255/85 R16 Owners Experience
Discussion in 'Wheels & Tires' started by rsbmg, May 8, 2011.
255/85 R16's?
Poll closed Jun 7, 2011.
  1. My tire of choice has worked great in all conditions
    58.3%
  2. Ran em but didn't work for me, went wider and am happy I did.
    16.7%
  3. Ran wide before now run the skinnies and am much happier
    25.0%
  1. Mar 17, 2015 at 8:04 PM
    #2601
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    I did it for years. Hell I was on my 3rd set of 255s before I lifted
  2. Mar 18, 2015 at 10:00 AM
    #2602
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Seems this needs a fresh re-posting in this thread:
    A suspension lift (coilover, lift springs, spacer, etc.) only changes where the tire is at ride height, it does not change the overall range of travel of the tire.
    There are three scenarios:
    1. Stock height - this potentially requires some or all of the following; trimming, proper alignment adjustment, cab mount chop, and proper backspacing to prevent rubbing when street driving and at full lock.
    2. Lifted, street only - if lifted you can run this size with minimal adjustments if you never leave pavement.
    3. Lifted, off road - see #1 to eliminate rubbing through full tire travel
    I'm gonna keep repeating this information until I'm blue in the face because it's probably one of the most misunderstood facts about tires and lifting. Unless you have a drop bracket or SAS for a lift you are not changing the range of motion of the tire.
    Crom likes this.
  3. Mar 18, 2015 at 10:55 AM
    #2603
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Yes, keep repeating this. I don't understand what is confusing about this.
    With most suspension lifts, all we are doing is pushing the tires down in their stock travel. This means less droop and more compression. You will still rub the same amount, it just depends on where your tire is at the time.
    Crom likes this.
  4. Mar 18, 2015 at 11:00 AM
    #2604
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    no worries. i just had to trim a bit and im at close to 3 inchs. so im assuming you just have to trim alot with that on stock suspension. idk? idc actually glad mine looks good and rides nice.
  5. Mar 18, 2015 at 11:24 AM
    #2605
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    bingo, you can if you wanna just get the plastic out of the way.
  6. Mar 18, 2015 at 4:21 PM
    #2606
    PyriteMica
    PyriteMica Member
    SR5
    To those that have used the Sr5 steelie, any rub on a stock UCA? I see most reports of trd off road rims clearing and steelies clear on the pavement but steelies/stock uca stuffed? Any contact other than plastic?
  7. Mar 18, 2015 at 5:54 PM
    #2607
    buzzhead8189
    buzzhead8189 Well-Known Member
    Matthew
    TEXAS!
    04 V6 4x4 Manual Everything
    Icon Coilovers and Rear Resi, Dakar Springs, CBI Sliders, Homemade Rear Bumper
    My experience since yesterday, damn these are quiet!
  8. Mar 19, 2015 at 4:57 PM
    #2608
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Sweet, any reason u ditched OR rims for the spares? Just that those are quit a few pounds more than the alloys.
  9. Mar 19, 2015 at 7:58 PM
    #2609
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    I always liked the spare rim look. Before you decide to switch back to the alloys, weigh them. I thought they were near the same weight as the steel ones.
  10. Mar 19, 2015 at 10:23 PM
    #2610
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    onto set #2
    Crom likes this.
  11. Mar 20, 2015 at 1:51 AM
    #2611
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Those are both 255's?! Incredible difference in size mounted and worn if so...
  12. Mar 24, 2015 at 2:53 PM
    #2612
    luka
    Kailua, HI
    yup, the new wasn't mounted so actual height is wrong, but the wear difference is huge.
  13. Mar 25, 2015 at 7:04 PM
    #2613
    Wolftaco
    Wolftaco Well-Known Member
    Luke
    Philadelphia, PA
    06 Overland Build
    Old Man Emu, Leer 100cc, Blacked Out Billet Grill, ARB Bumber, Warn M8000-s winch with under hood solenoid relocation, Stubbs HD Standard Sliders, diff breather
    Wow what a size difference! How much mileage you get on that first set? I am thinking of getting Toyo MTs, you must really like em to be on your second set. I have the M55s and love them. I am in need of extra set of some mud tires for an upcoming backcountry adventure and am leaning towards the Toyos over BFG KM2 for the tougher sidewalls.
  14. Mar 26, 2015 at 9:48 AM
    #2614
    luka
    Kailua, HI
    I'm mostly around the 16.5mpg range with all the armor/stuff with stock gearing, I've noticed that my ultra-gauge is now showing a higher avg mpg on the highway with the new tires...maybe the old ones being as bald as they were started to impact rolling resistance.
    I've always been interested in the M55, but haven't really found any place local that carries them.
    I actually wanted to get some ko2's in the 34x10.5 which comes out to about the same overall size as the Toyo's...but I'd have to get a set of 17" rims and where I live makes it a pain in the ass to just up and change tire sizes. (google Recon in Hawaii)
    while the process isn't difficult, I just don't have the time to do it.
    maybe next year i'll get a second set of AT's for regular commuting and save my MT's for camping in the mountain.
  15. Mar 26, 2015 at 9:59 AM
    #2615
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    Was able to get my hands on a set of BFG KM2. Americas Tire had em shipped from one of their stores in Florida.
  16. Mar 26, 2015 at 10:04 AM
    #2616
    Large
    Large Red
    Please provide me a link for those mirrors!!!!!!!!
  17. Mar 26, 2015 at 10:15 AM
    #2617
    916TacoTruck
    Inyo mom
    2019 Rapturd
  18. Mar 26, 2015 at 10:34 AM
    #2618
    Large
    Large Red
  19. Mar 26, 2015 at 1:58 PM
    #2619
    crazy joker
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    :jellydance: of the doors and of Sacramento. Grew up there and visit whenever I can.
    Crom likes this.
  20. Mar 26, 2015 at 2:05 PM
    #2620
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    Does anyone know if the km2's have enough rubber on them to regroove? I have 8 255/85's and wouldn't mind grooving the set not on the truck
