255/85 R16 Owners Experience
Discussion in 'Wheels & Tires' started by rsbmg, May 8, 2011.
255/85 R16's?
Poll closed Jun 7, 2011.
  1. My tire of choice has worked great in all conditions
    58.3%
  2. Ran em but didn't work for me, went wider and am happy I did.
    16.7%
  3. Ran wide before now run the skinnies and am much happier
    25.0%
  1. Aug 20, 2018 at 4:36 AM
    #4541
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    @JimboAnz new to the scene, just changed my UCAS last month, had no idea that was an issue, thanks for the heads up. I’ll add it to my preventative maintenance list.
    toysrgood and JimboAnz[QUOTED] like this.
  2. Aug 20, 2018 at 4:38 AM
    #4542
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    or locktight them suckers. if they are installed the way they came out, they cannot fall out even if the nut comes off. when installed backwards, if nut falls off, gravity may take over, and it may slide out. just a heads up. always need to check nuts / bolts on a regular basis :thumbsup:
  3. Aug 20, 2018 at 4:43 AM
    #4543
    mcharfauros
    MO
    Dumb Truck Thangs
    @JimboAnz Good stuff, good eye, I see what you’re talking aboutnow, fortunately I Installed the bolt the same way it came out. Even so, I’ll still keep an eye on it! Appreciate the feedback! Was talking to some buddyies Chandler and Gary up in the St. Louis area this past weekend, and they mentioned they went wheeling with you at some point. Small world.
    JimboAnz[QUOTED] likes this.
  4. Aug 20, 2018 at 4:46 AM
    #4544
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    10-4 man. Likely over at Black Mountain in Harlan KY last year, or AOP, or Windrock :cheers:
    mcharfauros[QUOTED] likes this.
  5. Aug 20, 2018 at 6:00 AM
    #4545
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    In general yes. There might be some metal hammering to be done as well. If you're way back in the wheel well you'll need to do a cab mount chop.
  6. Aug 20, 2018 at 7:50 AM
    #4546
    NOLAMedic
    NOLAMedic Well-Known Member
    2018 Quicksand DCLB TRD Off Road
    I HOPE that won’t be an issue after adding lift. Currently, it doesn’t rub.
  7. Aug 20, 2018 at 8:52 AM
    #4547
    PCTaco
    Adam
    New Columbia, PA
    Working on it
    Depends on geometry. Mine doesn't rub during normal operation but I get some rubbing at full stuff in a turn.
  8. Aug 23, 2018 at 9:42 AM
    #4548
    Loneknight5
    Loneknight5 Well-Known Member
    Kyle
    DFW, Texas
    TRD OFFROAD
    I hate being this guy but is anyone running these on a stock 2015?
  9. Sep 3, 2018 at 9:37 AM
    #4549
    SpeySquatch
    2016 TRD OR DCSB
    What size would that be on a 16” wheel? Or are you talking about a 17” wheel?
  10. Sep 3, 2018 at 9:39 AM
    #4550
    SpeySquatch
    2016 TRD OR DCSB
    Toyos are a lot heavier and a bit overkill for these trucks
    ecgreen[QUOTED] likes this.
  11. Sep 10, 2018 at 5:44 AM
    #4551
    Sky_Hawk25
    Sky_Hawk25 Well-Known Member
    2014 MGM Tacoma
    Tried to read a lot of this thread but didn't see my exact question asked, so my apologies if this has already been asked.
    I have an 2nd Gen 2014 SR5 w/ stock suspension and am looking at switching to stock 2018 TRD OR rims [16x7].
    I know I can mount these rims on my 2014, my question is can I run 255/85/r16 tires on my stock SR5 suspension w/out rubbing or trimming required?
    Anyone who has this set up who can provide some info and pics would be great. Thanks in advance for any help/knowledge.
  12. Sep 10, 2018 at 5:48 AM
    #4552
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    it is buried in here, but a guy got away with 255/80R17 on stock trd sport rims and suspension. He ran it for a couple weeks till his lift came in. So I say its doable just brace yourself for the chance of rubbing at extreme lock and bump (no mobbing over speed bumps). Def will have to ditch the front mudflaps, or heat gun and flatten/trim them.
    really 265/75R16 (265/70r17) is the only size that you can run on stock suspension, probably could get away with 255/75R17 as well.
  13. Sep 10, 2018 at 5:54 AM
    #4553
    Sky_Hawk25
    2014 MGM Tacoma
    Thanks for the info. Do you know if that was a 2nd gen or 3rd gen by chance?
    Hopefully someone who has some first hand experience of the 2nd gen set up I am looking at will see this and chime in.
  14. Sep 10, 2018 at 6:10 AM
    #4554
    jztacoma
    Upstate NY
    Semi Stockish
    wanna say his was a 2015.. but def a 2nd gen... it was a couple pages ago so start going backwards, think it was a white Tacoma.
  15. Sep 10, 2018 at 6:19 AM
    #4555
    jztacoma
    Upstate NY
    Semi Stockish
  16. Sep 10, 2018 at 3:03 PM
    #4556
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
  17. Sep 10, 2018 at 3:06 PM
    #4557
    nelztaco
    Neil
    Levittown, PA
  18. Sep 27, 2018 at 3:59 PM
    #4558
    TacoCruiser
    TacoCruiser Starting over
    Bobby
    1999 LC / 2019 TRD Pro
    Stock
    What's going on here? Is that a stock Sport with 255s?
  19. Sep 28, 2018 at 6:05 PM
    #4559
    nelztaco
    Neil
    Levittown, PA
    Eibach coils up front and the rear leafs were upgraded from 3 leaf to 4 leaf by toyota. That’s it. Stock control arms. The tires barely fit... but they fit!
  20. Oct 16, 2018 at 5:43 PM
    #4560
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    2008 Tacoma PreRunner with billy's set at the top perch that gives about a 2.5" lift upfront is paired with 17" FN Pro wheels with a 0 offset.
    Does anyone know if 255/80/17 Cooper STT Maxxs will fit without doing the cmc?
