find out my recommended and max PSI.
  3. Jun 2, 2014 at 12:46 PM
    #1983
    Yota64
    Okay didn't know that, thank you. I am too cautious to go to max PSI, so that probably won't be a problem.
    Why do wheels have a max? Does a high PSI cause higher chance of bent rims?
  4. Jun 2, 2014 at 12:46 PM
    #1984
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Never in my life have I ever seen a wheel have a max pressure rating. A mass load rating yes but not max pressure.
  5. Jun 2, 2014 at 12:47 PM
    #1985
    Pake13
    Pake13 Well-Known Member
    Pake
    SouthEast Texas
    '11 Tx Pro DCSB,
    Debadged, OME 886 Coilovers, Dakar leafs, All Pro Bed Rack, etc.
    I didn't read all the pages so I don't know if anyone has mentioned the Cordovan Trailcutters!!!
  6. Jun 2, 2014 at 12:51 PM
    #1986
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    I got some tire put on a silverado a few years back. The dumb tech at the shop out in the Max psi of 80 psi. All the way home I felt like I was driving on marbles.
  7. Jun 2, 2014 at 12:54 PM
    #1987
    Yota64
    Oh I know him. I filed a complaint because he put my PSI about 1~2 PSI too low. He must have taken it to heart.
    :p
  8. Jun 2, 2014 at 12:56 PM
    #1988
    Gabassman
    Tyler
    Georgia
    Lol if you wanna have some fun. Remove sway bar and fill the tires to above max and run 80 down the interstate.
  9. Jun 2, 2014 at 12:57 PM
    #1989
    Yota64
    Sounds like a rollercoaster, is that a good guess???
  10. Jun 2, 2014 at 2:33 PM
    #1990
    Gabassman
    Tyler
    Georgia
    I could only imagine. Those two mixed together would be a disaster.
  11. Jun 2, 2014 at 2:42 PM
    #1991
    Yota64
    What is a sway bars function on flat surface? I thought it was for bumps?
  12. Jun 2, 2014 at 2:48 PM
    #1992
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Limits body roll
  13. Jun 2, 2014 at 2:49 PM
    #1993
    BradyT88
    BradyT88 Well-Known Member
    I did that on my 1st trip to Moab. haha Got my 255/85R16 KM2's put on a couple weeks before and Big O's put them to 80 psi. Never realized it until I went to air down on the 1st trail... I run 50 in them on the pavement normally.
  14. Jun 2, 2014 at 2:53 PM
    #1994
    Yota64
    Why do you choose 50?
  15. Jun 2, 2014 at 2:59 PM
    #1995
    BradyT88
    Better rolling resistance (ie better mpg) and center tire wear. I do so much offroading that my alignment is always hammered so I have a lot of side wear on my tires. When I put it up to 50 after getting the alignment back on it gets me riding on the center of the tires again where I have the most tread left.
    My fronts got hammered in Moab last week though... Jacked up my toe pretty bad and it ate my tires up pretty good in about 150 miles...
  16. Jun 2, 2014 at 3:02 PM
    #1996
    Yota64
    What if your alignment is correct and you don't offroad, would you still recommend 50?
  17. Jun 2, 2014 at 3:19 PM
    #1997
    BradyT88
    :notsure: Better rolling resistance which will improve mileage. You wil notice it rides rougher and you may have uneven tire wear. I am so heavy that I don't really have an issue with those last 2 though.
  18. Jun 2, 2014 at 3:43 PM
    #1998
    Gabassman
    Tyler
    Georgia
    Off road you don't want to run anywhere near 50 that would be a really rough ride. For dd somewhere in the neighborhood of 32-50 depending on tire size and vehicle weight. For off road just depends on the terrain. I'll run 20 or less
  19. Jun 2, 2014 at 7:25 PM
    #1999
    BradyT88
    Yeah I only run 50 on road. Offroad I run 20 or 25 psi. 25 psi is a little rougher but I keep eating tires are 20 psi due to my weight...
  20. Jun 3, 2014 at 5:28 AM
    #2000
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    I think someone was talking about tires, not wheels, having a max pressure rating. I've always seen it described as 3500lbs @ 50psi or something to that effect.
    To all the other comments about pressures on and off-road. I stick with near OEM (slightly over inflated) pressures. I'm at 40 all around right now. I haven't been offroad with these tires but I'd probably bring it down to near 15psi. I've always run between 10 and 15 on regular (non beadlock) wheels and had great luck. I've never slipped a bead yet.
    In the past couple years though I've been wheeling a frankenstein buggy which has beadlocks so I'm usually in the 4 - 8psi range. I've been down to 3 but there's too much flex in 38.5x11 tires when they're that low so I usually keep it barely north of 5psi for anything other than super slow rock crawls and sand.
