255 vs 265 tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glocker23, Jun 26, 2017.
  1. Jun 27, 2017 at 9:09 PM
    Glocker23
    Glocker23 [OP] Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Ahhh. Ya that can't be good. Currently grabber LT265/70 and am getting about 15-17 mpg. It sucks.
  2. Jun 27, 2017 at 9:10 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I run ST Maxx is 255/85/16. These are NOT light.
    But they are awesome - and quiet.
  3. Jun 27, 2017 at 9:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you went with an LT255, you might notice a slight increase in MPG, but it shouldn't degrade any more than it already is. If you don't do off roading, a P rated tire will help a lot.
  4. Jun 27, 2017 at 9:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When I was loading them in the truck to get mounted, I damn near killed my back because I wasn't expecting them to be 60 lbs each.
    Kyitty[QUOTED] likes this.
  5. Jun 27, 2017 at 9:12 PM
    Glocker23
    CT
    2012 DCSB Sport
    Always liked the LT tires to carry more weight when I need to. Not often but is convenient. Or to have the piece of mind it won't have a problem
  6. Jun 27, 2017 at 9:36 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    A 255/80/17 (or 255/85/16) tire will not improve your gas mileage, at least for stop and go driving. I could be wrong, but I believe the only tires offered in that size are LT tires. My 255 ST Maxx are flippin heavy. I love the tire, but I definitely noticed a reduction in gas mileage as well as take off speed when I made the switch.
  7. Jun 27, 2017 at 10:17 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    He's looking at 255/75r17, and there are a lot more options in that size.
  8. Jun 27, 2017 at 10:29 PM
    backcountryj
    Jonathan
    GA
    You are correct.
    But there has been a good bit of mentioning of the 255/80*85 variety in here as well. Just trying to insure the OP does not get lost in the forest for the trees.
  9. Jun 27, 2017 at 10:44 PM
    Glocker23
    CT
    2012 DCSB Sport
    Honestly wanted a taller tire to fit into stock suspension over my 265/70/17. Wasn't entirely sure what fits so used those as a starting off point
  10. Jun 28, 2017 at 4:19 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Heck, I noticed that many 255s weighed just as much as the 285s I was looking at when I was shopping around.
  11. Jun 28, 2017 at 4:25 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    Did you do the CMC I never did ask?
    boogie3478[QUOTED] likes this.
  12. Jun 28, 2017 at 4:27 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
  13. Jun 28, 2017 at 4:30 AM
    Superman910
    Eric
    Northern Virginia
    Hey I can't remember every video you post, you are like fast and the furious franchise. I have to go back and rewatch and be like "ohhhh so that's what happened". You should make a mashup.
  14. Jun 28, 2017 at 4:34 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
  15. Jun 28, 2017 at 6:48 AM
    #35
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    For the love of god, do not get ST Maxx's for a commuter truck. They suck for city driving and are not worth any sort of "peace of mind".
    Get some P-rated 255/75 AT tires.
  16. Jun 28, 2017 at 9:01 PM
    #36
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Im planning on going with the Cooper AT3 255/75-17 on my 4Runner
