255/85 R16 Owners Experience
Discussion in 'Wheels & Tires' started by rsbmg, May 8, 2011.
255/85 R16's?
Poll closed Jun 7, 2011.
  1. My tire of choice has worked great in all conditions
    58.3%
  2. Ran em but didn't work for me, went wider and am happy I did.
    16.7%
  3. Ran wide before now run the skinnies and am much happier
    25.0%
  1. Jul 6, 2015 at 8:31 PM
    #2741
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Chains have a great number of sizes available. The tire dimensions seem to be a little different for each brand. You will be more successful if you pick the tire first. Quality chains have customer service pages and 800 numbers to insure a good fit. If you need chains, do not be foolish enough to risk your life to save a few dollars. You may need wheel spacers to add clearance for the front suspension. Quality chains will also not turn into a ball of rust, especially if you use a little soap and water.
  2. Jul 6, 2015 at 9:01 PM
    #2742
    BradyT88
    BradyT88 Well-Known Member
    My chains that fit my stock 265/70R16's fit my 255/85R16 KM2's although just barely. I've yet to need to use them though. My KM2's aired down have got me through everything so far.
    I did test fit the chains though to know they work. Takes a lot more work and time than though them on the stock all terrains.
  3. Jul 7, 2015 at 4:23 AM
    #2743
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I thought i had read on tw somewhere that chains will rub upfront even with 265's, i live in alabama so i dont have to worry about that much but also most of the tires in this size are studded would that be a possible alternative?
  4. Jul 7, 2015 at 3:48 PM
    #2744
    csellison
    csellison Comatose!
    WV
    05 Reg Cab 4cyl 5speed
    ARB bullbar, smittybuilt 9.5k ,255/85/16 Cooper ST, Body Armor Rear bumper with tire carrier, Billy 5100 with OME 885 and 2 inch AAL, Toolbox, bed mounted High Lift with All Pro mounts.
    Traded up to 14 extended cab. Finally got the 255's on
    14489 likes this.
  5. Jul 7, 2015 at 5:14 PM
    #2745
    yota243
    E.J.
    north Alabama
    Everyone on stock gears are u doing ur oil change intervals by odo or actual miles on 5000 miles at 7.5% thats an extra 375 miles. Not huge but i go 6k change the filter and go another 6k and do a full change so that would be like 800 miles right? I may go 5k and 5k by odo from now on just gettin everyone elses thoughts
  6. Jul 7, 2015 at 5:34 PM
    #2746
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I ended up going from 8000km to 5000km intervals using the ODO. For me its just easier to keep track of and with the tires, armor, and short commutes that I do, it cant hurt anything but my wallet. Also, if I cant get to the oil change right away I have a bit of leeway.
  7. Jul 9, 2015 at 1:31 PM
    #2747
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Hey guys just a quick question. I have stock TRD OR wheels and my 255/85 ST Maxx tires rub the front side of my uca's. Does anybody else have that issue or is is possibly an alignment issue?
  8. Jul 9, 2015 at 1:45 PM
    #2748
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Thanks, I'll have them redo the alignment and see what happens.
  9. Jul 9, 2015 at 1:48 PM
    #2749
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I was thinking the same thing too. The alignment they did last time doesn't look right so I need one anyways.
  10. Jul 9, 2015 at 2:10 PM
    #2750
    yota243
    E.J.
    north Alabama
    u rub anywhere on ur ride ryan? i have a spot about 1" and the width of a pencil on my frame from full lock and reverse, its not a big deal since its just the tip of the lug and its pretty much just knockin the dust off but i thought since we have the same set up urs might do it, or our alignment may be a little different
  11. Jul 9, 2015 at 2:52 PM
    #2751
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    I too am irresponsible.:anonymous:
    What brand of UCAs do you have?
    If the ball is fixed, they may not be able to get you 2-1/2 to 3 degrees of caster if they can only adjust camber on the LCAs.
  12. Jul 9, 2015 at 2:58 PM
    #2752
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I have stock UCAs currently.
  13. Jul 17, 2015 at 11:24 AM
    #2753
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    It's probably here somewhere but I wanted to see how you guys feel about the perceived power loss that you get stepping up to this size of tire (and weight).
    I understand that there is a MPG loss with this tire combo, but I don't want it to make the V6 feel like a dog by adding a tire of this size.
  14. Jul 17, 2015 at 11:39 AM
    #2754
    yota243
    E.J.
    north Alabama
    i like the way it feels now, its definately a lil slower but usually putt-putt around anyway so i dont notice it too much and it looks like i only lose 1 mpg moving up from 265/75. i would image it would be significantly great get up and go with 285's due to the weight, but i really cant say that for sure i guess. plus i can run 70 mph now at like 1900 rpm. i imagine my hwy mileage would actually increase a bit due to that fact. it is a truck tho and i didnt really buy it for speed, but i may one day build it for that ha
  15. Jul 17, 2015 at 3:01 PM
    #2755
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    It won't be a dog, but you will lose some peppiness.
    Mine still spun the tires when I stomped it once (empty) to test on worn concrete, and I ran it many times across Pennsylvania with half a ton on it using the turnpike which has some pretty good hills that drag down tractor trailers to 35~45 range while I was able to stay at 65.
    I have a set of stock Rugged Trails that I picked up to test the ABS witch hunt that went on this past winter, and at 265/70/16 it is peppier than my Cooper S/T 255/85/16s. Mileage with the stock tires is 2~3 MPG better, and I have full skids, sliders, and ARB bumper with winch using 700# coils.
    Edit: The Coopers are roughly 20lbs heavier than the stock tires.
  16. Jul 17, 2015 at 3:09 PM
    #2756
    yota243
    E.J.
    north Alabama
    Filled up today about 100 niles was interstate 70-75 mph the rest was 21 mile commute back and forth to work
  17. Jul 19, 2015 at 10:18 AM
    #2757
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I got to test out my tires a little better this weekend. I love them so far. This is one of the only pictures I got.
    Crom likes this.
  18. Jul 19, 2015 at 10:31 AM
    #2758
    snowmanwithahat
    That stuffs nicely. Any rubbing? Looks like there isn't any
  19. Jul 19, 2015 at 10:35 AM
    #2759
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    No rubbing at all. This is the perfect size tire for somebody that doesn't want to trim anything.
  20. Jul 19, 2015 at 11:01 AM
    #2760
    snowmanwithahat
    Stock suspension too?
