255/85 R16 Owners Experience
Discussion in 'Wheels & Tires' started by rsbmg, May 8, 2011.
255/85 R16's?
Poll closed Jun 7, 2011.
  1. My tire of choice has worked great in all conditions
    58.3%
  2. Ran em but didn't work for me, went wider and am happy I did.
    16.7%
  3. Ran wide before now run the skinnies and am much happier
    25.0%
  1. Nov 27, 2014 at 12:12 AM
    #2401
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Again?
    Where did you try to buy from? Could be they were just out of stock for the moment.
  2. Nov 27, 2014 at 9:53 AM
    #2402
    Salt
    Salt ...
    Lyons, Colorado
    12' DCORSB TRD
    SnugTop XV with yakima rack. Factory Cab roof rack. Full bedrug. Debadged. Full OME suspention kit, 866's & Dakars. SPC UCA's. Slee Sliders. ARB front bumper w/ M8000 Warn winch. FJ TRD Wheels. Cooper ST Maxx, 255/85r16
    I purchased mine from a local shop. Based on your question you need to inquire with a local retailer or contact Cooper directly.
    Good luck. I would buy the ST Maxx again.
    Salt
  3. Nov 27, 2014 at 11:49 AM
    #2403
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Cant find em locally or online. TireCrawler says they are on natl backorder.
  4. Nov 28, 2014 at 3:51 PM
    #2404
    whapworth
    whapworth New Member
    2008 Tacoma TRD OffRoad DoubleCab 6spd
    Bilstein coilovers, add leave rear
    hi all,
    just mounted 255/85/16 with about a 2 inch lift right now.
    they're great, much to say but trying to figure out highway psi.
    does this look right? seems very low:
    KM2's: 3415 @ 80psi x 4 = 13660 total capacity
    2008 TRD Double Cab Short Bed: 4220 curb weight = ~30% of total tire load capacity
    so 80psi x .30 = 24.7psi
    running at 34 right now just to get home. was gonna try chalk test...but always a crap shoot.
    any insight much appreciated
  5. Nov 28, 2014 at 4:05 PM
    #2405
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    These are some pressures that people have posted to give you an idea. I believe im running 35psi all around, but thats not neccesarily right, but i havnt had time to do the chalk test.
    24.7 does seem low though
  6. Nov 28, 2014 at 4:11 PM
    #2406
    Maxx
    Maxx Well-Known Member
    PSI vs load is not linear. Check for load charts based in the type of tire you use now. I think I posted links to charts earlier in this thread.
  7. Nov 28, 2014 at 4:38 PM
    #2407
    whapworth
    Thanks all.
    generally pretty good on forums but after about 50 clicks and 10 searches still coming up short. really sorry to bother and bee a noob, but if anyone has a link to the load chart for the KM2's would be much appreciated. just read through the thread in wheels in "what my psi...", and only take away seemed to be the chalk test
    maxx found load charts for the toyo, pretty complicated PdF, was that what you were referencing.
    and totally makes sense that it's not linear
  8. Nov 28, 2014 at 7:15 PM
    #2408
    bzzr2
    bzzr2 Well-Known Member
    tread depot had them back in stock today - but when i called they only had 6.. i spoke to cooper manufacturing last week and was told they were being made at that time and that workers were working over the thanksgiving wknd doing a big run in this size. i ordered some today for my jk!
  9. Nov 29, 2014 at 6:17 AM
    #2409
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    The chalk test is the only accurate feedback that you can use. The issue of temperature also comes into play. My pressure goes up with the temp as the compound is definitely softer in the summertime. With Cooper Discoverer S/T I run about 48 when it is single digits and close to 60 when it gets around 90 in the summer. I run about 20 when I hit the trails.
  10. Nov 29, 2014 at 9:50 AM
    #2410
    scollins
    scollins Well-Known Member
    Scott
    Renton WA
    2019 Ford F450 STX 6.7L Powerstroke
    The chalk test is not an accurate measure of proper inflation. Just because a tire sits "flat" on the road doesn't mean it is inflated properly.
    The load carrying capacity of the tire is strictly based on the pressure inside the tire. And we know what those capacities are based on tire pressure. This should be a good starting point to make minor adjustments from.
    Here is a detailed post I created talking about tire pressure, tire construction and load capacity: http://www.tacomaworld.com/forum/wh...onship-between-psi-load-lt265-lt255-data.html
    There is a link to the Toyo website with load tables in my post. Towards the end of the PDF are TRA specifications for all tires. These are not specific to Toyo tires, but to ALL tires made to the specification. An LT255/85R16 Load Range E tire from Toyo, Cooper or BFGoodrich will have the same load carrying capacities.
  11. Nov 29, 2014 at 9:53 PM
    #2411
    TacoBrah
    Sean
    Only 2 left. You got the last set of 4 lol.
  12. Nov 30, 2014 at 10:53 AM
    #2412
    bzzr2
    Wasn't me that got them, somebody else got lucky I guess! I ended up ordering mine from a shop a few hrs away in my previous city, ended up being$375 less than tread depot for 5 including install.
    Hope you find some soon if you're still looking! They should be hitting the shelves all over very soon.
  13. Dec 2, 2014 at 7:06 AM
    #2413
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Ok so I'm going to get a icon 3" C/O lift for my 2015 DCSB tacoma and was wondering if the 255/85/16 km2's would fit on stock off road rims would I need to trim or should I be ok?
    Thanks, Andrew
  14. Dec 2, 2014 at 7:14 AM
    #2414
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    You'll be fine. maybe minor plastic trimming at MOST
  15. Dec 2, 2014 at 7:17 AM
    #2415
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    No trimming needed for me with the billy and AAL lift
  16. Dec 2, 2014 at 10:57 AM
    #2416
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Thanks guys and is that including going offroad on trails and what not?
  17. Dec 2, 2014 at 11:49 AM
    #2417
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    I respectfully disagree on several points, but find your post about tire inflation and load to be quite impressive.
    The chalk test is not only accurate feedback, displaying the amount of contact with the road surface, but it can be done quite easily in a variety of environmental conditions.
    When done with a bit of common sense, it is a great guideline. I would suggest starting at a high pressure and driving under acceleration, braking, and both left and right hand turns at low to moderate speed to determine when you have full patch contact. Continue lowering the pressure until this is achieved.
    From my work at a rubber compounding/forming company, which included custom tire fabrication, you should be well above the load requirement when you achieve full contact. Drop another 5 percent from that value and you should have even wear and a safety factor for loading so that a pothole doesn't cause rim damage.
    Additionally, I was wondering what you used to determine the load requirements? Did you use min or max loading? What kind of lateral acceleration values, and what kind of a modifier for a lifted truck versus stock? Are you assuming that all four wheels are loaded, or did you use three in the case of off-roading or blowout? When off-roading I have teetered from one group of three, onto two while tipping then onto three as the center of gravity shifted, but the speed was less than one mph.
    Did you see my comment about temperature? Generally, manufacturer's make charts for ambient temps of 70F or 75F, and rely on a safety factor for a usable range of -20F to 120F. The compounds are weaker as the temperature climbs, and a surface temperature above 240 typically causes the lubricants to boil off.
    I think if you run a D-rated or E-rated tire below 40psi at speeds above 50mph you will see a lot of premature wear, some pretty poor mileage, as well as fatigue cracking on the sidewall.
  18. Dec 2, 2014 at 8:57 PM
    #2418
    scollins
    Scott
    Renton WA
    Funny, because I think we are both at the same conclusion, based on your last comment. If I do a chalk test, with my rear axle weight of 2100lbs (static split of 1050 lbs per tire on the street), the amount of pressure that results in an "even" chalk wear is likely well below the table-calculated pressure. And many here are below 40 even with lots of freeway driving.
    And everything is a compromise, so the ideal pressure when traveling a freeway at 70 MPH is quite different than what is needed in an extreme off-road situation. Many Euro cars say to increase pressure to max for any extending driving over 100.
    In the end though, I doubt any manufacturer uses a chalk test to develop their pressure specs. Even acknowledging that they aren't looking for longest tread life but "safest" operation.
    Best advice should be a combination of methods. Use the chalk test, but make sure the minimum pressure is still within guidelines. LT tires start at minimum 35 psi, and even running LR-E tires on a Tacoma, 40psi would be a good starting point.
  19. Dec 6, 2014 at 3:06 AM
    #2419
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Do you have wheel spacers or not? That's look I really am aiming for!
  20. Dec 8, 2014 at 8:19 AM
    #2420
    Boulder Taco
    Boulder Taco Well-Known Member
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    3" ToyTec Lift D.C. 285/75/16's ProComp ES9000 Shocks Avid Light Bar / Sliders Hella Black Magic Fog Lights Black Badges + Black Grille ARE Topper Sockmonkey TRD Decal Bulletproof Fab. TRD Skid Plate Blacked Out Rear Bumper
    Any pics?
