255/85 R16 Owners Experience
Discussion in 'Wheels & Tires' started by rsbmg, May 8, 2011.
255/85 R16's?
Poll closed Jun 7, 2011.
  1. My tire of choice has worked great in all conditions
    58.3%
  2. Ran em but didn't work for me, went wider and am happy I did.
    16.7%
  3. Ran wide before now run the skinnies and am much happier
    25.0%
  1. Jan 31, 2016 at 5:11 PM
    #3241
    imageomega
    imageomega Well-Known Member
    Jarrod
    You can put a 235 on 8.5s. Not sure why anyone would... but 255 wouldn't be a legal/shop limit, just a potential logic limit.
  2. Feb 1, 2016 at 9:35 AM
    #3242
    nels
    nels Member
    Denver
    2012 GX460. Sold: 2016 Super White TRD Off Road 4x4. Sold: 99 TRD V6 4x4 OME
    None
    BFG KM2 on 16" scs F5. Couldn't be happier.
  3. Feb 1, 2016 at 9:36 AM
    #3243
    imageomega
    Jarrod
    ^^ Looks great
  4. Feb 1, 2016 at 9:38 AM
    #3244
    nels
    nels Member
    Denver
    None
    Thanks!
  5. Feb 2, 2016 at 9:14 AM
    #3245
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    Anybody have experience with Maxxis Bighorns?
  6. Feb 2, 2016 at 9:17 AM
    #3246
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Yep. Lots of us
  7. Feb 2, 2016 at 9:28 AM
    #3247
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    yup here too. I will let you know that if you stop in some soft sticky mud (or in my case your wife stops) and ur 2wd and did not engage the locker before entering said soft sticky mud, and can't move much to get the locker engaged, by the time you spin and wiggle enough to get the locker on, u may need assistance getting out of your hole. But I have personally never gotten my truck stuck with these as long as you keep some momentum, they clean out well and keep you moving.
  8. Feb 2, 2016 at 9:42 AM
    #3248
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    PlastiDip
    How are they? How many miles cab u get out of them? Pics? Lol
  9. Feb 2, 2016 at 9:45 AM
    #3249
    TacoFMS
    Justin
    Louisa County, VA
    No clue on mileage. I run 2 separate sets of wheels and tires. Only run those when I'm planning on going for a ride. I will say I would definitely be buying another set if they were offered in the size I want. But sadly they are not so I have to go with something different. I have always been pleased with their performance though.
    Pics are in my build thread.
    k3v11n likes this.
  10. Feb 2, 2016 at 9:49 AM
    #3250
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    PlastiDip
    Any idea how they perform in the rain? I'm not lucky enough to have 2 sets of wheels. Lol. And the lady drives the truck on some occassions when I need a designated driver. Lol
  11. Feb 2, 2016 at 9:54 AM
    #3251
    TacoFMS
    Justin
    Louisa County, VA
    Like most mt's. Bit slippery compared to an at, but they are somewhat siped so that helps.
  12. Feb 2, 2016 at 10:45 AM
    #3252
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Last week, dished out some more punishment, Toyo MTS, hanging tough in the rocks. Wheeled a historical stagecoach wagon route through the rocky Jacumba Mountains.
    Very tight.
    18-PSI
    Trail is extremely rocky.
    Sidewalls took a heavy beating. This was from 3/4 of the way into a trail, and exit route was same as origin.
    Rear wheels got some new rock rash. lol
    It will be six months of ownership this month. Loving the tall and skinny.
  13. Feb 2, 2016 at 2:02 PM
    #3253
    NDK81
    NDK81 Active Member
    Northern NM
    97' Taco
    OME Suspension Kit, AFE Filter, Deck Plate Mod 235/85 16 on 16 hole spares.
    My boss does about 20k miles a year on his Dodge 2500 diesel work truck and replaces them every fall at about 25% tread left. I have heard they are good tires but soft so they don't last long. On lighter rigs like Jeeps and Tacomas I've read 30-35k before they wear out. They tend to do better as a dedicated off road or mostly off road tire.
    k3v11n[QUOTED] likes this.
  14. Feb 3, 2016 at 10:35 AM
    #3254
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    I started researching and this is what I have figured out, which SPC has confirmed. Increasing caster from lower arm adjustment cams will roll the lower ball joint forward, which pushes your tire forward. Increasing caster from the UCA rolls your ball joint back, which pushes your tire toward the cab mount. So to compensate for rubbing you need to max out your caster from the LCA and then fine tune it from the UCA. Moving the LR ball joint setting to the -1 position (+1 degree of caster compared the 0 ball joint setting that yields +2 degree of caster) would give you more clearance from the cab mount. This will only work if you have maxed out you lower arm adjustment cams.
    arkywally and Crom like this.
  15. Feb 3, 2016 at 10:52 AM
    #3255
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Hmmm, interesting. When I did my adjustments in the driveway my lowers weren't maxed out and I still gained significant clearance from the cab mount by adjusting the from the caster from the UCA.
    So does that confirm that when you adjust caster the center pivot point of the axle is moving forward and back? I always assumed that it stayed somewhat stationary as shown in the diagram I posted, if it is moving, I am curious as to how this affects CV wear if the CV axle is angled forward or back vs up and down. Then again maybe a couple of degrees doesn't matter that much.
  16. Feb 10, 2016 at 1:51 PM
    #3256
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Anyone seen a good price on the Cooper ST Maxx in this size currently? I got a set of first Gen wheels powder coated and looking for a set of "skinnies".
  17. Feb 10, 2016 at 2:30 PM
    #3257
    zscott
    Zach
    Utah
    I just spent a good couple of weeks searching. The only place that had them (in stock) was Amazon. I ended up switching sizes and when I had them mounted the guys at Discount said there was a big backorder for the ST Maxx in the 255 85 16 and many other brands were also hard to come by.
    I am sure they can be found but you likely wont find much for less than 250-260/tire.
  18. Feb 10, 2016 at 2:34 PM
    #3258
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
  19. Feb 10, 2016 at 2:37 PM
    #3259
    zscott
    Zach
    Utah
    Hopefully they actually have them. I called to verify a couple weeks ago and although they say in stock but didn't have any actually available. There was a back log till they could ship.
    Not a bad price though. Maybe they got a bunch in and prices will go down.
    edit: they only have 2 in stock.
  20. Feb 10, 2016 at 3:14 PM
    #3260
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    I ordered a set of 4 from Tire Liquidators here in town. Took them 5 days to get here. I paid $1121.77 out the door with mounting, balancing and warranties.
    Discount Tire was 20 or so bucks cheaper per tire, but they wanted $40 a tire for certs as opposed to the $18 I paid at TL. Discount quoted me $1115 out the door and had no clue when they would be able to get them.
    Only thing I really regret is not buying the 5th tire for the spare. Didn't think it would be so hard finding a same sized decent used tire for a spare.
