26.7 MPG
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Jun 14, 2022.
  1. Jun 16, 2022 at 3:25 PM
    #61
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it takes time for the ECU to adjust fuel maps/timing advance for the change in fuel octane
  2. Jun 16, 2022 at 3:41 PM
    #62
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    If you’re driving the speed limit that’s fine. If you’re doing 10 miles under with just 3 cars behind you, then you’re being selfish since some people aren’t just sight seeing and have somewhere to be. I don’t know the answer to that but please don’t be one of these lol.
  3. Jun 16, 2022 at 3:43 PM
    #63
    Chugiak76
    Chugiak76 Well-Known Member
    Colorado Springs, Colorado
    2020 Tacoma SR 2.7 4x2, AXC
    That's true, but I don't think it's relevant for a low-medium compression port injected engine that was designed to run on regular. I 100% believe the 2GR in the Tacomas can and does make use of higher octane fuel because it has a higher compression ratio and has direct injectors as well as port. Same for any turbocharged engine. But I know of no mechanism that would enable the 2TR-FE to take advantage of anything higher than 87 octane.
    I used to own a GS350 and I could tell within minutes after I switched from 87 to 90 (highest available in Alaska) or back that something changed, and I clearly preferred the way it ran on 90 as opposed to 87 - no contest. On my 2000 (no longer owned) and my 2020 Tacoma, both with the 2.7L, ran worse on mid-grade gasoline for the entire tank and switching back to the minimum felt better within minutes. I think that's because those engines are clearly engineered for a specific octane. The "it takes time to adjust to higher octane" category I believe is for modern engines that tolerate regular extremely well, but have the capability to take advantage of higher octane if provided.
    I could be wrong about some or all of that, just what I think.
  4. Jun 16, 2022 at 3:58 PM
    #64
    Chugiak76
    I'm NEVER that moron going slow in the passing lane. That's not only incredibly stupid, but dangerous as well. If I am going 10 mph under the speed limit, and there's no passing lane, I will try to pull over promptly if even a single vehicle comes up behind me. Not always, but if I will if I can. I only wait for a queue of 5 when I'm going the actual speed limit, which definitely also happens.
    Hell, sometimes when I'm not sight seeing and going 10 over, I still get people passing me. It seems no matter fast or slow I go, there is always someone in more of a hurry than I am.
    I tend to agree, that yes it is incredibly selfish to drive less than the speed limit, but it is after all a limit, not a target. We pay the same amount of money for registration taxes and fees, so I think as long I'm not doing anything dangerous, illegal, or overtly selfish (hence the 5 vehicle queue rule), we have the same right to road and my conscience is clear. The slow speed thing is just on these weekend summer drives that I like to do, not my normal commute. The thing I do on my normal commute is decelerate slowly when possible, but I signal early, and for traffic lights that have turned red or are about to turn red, well, I'm not impeding anything no matter how gradually I slow down if we all stop at the same light.
    davidstacoma[QUOTED] likes this.
  5. Jun 16, 2022 at 4:29 PM
    #65
    Dawelda
    Dawelda Well-Known Member
    West of West Phoenix
    20 Tacoma DCLB TRDOR Desert Sand
    2.5" lift w/33" tires, 10K Winch & bumper, camper shell
    Funny!:rofl::rofl:
    But to be fair, there's definitely something wrong (mindless sheep) with those people that will follow and be "stuck" behind someone and NOT pass on the right when it is prudent. :cheers:
  6. Jun 16, 2022 at 4:29 PM
    #66
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    I drive the speed limit, and stay right. Doing that I get passed like I am standing still…what do notice about the passing lane at least here…it is speeders tailgating other speeders.
    AxisCab and davidstacoma[QUOTED] like this.
  7. Jun 16, 2022 at 4:49 PM
    #67
    davidstacoma
    David
    NC
    That’s true, however sometime you can’t pass on the right due to traffic going faster. I just bode my time and when I can get over, do it. I may or may not give a good horn alert to the slow driver in the left lane.:rolleyes:
  8. Jun 16, 2022 at 7:46 PM
    #68
    SwollenGoat
    On two lane HWYs I’ll pull over and let people pass. They may think I am being nice, but I am letting them run interference for LEOs…let them get the ticket. ;):D
    AxisCab and Taco75605 like this.
  9. Jun 16, 2022 at 7:50 PM
    #69
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
  10. Jun 16, 2022 at 8:09 PM
    #70
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    bye bye bye
  11. Jun 16, 2022 at 8:40 PM
    #71
    Taco75605
    Taco75605 Well-Known Member
    Blake
    2022 Tacoma TRD Sport RWD
    I’m all for people that want to drive below the speed limit, when they are polite and considerate about it.
    You never know. That slow driver might be driving home from the hospital, just got fired or on their way to a funeral for a loved one. I usually give folks the benefit of the doubt. No matter how bad my day is, I can bet someone else, somewhere is having one far worse than mine.
    AxisCab and Vmax540 like this.
  12. Jun 16, 2022 at 9:02 PM
    #72
    SwollenGoat
    I used to drive fast…fast enough to have my license revoked, and almost had it revoked again. Don’t even want to know how much I have paid in fines, or time wasted in traffic survival school. Lesson learned… took awhile, if people get pissed off for me driving the speed limit or below, fuck ‘em. Sure I’ll get the “look” of why are you driving so slow stupid! I’ll give them my best parade wave and shit eatin’ grin back.
    Man…would never know we are having record high fuel prices for how fast people still drive.
  13. Jun 17, 2022 at 2:02 AM
    #73
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Where there is traffic I drive 5-7 m.p.h. above the limit and that is too slow for the vast majority of drivers... Back paved roads I pull over frequently and get a kick out of passengers not used to riding with me when they flip out wondering why I'd do such, then there's the tailgater's that sit behind you until you stick your hand out the window and wave them by.
    Taco75605 likes this.
  14. Jun 17, 2022 at 5:52 AM
    #74
    Tacospike
    Two Trucks
    Edit: also a 38 gal tank
    ijm01PR likes this.
  15. Jun 17, 2022 at 5:54 AM
    #75
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    You forgot to mention that the whole trip was downhill :)
  16. Jun 17, 2022 at 6:34 AM
    #76
    SwollenGoat
    I put the cruise at the speed limit. Won’t drive faster for tailgaters, if they can’t figure out how to get around me that is their problem. Luckily I can take ranch back roads most of they way to work and don’t have to deal with majority of the dumbasses. Only on the interstate once a week to head to the trails, just sit back and laugh at people getting frustrated. Ya think they would eventually realize that a pig enjoys rolling around in the mud. If want to piss people off drive the speed limit. lol!
    AxisCab likes this.
  17. Jun 17, 2022 at 6:35 AM
    #77
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i hate pricks that tailgate you and flick you off because the guy in front of you is going slow
  18. Jun 17, 2022 at 6:40 AM
    #78
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    I get 22-24mpg on 40 mile drives at 70mph on a Highway with hills.
  19. Jun 17, 2022 at 6:42 AM
    #79
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    I've got MPGnis envy right now.
    SwollenGoat likes this.
  20. Jun 17, 2022 at 6:57 AM
    #80
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Amen brother! Whenever I get behind a minivan doing the speed limit or less, I always think of my Dad and I give the slow driver an automatic pass. I wish Dad was still out there aggravating other drivers.
