265/65/17 or 265/70/17 for highway tires?
Discussion in 'Wheels & Tires' started by BlueTACO09, Mar 13, 2017.
  1. Mar 14, 2017 at 7:51 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Sprung vs unsprung weight and then adding in rotational weight. The following is quoted from another car forum... I will not be held responsible for spelling, punctuation and grammar mistakes, but it is well explained:
    "you really have 3 different classifications of weight.
    sprung weight
    unsprung weight
    rotational weight
    sprung weight is anything that is on the car that is carried by the shocks/springs. so trunk, seats, engine, etc...
    unsprung weight is everything that touches the road before the springs. so wheels, brake rotors and calipers, hubs, and half of the shock itself.
    rotational weight is the stuff that rotates. here there is a bit of a mix between sprung and unsprung weight. your driveshaft is rotational weight, but it is also sprung. your wheels are rotational and unsprung.
    ideally, your suspension will work best with the least amount of unsprung weight (quicker response, less inertia), so better handling. your car will accelerate best with the least amount of rotational weight. so wheels, brake rotors, drive shafts, light weight clutch, etc. reducing sprung weight helps everything, but not quite to the effect that the other two will.
    so if you look at it that way, taking rotating, unsprung weight off the car will help the most. wheels, brake rotors, lug nuts, tires. there is no set number like a lot of people pass around like "1lb of rotating mass is like 5lbs of regular mass". thats just not easily quantifiable because if you take a pound out of a tire, its going to have a much bigger effect then taking a pound out of a driveshaft. the reason is the tire has a much higher moment of inertia then the axle does."
    AdventureKid and BlueTACO09[OP] like this.
  2. Mar 14, 2017 at 8:28 PM
    BlueTACO09
    BlueTACO09 [OP] Member
    Louisiana
    09 Double Cab PreRunner SR5 V6 TRD Sport
    Fold-A-Cover bed cover, OEM roof rack
    So saving a few pounds in tire weight is worth more than the benefit of a larger tire?
    KevC likes this.
  3. Mar 15, 2017 at 6:03 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Depends on how you use your truck. If you do a lot of steady highway cruise with very little acceleration once you get up to speed, the tire weight won't make much of a difference.
  4. Mar 15, 2017 at 6:04 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Use stock size, your MPG is worse with larger tires. It is all for looks.
    Oey12 likes this.
  5. Mar 15, 2017 at 6:14 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Tire for tire, when I was looking to go from 265/65/17 up to 265/70/17, the slightly larger 70 series tires were generally cheaper. Turns out the 265/70/17 is a standard size Silverados (and maybe other full sizes) use. The 265/65/17 used on the Tacoma is not as common of a size.
  6. Mar 15, 2017 at 3:17 PM
    BlueTACO09
    Louisiana
    Like I mentioned before, I've found the same thing. This is one of the reasons I'm considering it.
  7. Mar 18, 2017 at 5:46 PM
    bhughesru03
    bhughesru03 Well-Known Member
    Virginia
    20 TRD OR 4x4 MGM
    I've been considering the same thing. To my understanding the 265 70 17s are about an inch taller then the 265 65 17s. Does that mean a slightly higher ground clearance too?
  8. Mar 18, 2017 at 7:12 PM
    BlueTACO09
    Louisiana
    From what I've read, yes. About an inch of extra ground clearance
  9. Mar 18, 2017 at 9:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    1/2"
  10. Mar 18, 2017 at 9:13 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    This.
  11. Mar 18, 2017 at 9:14 PM
    T4RFTMFW
    1" taller tire = 1/2" more ground clearance.
    Height increase divided by 2, always.
    BlueTACO09[OP] likes this.
  12. Mar 22, 2017 at 7:34 PM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    Well, my question fits right into this thread. I have a 17' TRD OR with 16" stock rims.
    I would like to go 17x7" TRD Pro 4Runner rims, but don't want to go the standard 265/70/17.
    What's the narrowest tire I can put on the 7" wide rim? Reason I ask is because, more contact on the ground=more rolling resistance = worse mpg.
    I think this plays just as much into the equation with tire weight, etc.
  13. Mar 23, 2017 at 7:07 AM
    CanadaToy
    Greg
    Toronto
    I would be more concerned about the tread. i know my best mpg in a truck was with michelin ltx m/s2 tires. i hit 9.7 L/100km (24mpg) in a 99 4runner that was rated for 13 L/100km (18mpg). Haven't gotten close to there with my 17' yet which is rated for 23mpg (10.2 L/100km)
  14. Mar 23, 2017 at 7:28 AM
    AdventureKid
    Jake
    Oceanside, CA
    Camper Shell
    *I'll be running Michelin LTX AT/2 which already have a better rolling resistance than the stock Goodyear Kevlars.
    The best mpg I have had with the stock tires was highway, driving conservatively and did 26.8mpg.
  15. Mar 23, 2017 at 8:16 AM
    #35
    BlueTACO09
    Louisiana
    If I can afford it I would like to get the Michelin defender m/s. I'm thinking about going with the larger diameter mainly for looks and to fix the speedometer. I've been looking at coopers lsx also mainly for looks. I don't need an all terrain but I want a tread that won't get me stuck in wet grass.:ballchain:
  16. May 19, 2022 at 9:11 AM
    #36
    haljordan
    haljordan Member
    Hal
    Wondering your thoughts here: https://www.tacomaworld.com/threads...e-trd-pro-wheels-all-stock-suspension.766232/
    I'm basically debating just about the same thing. Going with 16" for a new set of wheel and tire combo vs 17" . I can actually get the 17" setup cheaper than the 16" , but out of necessity I will be doing a lot of highway driving this summer with my Tacoma, which with gas prices as they are, will add up quickly.
    Oey12[QUOTED] likes this.
  17. May 19, 2022 at 10:39 AM
    #37
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    Honestly since you’re going to be doing a lot of highway I would keep to stock size tires. If you choose those 17” rims, 265/65R17, or if you go with 16” rims, 265/70R16.
    Upsizing tires will do nothing but hurt mpg’s in my experiences. I drive extremely conservative with mpg’s always in mind. Looks are by far the biggest benefit IF you don’t do legit off-roading…(pardon my grandiose here) but I have went up/down plenty of rocky and sometimes icy hunting trails with stock size Michelin LTX’s without fail.
  18. May 19, 2022 at 10:52 AM
    #38
    CanadaToy
    Greg
    Toronto
    17" wheels have more tire selections. but either is fine, get whatever rim design you prefer.
    265/70/17 are larger than 265/65/17 and 265/70/16, so your MPG will be a bit worse, and speedometer off about 2-3%.
  19. May 19, 2022 at 11:14 AM
    #39
    haljordan
    haljordan Member
    Hal
    I should have clarified that the primary reason for selection of 265/70/17 to mount on the 17" wheel was based on the fact that it is _very_ widely available and indeed is cheaper than the 265/70/16 tire by a good margin (and is what the 4runner TRD pro uses)
    I've seen quotes on this site about this. Seems a lot of domestic trucks utilize 265/70/17 so that may be the reason for the cheaper price.
  20. May 19, 2022 at 11:32 AM
    #40
    CanadaToy
    Greg
    Toronto
    depending on your suspension and wheel set up, it may have minor rubbing on mudflaps / etc. it will look better. if you get efficient tires it wont affect your MPG too much.
