255/85 R16 Owners Experience
Discussion in 'Wheels & Tires' started by rsbmg, May 8, 2011.
255/85 R16's?
Poll closed Jun 7, 2011.
  1. My tire of choice has worked great in all conditions
    58.3%
  2. Ran em but didn't work for me, went wider and am happy I did.
    16.7%
  3. Ran wide before now run the skinnies and am much happier
    25.0%
  1. Apr 9, 2014 at 1:21 PM
    #1841
    jameskhana
    jameskhana Maibatsu Monstrosity
    James
    Dallas, TX
    2007 DCSB Base 4x4 6spd
    Np! I figured some of the 255 guys would be interested to see the comparison.
    FWIW I've heard Toyos always run a little bigger than their specs indicate. I should have rolled it out and put it next to my 285's...then I bet it would have looked more like a true pizza cutter.
  2. Apr 9, 2014 at 1:22 PM
    #1842
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    This is from a guy on Expo Portal.
    Toyo M/T 285/75/16 v. Toyo M/T 255/85/16
  3. Apr 9, 2014 at 3:11 PM
    #1843
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    My 255 km2's make 285 toyo Mt's look like baby tires they are so much larger in diameter.
  4. Apr 9, 2014 at 3:16 PM
    #1844
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    a/t or m/t whichever one i can get the best deal on I'm slapping on meh rig..
    That pizza cutter looks a bit bigger than the 285. Intresting.
  5. Apr 9, 2014 at 5:54 PM
    #1845
    jameskhana
    James
    Dallas, TX
    1/2" taller according to Toyo's specs...33.5 vs 33.0
  6. Apr 9, 2014 at 5:59 PM
    #1846
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    285/75/16 is only 32 3/4" , no ?
  7. Apr 9, 2014 at 6:07 PM
    #1847
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    yeah the 255 should be a tad bit taller than the 285. Ive put my worn out 255/85 cooper st spare up against my 33/10.5/15 and the worn down cooper is the same height as the brand new 33/10.5 km2
  8. Apr 9, 2014 at 7:42 PM
    #1848
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    What are the main differences going to be for running a 255/85 load E vs Load D or C?
  9. Apr 10, 2014 at 5:14 AM
    #1849
    Mainmoe02
    Moe
    Austin, Texas
    I think this is the answer...
    Load range E = 10 ply
    Load range D = 8 ply
    Load range C = 6 ply
    Atleast this is what I've seen the trend is when comparing different load ranges. Also, the more ply the heavier the tire.
  10. Apr 10, 2014 at 5:58 AM
    #1850
    XXXX
    sKiP
    05 Prius
    that would be 1/4" taller...
    diameter / 2 = height difference
    Probably. 285's are small. My 255's make 285's look like stock tires.
    Weight capacity and ride comfort.
    The more weight capacity the stiffer the ride.
    No such things. That chart explaining plys was good 50 years ago but not today.
    You find me a new off the shelf brand name 255/85/16 tire meant for a truck that has 10 plys and Ill send you $100.00 when I get home tonight.
    Ply is an ancient term used in the wagon wheel days. These days the most plys you will get is three with a typical E load tire.
    No one should ever equate load "E" with 10 ply any longer. "E" only refers to weight capacity.
  11. Apr 10, 2014 at 6:06 AM
    #1851
    CanisLupus
    Stokesdale | NC
    Is something like the Toyo M55 just have the "10 ply" designation because it is E rated and is not truly 10 ply? Or did I just get $100...? :rolleyes:
    http://tirecrawler.com/shop/detail_tire.php?product_id=10276&t=GS&gclid=CITbjPD91b0CFcg7Ogod23kAjQ
  12. Apr 10, 2014 at 6:10 AM
    #1852
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
  13. Apr 10, 2014 at 6:26 AM
    #1853
    XXXX
    sKiP
    05 Prius
  14. Apr 10, 2014 at 6:53 AM
    #1854
    CanisLupus
    Stokesdale | NC
    :eek:
    So I see that in the LT chart, it still says "E Rating - 10 Ply".
    Why do they still even put this "ply rating" if LT tires only have two to three plies like the Tire Rack link says?
  15. Apr 10, 2014 at 7:04 AM
    #1855
    BradyT88
    BradyT88 Well-Known Member
    Marketing I'm sure. They can do it because in the fine print it will say "10 ply equivalent" and some people will see it and really think they are 10 ply and 10 ply sounds way better than 3 ply.
    I though bias ply tires still follow the 6, 8, and 10 ply thing though? Interco still makes a lot of Bias ply tires and they rate them as ply count and not so much load range on their site.
  16. Apr 10, 2014 at 7:19 AM
    #1856
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Same reason terms like 1/4 ton and 1/2 ton pickup still exist. They make no sense anymore, but people are stupid and get hungup on terminology.
  17. Apr 10, 2014 at 9:42 AM
    #1857
    TacoBrah
    Sean
    How much more rough is E vs D?
  18. Apr 10, 2014 at 9:45 AM
    #1858
    XXXX
    sKiP
    05 Prius
    3 plys rougher :D
    thats an almost impossible question to answer. in all seriousness do you think any of us have ridden in the same truck with the same weight and different load tires made by the same manufacturer?
  19. Apr 10, 2014 at 10:00 AM
    #1859
    TacoBrah
    Sean
    Makes sense. Just did a search and the tires I have now are E anyways, so if I went 255/85 in E it couldnt be too bad.
  20. Apr 10, 2014 at 5:43 PM
    #1860
    mike2100
    mike2100 Well-Known Member
    Virginia Beach
    TBD
    The tires are 1/2" taller. They give you 1/4" more ground clearance.
